Results 1 to 2 of 2
    Cove Hustler & G-Spot Main Pivots
    I am thinking about getting a Hustler, but am wondering if there are any common problems with these frames? Also, do the Main Pivots hold up well or do the loosen up and require regular maintenance to keep them tight?
    Also does anyone have a Hustler frame they are trying to sell?
    Thanks, Pat
    Reputation: lambhead's Avatar
    main pivot is fine
    on my G spot. The hustler comes with an RP3 which you will need to offset the potential bobing from the pivot design though. bolt check it every once in a while for hand tightness, but don't tighten them too much or you'll have crunchy bearings in no time. the 2 bolts per side on my G's main pivot are seriously beefy, and cranking them down for fear of them coming loose is unnecessary. great bikes, fine quality, sweet workmanship, I'm sure you'll love it.
    Gabe
    Quote Originally Posted by pkyam
    Thanks, Pat
