Results 1 to 5 of 5
    Jun 2014
    need to replace my hub. anyone recommended in glendale/burbank/pasadena area
    need to swap out my front hub and i guess true the wheels while im at it.
    can you guys recommend a shop or individual? what is the average cost for something like this?
    im in glendale, so surrounding areas like burbank or pasadena is fine.
    thanks
    moar alike..
    Reputation: Deerhill's Avatar
    Dec 2009
    You should just do it yourself if you ride a lot.. cost depends what hub you want. Larry @ Ghisallo Wheels has solid builds if you don't have time.
    I ordered spokes from that wheelbuilder site..once. The spokes they sent were incorrect lengths
    All barks have been rendered into english...
    Jun 2014
    building part i can figure out; i just dont have the truing stand. and my wheels are basic. i just want to use a different fork so i need to switch from QR to 15mm through. my other option is get a used wheel set (again basic) for about 200-300. so if i can get the front hub switched out for a lot less then ill do that. if not i will just buy a used wheel set
    again, if anyone that can do this let me know your price. i dont mind if you work out of your garage or in a shop, as long as you know what you are doing.
    Reputation: h82crash's Avatar
    Dec 2009
    Get a hub from Bike Hub Store and go to your LBS. Usually lace you up for $50 or so. Spokes will cost you about $30. Should be done under $150. If you find a used wheel for less, buy it.
    BikeHubStore.com
    Goat Rider
  1. New to the area, Glendale area trails rec
    By Kabob King in forum California - Socal
    Last Post: 03-07-2013, 12:07 AM
  2. Glendale area middle level trails
    By Midle Age Warrior in forum California - Socal
    Last Post: 12-21-2012, 01:09 PM
  3. Recommended Trails in Pasadena
    By EManansala in forum California - Socal
    Last Post: 12-04-2012, 01:18 PM
  4. Glendale area trails?
    By MTP in forum California - Socal
    Last Post: 06-19-2012, 01:21 PM
  5. Re: Verdugo Mountains - Burbank area
    By BikingScott in forum California - Socal
    Last Post: 05-24-2012, 12:29 PM
