Results 1 to 3 of 3
    CAK
    CAK is offline
    Reign Rider
    Reputation: CAK's Avatar
    Cove Handjob, what Bottom Bracket for ISIS?
    Running Truvativ FireX, trying to figure out BB and Chainline for tripple rings.
    Reputation: CulBaire's Avatar
    68x113mm
    Howdy Cak,
    A 68mm X 113mm should fit ok, Thats what I am running with my turbines and the chainline is pretty good.
    I am however considering an experiment with a 68mm X 108mm to Try and be able to run all gears in the middle ring, but only the top 3 or so when In granny gear; as I run plan on running a 20/32/44 x 12/27 set up. Donno how it will work, or if there will be enough clearance etc...
    Anyways a 68mm X 113mm BB should work ok with the FireX cranks.
    Hope I helped some
    -Cul
    Cul is a regretted trademark of the CulBaire Co'op Pty Ltd, as are his random ramblings and associated bullshit.
    CAK
    CAK is offline
    Reign Rider
    Thanks,
    I got the frame last week. Wow, it really is nice.
    I'll post some pics when the build is done.
    -Chris
  1. @#$%^&* Shimano bottom bracket mounted derailler
    By old_dude in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-02-2004, 10:04 AM
  2. Replies: 10
    Last Post: 05-24-2004, 12:06 PM
  3. Please help! Broken bottom bracket lock ring.
    By Bart in forum General Discussion
    Last Post: 05-15-2004, 01:09 PM
  4. brand new bottom bracket, broken?
    By kenaran in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-12-2004, 10:47 AM
  5. Help with bottom bracket
    By DoothaBartman in forum General Discussion
    Last Post: 04-10-2004, 02:44 PM
