Results 1 to 34 of 34
    OOOOOOOh Gee Are Eee
    Reputation: Ogre's Avatar
    Feb 2005
    Z Shaped Cranks give you better leverage
    This is awesome... we need to help these guys fund these cool Z shaped cranks which make climbing super easy.
    Z Torque > Home
    They give you longer crank arms but maintain ground clearance!
    (I'm sure the chatter from so called physicists claiming these are a total fraud is just jealousy)
    Reputation: Snfoilhat's Avatar
    May 2010
    pffffffffffffffffffffffft
    aka dan51
    Reputation: d-bug's Avatar
    Mar 2005
    I'd totally buy, but they used THEN instead of THAN in their tag line. That's a bigger turnoff than smoking... Oh well.
    Uncle
    Reputation: Entrenador's Avatar
    Wow, Weir is older than I thought.
    Rhymes with fartmaster
    Quote Originally Posted by d-bug View Post
    Agreed.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Looks like some 1990s cr@p.
    Reputation: Brewtality's Avatar
    Spammer
    Reported
    Its all Shits and Giggles until somebody Giggles and Shits
    Lusus Naturae
    Reputation: NoBalance's Avatar
    Feb 2007
    Would totally get it except for the extra weight!
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    MIT professor be damned! The physics works here. In fact, I'm going to invent the "ZZ Torque", employing multiple Z's, as many as necessary, for infinite torque.
    Buyers can select from the following models:
    Legs - all around ZZ Torque model with 12 Z's. Most popular model.
    Sharp Dressed Man - top of the line Carbon model with 14 Z's. (Note: not carbon fiber, just carbon)
    Cheap Sunglasses - budget model, only 3 Z's.
    wg
    wg is offline
    Fermented Grain Sampler
    Reputation: wg's Avatar
    There's a whole lot going on here. I think it needs more suspension type stuff to help climbing...
    Don't harsh my mello
    Reputation: oakhills's Avatar
    Perpetual motion cranks!
    bicycle rider
    Reputation: morganfletcher's Avatar
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Ogre View Post
    Z Torque > Home
    Should do the same thing with the arms on the spider. Go faster without needing bigger rings!
    mtbtires.com
    Oaktown Honkey on Strava
    I think those cranks above would really help your cornering.
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    These cranks remind me of people who claim bike handling is different (due to leverage) between "angled stem without spacers" and "0 degree stem with spacers" - when the handlebar ends up in the exact same position.
    Reputation: TheMachinist's Avatar
    Feb 2007
    Quote Originally Posted by saul lumikko View Post
    these cranks remind me of people who claim bike handling is different (due to leverage) between "angled stem without spacers" and "0 degree stem with spacers" - when the handlebar ends up in the exact same position.
    burn!
    I feel like this whole thing has to be a troll. Look at the gifts they give you for contributing.
    Rock The Post | Z-torque Bicycle Cranks
    Reputation: gonzo's Avatar
    Leverage = distance between axel and pedal.
    Leverage = distance between axel and pedal. Does not matter how convoluted your crank arm is designed.
    Just get a 180mm crankset to get more leverage................
    Safety Consultant
    Reputation: Turd Fergusen's Avatar
    Saw this in the comment section of the debunking website:
    "A smaller front wheel means you can simply roll up a small incline with no effort. Make the front wheel small enough and you can roll up quite a steep hill with no energy expended at all."
    Brought to you by the inventor of the Z crank.
    Dec 1998
    Quote Originally Posted by Turd Fergusen View Post
    Perfect!
    mtbtires.com
    Does Zorro use these?
