Results 1 to 2 of 2
    Coil over rear shock on their ETSX?
    Just curious. I am going to build up a 2003 ETSX and have a relatively new 2004 Vanilla coil over (Pro Pedal) from my 2001 Element Race that will fit (I assume I will need new spacers and a beefier spring due to the different frame) but I am wondering if anyone has any experience. I would imagine the right cross country spring weight set for 4" would also be good for 4.5" (squishier) but would be too stiff for 3.5" travel because my shock does not have compression adjustment.
    Does anyone have any experience with this type of setup?
    Reputation: FireDog46's Avatar
    I have...converted to a Vanilla RC
    Got tired of having to check pressure settings all the time. That, and pressure varies
    according to weather. Noticable when the ambient air temperature varies by as much
    as 20 to 30 degrees centigrade.
    See my etsx 2002.5
    http://forums.mtbr.com/showthread.ph...aded#post94649
    However, with coil it is critical that you are as accurate as possible with the spring rate.
    I posted a spring rate calculator on this forum (have been thinking of posting the latest
    version). Calculate a spring rate for the 4" position with 1.5 turns of preload. If you
    have your riding weight and style correctly entered (weight and bias) the calculated spring
    rate will work for both the 3.5 and 4.5 positions with about a 5% decrease and 5% increase
    in sag respectively.
    Don't overdue the rebound setting, otherwise the shock will tend to pack down. Something
    an air shock has less of a tendency to do due to the ramping up of the effective air spring
    rate.
    This may be specific to the Vanilla RC, but I find it works a lot better in the 4.5" setting.
    I think this maybe due to the increase leverage ratio and that the RC was designed for
    more aggresive freeride type longer travel/higher leverage ratio bikes.
    I like the change the conversion has made to the ride characteristics. Unfortunately I
    haven't been able to get much riding in this year and was still in the process of fine tuning
    spring rates. I have a compliment of different rates from 450# to 600# in 50 increments
    with an 700# and 800#. Yea...overkill but each was only $25 from Cambria and my weight
    has been known to vary by as much as 30# to 40# (either body mass or protective clothing).
    I'm currently bouncing between the 550# and the 600# in the 4.0 and 4.5 positions.
    goodluck
    michael
  1. Service Tip for all Cane Creek rear shock owners
    By TeamTwentyFour in forum Shocks and Suspension
    Last Post: 06-13-2006, 01:23 PM
  2. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  3. Replies: 45
    Last Post: 10-12-2004, 12:04 PM
  4. How much & what kind of oil to put in rear coil shock?
    By retch in forum Shocks and Suspension
    Last Post: 06-30-2004, 03:20 AM
