Results 1 to 2 of 2
    Reputation: canada17's Avatar
    Banshee Morphine and Rear brake
    Morning everyone,
    I just got a morphine and am building it up. I having issues with the rear brake mount being too close to the disc. Those of you who own a morphine know the size (thickness) of the mount is incredible but it puts the caliper too far into the wheel. Any ideas how to fix this. I was imagining that if I slid the entire wheel on the through axle over a mm or two (with a spacer) that might help, as it is now there is two spacers on the drive side, one on the non-drive side, and that one spacer would do the trick, but I don't know if that is the shoddy way to fix this issue. Anyone else had this? If so, how did you fix it?
    "Eagles may soar, but Weasels don't get sucked into jet engines"
    Ghost ride the whip!
    Apr 2005
    I had the same problem at first, but I had some super thin washers under my rear rotor and when I took them off everything lined up fine.
