Results 1 to 6 of 6
    Anyone in west LA with a magura bleed kit?
    Hi there...I have a magura marta that needs bleeding, and none of the several shops I called has a kit in stock. Since my bike is unusable until I get this fixed, I was hoping someone might have one I could use? I got air in the line so I just need a little fluid to purge the air, I'd be happy to reimburse whatever you think is fair.
    Stray Bullet
    Reputation: Nagaredama's Avatar
    Did you try Cyngery?
    I have a Magura service kit if you know how to do it yourself.
    Yes I did...no luck unfortunately.
    try helens on broadway, i've seen the magura blood there and they might also have the kit.
    Reputation: nintense's Avatar
    Did you try Bike Improve??
    They have Magura Bleed kit...
    P.S I'm the owner
    Quote Originally Posted by peligro
    Equal opportunity meanie
    Reputation: DHidiot's Avatar
    Moto shops, specifically KTM shops, should have a Magura bleed kit (most KTM's use a Magura hydraulic clutch - operates and bleeds the same way as any hydraulic brake). They are fairly inexpensive too. I want to say $25-30 for the bleed kit?
    805
