Results 1 to 3 of 3
    05 ETSX rear shock help...
    I'm wondering if anyone can chime in with tips on how you've set up your rear shocks. I've gotten an 05 ETSX-70 as a replacement frame, and its got the RP3 on it. No manual came with it. Bike shop not very helpful either. Sticker on the frame says that the shock is custom tuned for RM. I mostly use the frame in the 4.5" travel mode, I weight 180lbs and pump the shock from 160 to 180, and I usually ride in the "softest" pro-peddal mode...
    So, what's the BEST way to get this shock set up right?
    ups and downs
    It's as simple as that
    The fox website has an RP3 manual for download
    http://www.foxracingshox.com/website...Cshox_en05.pdf
    Basically you want to shoot for about 3/8" of sag. Here's the one paragraph on the Pro-Pedal setting
    ProPedal RP3 Damping Adjustment
    The FLOAT RP3 features a three position ProPedal tuning lever allowing on-the-fly ProPedal tuning. ProPedal damping reduces pedal induced suspension bob. The three settings of the lever are full ProPedal, light ProPedal and Plush. Use the different settings to tune the shock to different riding conditions and situations. For example, use the full ProPedal position for riding to the top of the mountain and then switch to the Plush position for the descent. Because suspension designs vary, some pedal inherently better than others.
    To determine which ProPedal position is best, pedal the bicycle at about 15 mph and moni-tor the shock movement. Switch between positions and select the one that reduces suspension movement most effectively while providing the desired amount of bump absorption. The setting may change depending on conditions and riding styles.
    LBS Manager
    Reputation: Johnny Hair Boy's Avatar
    I have the same bike
    and also weigh 180 I have my shock set up almost exactly like yours and that seems to the best for me.
  1. Service Tip for all Cane Creek rear shock owners
    By TeamTwentyFour in forum Shocks and Suspension
    Last Post: 06-13-2006, 01:23 PM
  2. 05 Fuel 70- rear shock upgrade suggestions?
    By gopriest31 in forum Trek
    Last Post: 02-28-2005, 09:14 AM
  3. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  4. Replies: 1
    Last Post: 10-19-2004, 05:32 AM
