Results 1 to 29 of 29
    dft
    dft is offline
    Reputation: dft's Avatar
    cheap cure for PO
    my friend emailed me this, thought i would pass along
    Okay, last week I said I may have a great remedy to NOT get PO infection post ride. It is an extreme measure but well worth it if you get it that bad.
    Mineral Spirit AKA "Pain Thinner".
    Right after the ride, get an old rug, soak it with paint thinner and rub your exposed area real well. It works. I wanted to try that for a long time and finally after last time riding XXX and being exposed so much to PO, I had to stop by Lowes, but the paint thinner and test it.
    It smells bad but well worth it.
    Here is how I got to test this: I got some technu for post ride that I used once in a while in the shower. I swear, when I was using it the smell reminded me of paint thinner. So I showed it to friend who is a chemist and she looked at the ingredients and she said the only active ingredient in this bottle is "Mineral Spirit", which is Paint Thinner. Sure enough I was right on track.
    Now when I was in High School I spent all summer working with painters (hard work), and at the end of the day to clean the paint from our arms, legs, we just use paint thinner and rub it until the oil paint is dissolved. It works great, and works great for PO which is also an oil.
    It is a radical solution, but hey, if you get it bad, it is well worth it, and 1 littler of it only cost $5.
    Reputation: rowdyranger's Avatar
    Quote Originally Posted by dft
    and to make this method even more effective, apply a lit match to the already applied paint thinner. Less skin means less area for the Poison Oak. Richard Pryor did it and never got PO again!
    Self Appointed Judge&Jury
    Oct 2000
    Wouldn't it be easier to inject battery acid directly into your veins? I did the same thing as a kid in the seventies we used gas or paint thinner to clean up almost anything. Although these days I think it has been proven to be slightly harmful to your health. The skin in a living membrane and certain things can be absorbed into your body via the skin. I could be wrong but it sure sounds like a bad idea.
    Dented n' Spent
    Reputation: endohappy's Avatar
    Just looking for a little clarification. Sounds like you're saying do this *right after* the ride when you know you've been exposed. Are you also saying it works after you've broken out and already have bad rashes?
    People have been washing up with paint thinner for a long time. Hard to believe it's that bad for you.
    Thanks for the info!
    What kind of bike?​ I don'​t know,​ I'm not a bike scien​tist.
    I piss on myself. It seems to work, i never get P.O.! Dawesome!
    Just use Windex. I am the PO master!
    I <3 Dirt
    Reputation: mealsonwheels's Avatar
    Paint thinner has worked for me with some success with PO and Poison Sumac. I like Zanfel though although it is pricey.
    endorphin addict
    Tecnu Xtreme is unbeatable, unless you just like the feeling of oak on your scrotum
    San Diego County
    Reputation: Duzitall's Avatar
    my friend emailed me this,... I swear, when I was using it the smell reminded me of paint thinner. So I showed it to friend who is a chemist and she looked at the ingredients and she said the only active ingredient in this bottle is "Mineral Spirit", which is Paint Thinner. Sure enough I was right on track.
    Good thing your friend had access to a chemist to read the bottle for him.
    Sorry, couldn't resist
    Quote Originally Posted by turnerbikes View Post
    Of course the easiest way to fix this is to go for a hike.
    DT
    Reputation: Namlak's Avatar
    I use Gojo Mechanic's soap as found at Pep Boys. That stuff will take any grease/oil off your skin. Probably less toxic than paint thinner, smells like oranges, and I can use it as soap when I need to (like after working on the car).
    Glad to Be Alive
    Quote Originally Posted by Namlak
    I heard that works good and windex......washing your skin with soap and water works for me
    I don't huck.
    Jun 2005
    We used Simple Green once. Seemed to work great.
    Blog Ramblings
    West Coast writer for twentynineinches.com
    I think the key is you have to get it off with something (anything that cuts grease will work) in a couple of hours. After that, it binds to your skin and you are screwed. I make it a practice to immediatly jump in the shower after a ride and scrub exposed areas well with soap. That keeps the outbreaks to a minimum. If I get a good scratch from a PO branch though I am toast no matter what I do.
    Once I actualy have the rash the only things I have found that help are Zanfel and benadryl and real HOT showers.
    i can't type the letter s
    Reputation: mouse jockey's Avatar
    Quote Originally Posted by DIRTJUNKIE,
    That's partly what makes it so good, it absorbs further into the skin than a topical soap, so it gets to the PO oil that has been absorbed deeper into your tissue.
