Results 1 to 3 of 3
    Coil on 04 Slayer
    Goodaye Blokes
    After some advice please (btw, did a search on this forum, found a couple of usefull bits of info, but after more)
    As i am becomming more proficient at taking Becky (04 Slayer 50) to her limmits i am wondering whether a coil in the rear would serve me better.
    I don't want to pressure the buggery out of the Float RL to stop her bottoming (i still want small bump compliance). As i am hitting up bigger stuff she does occaisonally bottom out (twice last night) - i expect this issue will get worse as the jumps/drops get bigger.
    I consider myself to be a reasonably smooth rider, who makes use of the legs to minimise impact.
    Any advice on how to overcome this issue?
    Will a coil in the rear help the issue - remembering i still want small bump compliance (and a pedal platform if possible). If YES - what would be the reccomendation for a coil rear shock? I am not into constant mid ride 'tweaking' of dials and knobs (never even used the lock out on the Float RL or Vanilla 125) - set and forget is for me! Simple is good.
    Jawry
    just a bump guys...
    ...anyone got any further advice?
    Thanks, Jawry
    livin' large
    Reputation: canadian-clydesdale's Avatar
    It is possible to put a coil on, but I would be concerned about your rear triangle if you get to crazy with the drops you could snap that rear end. It's okay to bottom out your shock once in a while I've been told if you bottom out once or twicw a ride you have the right pressure.
    it tied the room together man!
  1. Switchblade with coil over...YES!
    By dodger in forum Titus
    Last Post: 03-07-2008, 11:38 AM
  2. Help 04 or 05 Gemini....long post
    By spacoli in forum Cannondale
    Last Post: 03-06-2005, 04:02 AM
  3. Help 04 or 05 Gemini....long post
    By spacoli in forum Bike and Frame discussion
    Last Post: 03-04-2005, 12:58 PM
  4. Elsworth Dare... hit or miss?
    By Korrupt in forum Downhill - Freeride
    Last Post: 08-13-2004, 08:17 AM
  5. 04 Stinky, 04 BigHit? or 04 Atomik?
    By Phil_Mosco in forum Downhill - Freeride
    Last Post: 05-13-2004, 12:29 AM
