Results 1 to 16 of 16
    Apr 2016
    Gravel bike worth it in Ventura/LA?
    I consider my self a cyclist more then a mtn biker. I got a road bike I love, a mtn bike (that is better then my skills) that I don't really love, and an interest in getting a gravel/cross bike. I live on the border of T.O. and Simi and looking to explore more of the area between Simi and Fillmore/Piru and other places like that. The only issue is lots of the fire roads can get really step so I'm not sure of the ride-ability of a lot of those areas. Same thing applies to the Angeles Crest. The only other thought is that some of the places I ride the most, like Cheseboro and Sycamore, are mostly smooth trails where this type of bike would work fine.
    Anyone get a gravel/cross bike and find they never used it or really loved it in Ventura or LA county?
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    When I lived in WLA, I used to go for a weekly ride in the evenings up Sullivan Ridge and pretty much every week, I got DUSTED by a couple guys on cross bikes. They passed me on the uphill as though we were on flat ground and I was standing still. It actually seems to me that a cross bike would be perfectly suited for all the fire roads, if you were into that sort of riding.
    Beer Please! SuperModerator
    Reputation: Klurejr's Avatar
    Up in Ventura off the 33 out of the north end is a road called Sulfer Mountain Road. When I first got into MTB that was the place I learned how to pedal, it is just a long gentle grade fire road and would be perfect for cyclecross. I only ever road a few miles up and then back down, but I hear it goes much further.
    https://goo.gl/maps/h7NRYVM1uRo
    Ride Bikes, Drink Craft Beer, Repeat.
    Know these before you post:
    MTBR Forum Posting Rules
    e-bike sub-forum rules
    Reputation: 2w4s's Avatar
    Mar 2005
    political comment my ass
    nothing witty here...
    My other ride
    Reputation: Sidewalk's Avatar
    May 2015
    Put road tires on your mountain bike sell the road bike, problem solved.
    Redlands Strada Rossa Ride: March 18, 2017
    Sep 2012
    You can't really explore the hills between Simi and Piru. Maybe once they open up Los Alamos Canyon then you'll be able to. Also the trails in those areas are in a bit of disrepair so while you might be able to ride a cross bike it might not provide for the most comfortable experience.
    Also you can encounter some decent climbs that a cross bike isn't geared well for. I'd pick a lightweight HT instead. Much better gearing even at 32/36 f/r than a cross. And wider tires which help with grip.
    I've ridden a cross bike on a lot of trails but with the gearing and tire width, out of seat climbing is a lesson in futility as it's nearly impossible to keep traction on the sand over hardpack.
    Get a gravel bike that can handle some 50mm+ tires, and get a triple crank (yes, I'm old skool) if you want to ride instead of push up the steeper bits. I'm looking at a Vaya myself. None of the roads/trails in Pt. Mugu, except Hell Hill, require a little ring. Many of the Angeles Crest fire roads can be done in the middle ring. Locally, the Dough Flat road out of Fillmore (north end of Goodenough Road) goes on for freakin' ever, and is pretty darn pretty right now. Happy Camp Canyon is a quick (muddy, right now) loop, but when the ground dries out there are some sandy bits that will make 50mm+ tires attractive. Happy exploring!
    Apr 2016
    Quote Originally Posted by unaware View Post
    Quote Originally Posted by ScottR1 View Post
    Get a gravel bike that can handle some 50mm+ tires, and get a triple crank (yes, I'm old skool) if you want to ride instead of push up the steeper bits. Happy exploring!
    Thanks for the replies. The bike I'm looking comes with a 40 x 11/42 1x, 40c tires spec. Not sure the max width tire it will take. I think I might hold off till I get my fitness better by riding my other bikes more.
    Don't buy upgrades, ride up grades.
    I live in NP and ride my Slate all over. I geared it down so I can climb all but the steepest trails. I like to connect roads and trails to create all kinds of loops on all types of terrain.
    Some of my fav loops include: Chesebro/Las Virgennes/Grasslands/Malibu Creek/Paramount Ranch/Liberty Canyon.
    I ride it in Sycamore Cyn a lot, but I avoid Guad and Overlook as they are too rough and steep. I often climb Westlake to Mullie, jump on the Backbone Trail West to Yerba, down Yerba to the coast and then ride up Sycamore back home.
    Backbone is fun and easy from Encinal West to Yerba.
    East Los Robles from Moorpark Rd to Westlake is fun... lot's of up and down.
    Sulphur Mtn in Ojai was mentioned, that would be beautiful and green right now. It's a perfect ride on the Gravel Bike.
    TTUB - Ventura County California
    A gravel bike is absolutely worthwhile around here. I have a Black Mountain Cycles monster cross bike with a triple crank and 11-34 cassette and (before my year away from any bikes) I rode it on Chumash, Albertson, Dirt Mulholland, and many of the trails around Calabasas and MCSP. There are sections where I had to walk, but even with 35mm small block eights I can ride most everything.
    I think a gravel bike is totally worth it, since it allows you to put together big mixed surface rides, adding significantly to the number of routes you can put together.
    For mixed surface in the San Gabes, I really like the SRAM 42/28 chainring combo. I also think it's also worth finding a frame that can take a 2.0 tire, since the fire road descents can be pretty fast, loose, and rocky. You can always run a smaller tire if you don't need the traction and flotation.
    chasing simplicity
    Reputation: MattMay's Avatar
    Dec 2013
    Quote Originally Posted by TTUB View Post
    I live in Westlake and that's one of my fave mixed surface rides on my hardtail...recently added in a side route before PCH and then Overlook for some added vert!
    https://www.relive.cc/view/896486013
    On the gravel bike note, I've been seeing more if them on the trails...so OP, don't think it would be a mistake.
    I know what it's like to be dead. "To Die & Live In LA."
    Quote Originally Posted by MattMay View Post
    Nice route! Back out Deer Creek and then throwing in Overlook... ouch!
    Apr 2016
    Great route but I would die on that. Just climbing up Westlake kills me as I've done the road version of your route (Westlake, Yerba, Sycamore) both directions in the past. So the bikes worth it once I can get my ass up the climbs.
    chasing simplicity
    Dec 2013
    It's a once every couple weeks max for this old man!
  1. Ventura county mountain bike clubs?
    By trevor1030 in forum California - Socal
    Last Post: 06-06-2016, 12:40 PM
  2. Replies: 44
    Last Post: 05-03-2016, 05:47 PM
  3. Bike Stolen (Ventura Ca area x-post)
    By jeffgothro in forum California - Socal
    Last Post: 02-06-2013, 10:38 AM
  4. Bike Stolen (Ventura, Ca area)
    By jeffgothro in forum General Discussion
    Last Post: 01-23-2013, 09:51 PM
  5. Bike stolen while in Ventura
    By Xmxr in forum California - Socal
    Last Post: 11-25-2011, 02:32 PM
Members who have read this thread: 4
