Results 1 to 7 of 7
Thread: Cove STD?
    Feb 2007
    Cove STD?
    Hi guns, show me your Cove STD!
    I'm going to buy one, so I'd like to know...
    -how does it ride?
    -is the frame strong? Does it last?
    -does bearings last?
    -wich chainguide did you install?
    -any information about '09 model?
    -how much does it weigh?
    thank you so much!
    Reputation: Scottandhisdog's Avatar
    Feb 2005
    Where are you buying one? I am interested in it too. I saw it on their website and it looks like it's exactly what I want.
    Feb 2007
    I'm Italian and in Italy Cove bikes are not imported. I'm going to buy it on a european website...
    Now I own an Intense SS, but this was not money well spent: bearings wear quickly, pivots get loose and the rear end is flexy... Now I just want to be sure that the frame I'm interested has not the same problems...
    Reputation: dr.smooth's Avatar
    -how does it ride?
    The feels similar to a Shocker in that the angles are quite similar except for the seat angle, just a little less travel.
    Tough as nails.
    On the hardest ridden bikes (Shocker and STD) the upper seatstay 628 bearing is a little rough at the end of the year. Other that that, expect no issues.
    An E-13 SRS or similar single ring guide fits fine with little or no modification. The E-13 DRS will work but requires some special attention.
    No changes thus far, just different color options.
    Kinda chunky, a tough lighter than a Shocker.
    Oct 2007
    Quote Originally Posted by Switch_81
    -how does it ride?
    thank you so much!
    16,8 kg
    Feb 2007
    Has anyone got a photo in bright green?
    I like the frame so much and if you say it has not problems with reliability I thing I will get one soon
    To Switch 81
    If you are interested in STD we got some on stock in Slovenia - Ljubljana in our bike shop .
    www.imbbus.si It is not far from you.
    You can e-mail me to : gregass@gmail.com and I will give you all the details.
    Otherwise awesome bike
    cheers greg
