Results 1 to 3 of 3
    househusband
    Guest
    Cove Handjob - a few questions!
    Hi all,
    Currently have a Cotic BFe, which is a great hardtail but is somewhat overbuilt - so doesn't really have the 'zing' that most steel frames have. My back is telling me that I should be looking at a new steel frame and the Handjob ticks all the boxes for travel and angles.
    I would be grateful for folks' comments on the following:
    1. Tyre clearance - I use 2.3" Hutchinson Barracuda's; what's the tyre clearance like?
    2. Rear brake rotor size - I use 185mm at the back; anyone else use the same, does it fit okay?
    Thanks.
    Reputation: dr.smooth's Avatar
    Lots of room for big tires. I run a 185mm rear rotor and it fits fine.
    -Adam
    customized
    Sep 2003
    It will gobble up those little tires no problem.