    This is similar to my antidote but I've never used it to prevent infection post ride.
    And you're right, using large amounts of paint thinner does damage your ability to spell and type, and creates a chronic pain for vert which hinders relationships, and damages workplace efficiency, thus creating an individual with tonic mood swings that tends towards anti-social behavior when the vert hasn't been satisfied. It's kind of like a junkie addicted to heroin.
    Bad, bad, stuff...STAY AWAY!!
    Oct 2000
    Quote Originally Posted by mouse jockey
    Thank you, that explains why I have been experiencing all the above problems as an adult.
    Equal opportunity meanie
    Reputation: DHidiot's Avatar
    I have HEARD (but never tried) that automotive brake cleaner which is something like 90% acetone sprayed onto a rag and wiped over the affected area can help. I could see how it could work well too, since it evaporates things very quickly on contact. Probably best not to spray it directly on your skin though...
    805
    Oct 2000
    Quote Originally Posted by DHidiot
    I think we need a Dr. to interject in this thread. I have a feeling we may be seeing quite a few fatalities in the Southern California mountain biking community in the near future, and I'm not talking about riding fatalities. Is there a Doctor in the house?
    This thread = dermatologists nightmare.
    805
    mtbcat.
    dft paint thinner
    " dft." afterward make sure you leave the rag you use in a bucket next to your gas hot water heater so you can get that new fork .
    Trail Rider
    Reputation: Quattro's Avatar
    A natural alternative
    I went on an exploration ride through a canyon near a stream bed. The single track was very narrow and did a lot hugging the stream bed walls. I went over the bars when I hit a root. I ended up in a big bush of PO(face first). I immediately went down to the stream and stripped off my shirt, sat in the stream, then rubbed the wet sand all over my exposed body parts, including my face and head. I rinsed off in the stream. I didn't get any PO. I'm very sensitive to it.
    Don
    Mar 2006
    Another natural alternative
    If I get PO, I like to let bears or mountain lions lick the affected regions. Their scratchy tongues take it right off. It is an added bonus if you get the PO in your *sensitive* areas.
    Mercury (Hg) and radioactive waste is good for 'curing' "PO". gasoline, napalm and burning magnesium are pretty good as well.
    ENJOY!!!
    - m. b.
    It is the peculiar quality of a fool to perceive the faults of others and to forget his own.
    - Cicero
    Reputation: ocrider101's Avatar
    Use mugwart its a oily plant that grows right next to po. If you rub it on you it neautralizes the po oils. Its the old indian cure.
    Warrior's Society > WarriorsSociety.org
    Team Sho-Air > Team-shoair.com
    Coolest LBS > Switchbackcylery.com
    Socal Riders Unite > Socaltrailriders.org
    I would suggest Scientology. It is the cure for all that ails you. If you weren't an alien in a human body, then PO would never be a problem.
    Quote Originally Posted by CharacterZero
    BRILLIANT!!!
    lofl!
    and people, the FDA is around for good reasons, so be careful out there.
    as for poison oak, i've had countless battles with it. it sucks getting it in the crotch region. but the worst place is by far the face. shaving is brutile.
    i am sure some sierra clubber / tree hugger is gonna cringe at me saying this, but i'd like to be the person to spray agent orange on the last living batch of poison oak, thus causing it's complete extinction. the asterik asterik asterik asterik is vile.
    - Cicero
    pewpewpew Moderator
    Reputation: Impy's Avatar
    if you want acetone just use nail polish remover. who knows whats in that other 10%??
    btw I wipe down with alcohol - always keep a bottle in the car - so far 100% sucess.
    Love, Impy
    A few years ago I read all the PO info I could find. Here's a couple of main points if you're exposed.
    The quicker you can wash an area that's been exposed the better. Most importantly, don't use hot or warm water. That will just open your pores and your infection will be worse. When you wash your legs (or whatever area was infected), do not rub the area. That could just rub the PO oils into your skin. Your best bet is to find an ice cold stream.
    Quote Originally Posted by Impy
    Brake cleaner >>>> nail polish remover.
    My gf was out of nail polish remover. I suggested she use that stuff as a joke. She did and said she'd never had the polish come off so easy. The stuff is pretty gnarly.
    805
    MV Rider
    Quote Originally Posted by ocrider101
    One of the easiest and cheapest methods is to wipe down with rubbing alcohol. All you really want is something to breakup the oil that cause PO. You can buy 2 large bottles at Costco for about $3.00.
