Results 1 to 27 of 27
    Reputation: GearTech's Avatar
    Cove Needs it's own forum!
    Seriously, they are some of the nicest bikes ever made. It would be nice to have a seperate spot to post pics and discuss setup.
    I think so too
    Reputation: Mr Bling's Avatar
    Jan 2005
    ditto
    Former Homer...Ventana convert: extreme poseur!
    thats true, mtbr please gife use a forum!
    ride.
    Tonton Flingueur
    Reputation: mr_manatane's Avatar
    Dec 2008
    It's a must!
    "Bougez pas ! Les mains sur la table. J'vous préviens qu'on a la puissance de feu d'un croiseur et des flingues de concours."
    i agree
    Feb 2007
    petition!
    Throwing my hat in the ring too!
    I agree too!
    Sunshine & Slippery Trail
    Reputation: andyb721's Avatar
    I've been waiting for this for years. Own forum please!
    Jan 2005
    cooooooooooooooooooooooooooooom'on
    Jan 2005
    Yup, agree.
    Jan 2005
    CraigH, what do you say? do we have a deal or what?
    Jan 2005
    don't let this thread get cold!
    pit
    pit is offline
    i agree too.
    Steve, from France.
    Quote Originally Posted by Mr Bling
    so, I post it here too: renewed homepage for the 2010 year. the handjob has Tange Prestige cromoly tubing in 2010 and new decals. I was thinking about the reason... wasn't the nivacrome good enough or the tange is cheaper or what?
    http://www.covebike.com/bikes/handjob.html
    I know Coves are hugely popular on the Shore. Let's keep this thread going until we see results
    Quote Originally Posted by Kisherceg
    The Columbus Tubing wasn't approved by some governing body for sports equipment safety. It was mostly due to the EU rules for imported sporting goods I think. Either way the Tange tubing is way better to work with and produces a more consistent product.
    Ride the dream
    Reputation: EnglishT's Avatar
    -signs-
    future convert - might have to get an STD
    Quote Originally Posted by EnglishT
    -signs-
    It's such a solid and versatile frame, do it!
    Ride the dream
    Quote Originally Posted by GearTech
    Well its been a tossup with that and the maelstrom - to be honest, stories of idler pullies wearing rather fast (hence high maintainance) is what put me off it.
    The STD seems more simple, yet interesting and solid at the same time.
    I've owned the Maelstrom and now own the STD. The are both amazing machines. If it's simplicity and low maintenance you're after the STD is the better choice. I would compare the Maelstrom to an F1 race car. It requires maintenance and attention to be reliable and to perform at its peak. The performance is damn awesome as well. I never had any problems other than pulley wear and Corsair is working on that.
    The STD is a workhorse with some serious pedigree. The performance with an Elka Stage 5 shock is flawless. It's burly, low maintenance and has excellent clearance for all the moving parts to prevent mud clogging and binding problems.
    Ride the dream
    Have ridden the STD (and liked it) but havent ridden the maelstrom. I'm all for interesting innovations, but not at the cost of reliability (as seems to be the case) unless the performance increase is drastic enough to warrent it.
    Evidently you liked it, but was the performance increase (if there was any) significant enough to warrent choosing it over the STD?
    I have certain parts that I can build up with already (but which I'd want to replace later) - the plan is eventually to go with an n'dee/stoy combo. Haven't had any experience with elka, but if they're anywhere near BOS it'd be worth a look (so I'll look).
    Edit:
    I'm kinda limited by certain parts (well, ideally, as I dont want to replace them immediately) so any other suggestions with 150 rear-hub spacing and 83mm bottombrackets, go for it.
    Ideally want something that will pedal (if needed, which generally wont be), isn't overly heavy and under 200mm rear travel (so more FR than DH).
    Edit:
    I can wholeheartedly recommend the STD for what you're looking to do considering the frame specs that you require.
    Ride the dream
    The only thing really standing in the way right now is the uber-sexy sunn radical (having removed the maelstrom from my shortlist for being too high-maintainance).
    There may be others out there, but I'm not seeing them - the STD and radical both fit within what I want. The radical (short) is lighter and lower, but the wheelbase is no longer and the headangle is the same. The STD is probably stiffer and probably pedals a little better and (for me) is a little cheaper.
    Tricky decision. No doubt someone will throw something else into the works just to make life more difficult.
    I've not ridden a Radical but they do look nice (and light) I'm turned off by the odd shock mounting though. I've heard they are pretty flexy in the back end, is that true?
    Oh, Cove still needs it's own forum
    Ride the dream
    Yeah, the odd shock mount is probably a love/hate thing - for me its a nonissue as BOS is plenty good enough (and with it being a -relatively- small company, I doubt getting the custom stoy is likely to be an issue anytime soon).
    I wouldn't be surprised if they're less than pedo-in-a-playground stiff, but I've not heard of them being overly flexy. I'm not a heavy boy so I dont tend to feel flex unless its really excessive (and with a 150mm hub, I doubt it would be).
    That (roughly) kilo of weight less than the STD is also appealing.
    And yes, Cove still needs its own forum (either way).
