Results 1 to 7 of 7
    Dec 2005
    Quick realease seat clamp???
    On my 06 specialized fsr xc comp seat clamp there is a black plastic piece shim between the metal parts I must have over tightend and caused it to crack can I remove this piece and go metal to metal the local shop says I have to buy a new clamp???
    Quote Originally Posted by Firemedic85
    There's no way that you should be able to break a seatpost clamp. Tell your LBS that it should be covered under warranty. IT's either a poor design or it was faulty to begin with.
    Samsonite Tester
    Reputation: Evel Knievel's Avatar
    Specialized uses house brand cheapos where they can. Try a Hope or Salsa clamp for longevity and quality.
    Yeah I gotta question. You got any excuses tonight Roy ? -Antonio Tarver
    There is room for it all, just ride what you like to on what you like to...that's freeriding. -rbn14
    Your Imaginary Friend
    Reputation: CranxOC's Avatar
    Quote Originally Posted by Blue Shorts
    On the contrary, cheap OEM products like the QR clamp frequently break and need to be replaced by better aftermarket products. Specialized builds a great bike but, in order to keep price points low they have to cut costs somewhere and a seatpost clamp seems as good a place to go cheap as any.
    Pick up a Salsa or Hope QR clamp and you'll literally never have problems again.
    There's a fine line between courage and foolishness. Too bad it's not a fence.
    Samsonite Tester
    Quote Originally Posted by CranxOC
    Echo echo echo .....
    right behind ya
    Reputation: Down boy down's Avatar
    Mar 2006
    Quote Originally Posted by Evel Knievel
    used a bunch of clamps for different rigs over the years and no are better than hope (IMO)- even salsa
    hard line, hard line, hard line after hard line
    I should have phrased it better. I meant that the seatpost collar should have been strong enough so that it wouldn't break. It obviously wasn't. Specialized should replace it whether or not the user buys a Hope or other clamp.
