Results 1 to 7 of 7
    trail "cleaner"
    New question here. Any Cove Hustler XC owners out there?
    I just checked Cove's web site and noticed the Hustler. Sweet looking bike. Anybody out there own one? I currently own a 03 Siffee FR and this bike appears to have the same front triangle as the Hustler. Will a 5" fork work OK even though they say it's designed around a 4" fork?
    One Cove Hustler owner
    Yep. just got one. Only 1 week old but allready clocked up about 20hrs in the saddle. This bike has a massive grin factor and so far has handled everything thrown at it. I run 100mm forks and the handling is razor sharp and recon it could handle a longer fork if needed. Get one you will not be disappointed.
    trail "cleaner"
    lets see some photos!!
    Quote Originally Posted by Godders
    How's the weight and pedaling efficiency? Any photos to share??
    As requested.......
    ....some photos!
    Bike must be ~28lbs with an XC build. The frame came with a 2005 fox float rp3 (which was an unexpected bonus). This has 3 pro pedal settings one is super plush for down hill, standard pro pedal which works well 90% of the time and a ?climbing setting which
    eliminates almost all pedal bob. As a result the bike climbs very well and all round pedal effeciency is very good over all terrain.
    Check out the photos
    (if this upload thing has worked)
    more photos
    I know nobody thinks rock shox are cool anymore but Duke races forks work perfectly with the bike, any look ok too!
    trail "cleaner"
    rear tire size capability
    Looks awesome! How large of a rear tire do you think will fit? I prefer 2.4's and was hoping they'd fit OK. I'd also run either a Z1 SL or a Talas up front. Do you think a 130mm travel would hose the handling? Thanks!
    hmmm
    2.4 is going to be tight at the back, if t does fit it won't leave much room for mud.
    A talas would be perfect, i think it could handle a 130mm fork although having the option to come down to 100mm would be great if you good since the handling is so good.
  1. Cove Stiffee for XC
    By Autumn in forum Bike and Frame discussion
    Last Post: 06-22-2004, 03:31 PM
  2. Cove Hustler XC
    By sh0rty in forum Bike and Frame discussion
    Last Post: 05-18-2004, 11:14 AM
  3. Local DH'r kicks ass in the XC at Sea Otter
    By Slayer77 in forum Downhill - Freeride
    Last Post: 04-26-2004, 12:56 PM
  4. Sea Otter XC update--Mark Weir
    By Slayer77 in forum Passion
    Last Post: 04-26-2004, 12:54 PM
  5. Agressive XC bike help
    By DJGsnax in forum Bike and Frame discussion
    Last Post: 03-03-2004, 10:04 PM
