Results 1 to 10 of 10
    rmb
    rmb is offline
    Reputation: rmb's Avatar
    Blizzard derailleur hanger question
    I have a 2004 blizzard frame that I built up using parts from another hardtail, this is my first steel frame.
    My question is; are you supposed to use a breakaway derailleur bolt on these frames since the derailleur bolts directly to the frame?
    Reputation: GearHead's Avatar
    Dec 2004
    In simple words, NO.
    The steel derailleur hangers are much stronger than the aluminum ones. Aluminum ones NEED to break or bend before the frame they protect does. If you bend a derailleur hanger on a steel frame bike, just take the derailleur off and bend it back straight with a cresent wrench.
    rmb
    rmb is offline
    Thanks for the information.
    ups and downs
    better a fragged bolt than a mangled derailleur
    There is still some advantage in using an aluminium pivot bolt for the rear derailleur, if you do catch it on something it's generally cheaper to replace the bolt rather than a pricey derailleur. Not that it makes it any easier to get home again with the derailleur ripped off versus having it mangled.
    Dec 2004
    Blizzard/steel frame derailleur hanger adj.
    Quote Originally Posted by GearHead
    Err, well, you are right that there is no need for the break-away hangers, as on Al. frames, but, you should have a shop put a proper derailleur hanger adjustment gauge on the frame (Park makes 'em) and be sure that the hanger is true. Even if the hanger is out by a few degrees, it is almost impossible to get the rear derailleur to perform as it should, no matter how much you tweak the set screws. Just my $0.02!
    Edan
    Inrideo est vita
    Reputation: SSteel's Avatar
    Psst.... If you make it a singlespeed you won't ever need to worry about such trivialities.
    Canadian distribution: X-Fusion Shox, Rand Momentum lube and Canadian Shield fenders.
    TheRide.ca
    Facebook
    LBS Manager
    Reputation: Johnny Hair Boy's Avatar
    I heard of fix once
    A friend of mine years ago would take his derailer off and cut 1/4 to 1/2 of the way through the main bolt so it would break well before the frame could get damaged. I have never done this my self but I have never had a steel frame.
    LBS Manager
    Hi
    Quote Originally Posted by SSteel
    Did you get that rigid fork fixed yet
    Inrideo est vita
    For sure.....
    Looks great.... rides great!
    TheRide.ca
    Facebook
    rmb
    rmb is offline
    I decided to use an aluminum bolt to avoid any potential problems. It was cheap enough.
  1. Dare derailleur hanger question
    By vibiker in forum Ellsworth
    Last Post: 04-21-2005, 05:12 PM
  2. derailleur hanger
    By FishMan473 in forum Titus
    Last Post: 12-28-2004, 02:44 PM
  3. Derailleur Hanger Question
    By Draxxx in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-16-2004, 05:26 AM
  4. Replies: 3
    Last Post: 08-07-2004, 08:51 AM
  5. Replies: 8
    Last Post: 05-18-2004, 09:26 PM