    Z (zarr)
    roccowt.
    rocnbikemeld
    Snowjnky McDreamy
    Reputation: snowjnky's Avatar
    . . . . . . .?. . . __. . . . . . . . . . . . . . . . . . . . :`. . . ./
    . . . . . . . /__.(. . .~-,_. . . . . . . . . . . . . . ,:`. . . .. ./
    . . . . . . /(_. . ~,_. . . ..~,_. . . . . . . . . .,:`. . . . _/
    . . . .. .{.._$;_. . .=,_. . . .-,_. . . ,.-~-,}, .~; /. .. .}
    . . .. . .((. . .*~_. . . .=-._. . .;,,./`. . / . . . ./. .. ../
    . . . . . .(. ..`=-,,. . . .`. . . . . . . . . . . ..(. . . ;_,,-
    . . . . . . \`~.*-,. . . . . . . . . . . . . . . . . ..|,./.....\,__
    ,,_. . . . . }.>-._\. . . . . . . . . . . . . . . . . .|. . . . . . ..`=~-,
    . .. `=~-,_\_. . . `\,. . . . . . . . . . . . . . . . .\
    . . . . . . . . . . . . . . . . `:,, . . . . . . . . . . . . . `\. . . . . . ..__
    . . . . . . . . . . . . . . . . . . . . _\. . . . . ._,-%. . . ..`
    Brother Seamus?
    Like an Irish monk?
    Comic relief in a discussion does no harm..
    CS Lewis
    Quadzilla
    Feb 2005
    Quote Originally Posted by morganfletcher View Post
    I like the curved better, you could do spiral cranks for ultimate leverage and cornering benefits.
    This is like trolling reality for money.
    Oct 2012
    Weird huh?
    Reputation: cmdrpiffle's Avatar
    Quote Originally Posted by Saul Lumikko View Post
    OMG I am so going to do this
    El Cid is Spanish for The Cid..
    cmdrpiffle 7 points 1 day ago
    Cinco de Mayo is Spanish for Cinco de Mayo
    Oct 2011
    Here you go
    1885 American Double Eagle
    - Boneshakers - Rideable Bicycle Replicas
    Or how about X cranks. Picture a double ended crank with a slot up the middle in which the pedal can slide from end to end. Then mount the cranks 90* offset so one side is like \ and the other side like /. Then as you push down with say the left foot, once you get down past 90*, you can start pushing down with the right foot. Then when the left foot bottoms out, lift the foot up, the pedal unlocks and slides up the slot in the now vertical crank arm and locks in at the top where you repeat the cycle. You end up with twice the down force on the pedals since two feet are pushing and you get twice the power strokes/revolution (4 instead of 2).
    Over it
    Jun 2010
    I've heard of this guy. His last company sold stereos. Their volume went all the way to 11.
    (rim shot)
    Nice e-bike! (sorry about your penis)
    The broken are the more evolved. Rejoice.
    Quote Originally Posted by dirtvert View Post
    (rim shot)
    No, no, no, no, no. Guitar amplifiers, not stereos.
    It's about showing up.
    Reputation: Berkeley Mike's Avatar
    Believing in this crank comes from failing to understand a basic principle.
    From Troll Scientist. com
    Attached Thumbnails Attached Thumbnails Z Shaped Cranks give you better leverage-115-hydro-powered-boat-troll-physics.png
    I don't rattle.
    Axe
    Axe is offline
    Custom User Title
    Reputation: Axe's Avatar
    You also need to combine it with a smaller rear wheel for better descending.
    That needs to be a sticky in the 29rs forum.
    Now, give him a chance, here. I think the Z crank just needs Bio Pace chainrings to work properly, is all. That will even out the increased torque into a a true constant application of power.
    Reputation: dsnow23's Avatar
    If they put a DW-Link at the angle, it would also reduce foot fatigue and increase pedaling efficiency. I don't know why that green GT doesn't have a springer seat to reduce the harshness of the ride. I guess some people are just masochists.
    Oct 2011
    Quote Originally Posted by jbt56 View Post
    Yes, do those B/P chain rings and don't forget to do the cryo-treatment on all the metal parts. And then use ceramic bearings on he bottom bracket with synthetic Teflon grease and you'll probably need to add a brake to the crank so you can stop it from spinning by itself so you can get your feet on the pedals!
    May 2005
    Well, its easy to laugh over this, but how about guy who avoided FSR patent by placing shock in upward direction and stating that "the force applied to the shock creates upward and forward momentum and helps to get front of the bike over the obstacles."
    Hint: his company in So Cal and his name is not Tony.
    I used to run tubes like you are, but then I got thorn in my wheel.
