• 11-21-2012
    Snfoilhat
    Originally Posted by francois View Post
    since we live in the Bay Area, I would suggest working on your pump track skills
    :eek:
    At whose house? What kind of beer do they like?;)
    /Since we live in the Bay Area, we can drive out of the Bay Area and ride Elk Grove, Aptos...........
  • 11-21-2012
    davidfrench
    Hi, I just joined the discussion.
    I'm in SF... and ready to ride!
    When, where?
  • 11-22-2012
    Yody
    Cornering Pop Quiz:
    Whats the different technique used in body positioning/cornering technique between these two corners
    Corner A: Tight radius, sharp corner, coming with with moderate speed, slightly bermed up, hard to see exit.
    Corner B: Wide Radius, swooping corner, coming off faster section, no berm, slightly off camber, can see see a little bit of exit
    How would you hit each corner and what would you do differently between the two?
  • 12-07-2012
    Yody
    Crickets
  • 12-07-2012
    mellowyellowCJ7
    A: I hit my head on the tree on the inside of the turn, because I slowed down too much and got more grip than I expected when I waited the inside bar, rotated my hips, looked for the corner exit and pulled on the outside bar on corner exit.
    B: I hit the bushes on the outside of the corner exit, because I carried too much speed, didn't wait the outside pedal, and low sided because I hadnít tried to evenly weight the tires and keep the bike more leaned over than my body.
  • 12-07-2012
    CSC
    A: rail that berm! Watching the pros, they tend to let their back wheel lock a bit to help with pivoting the bike through the turn without sacrificing much speed. Note: They are not locking their wheel before the turn and dragging it through the turn, but rather forcing it to break loose about halfway through the turn.
    I'd bet that a weighted outside pedal and rotated hips is enough...the berm soaks up a lot of the drifting potential.
    B: You could come into a turn like this with most of your original speed...just give yourself some space to slide as you exit. Since we can see the exit as we enter the turn, we can maintain speed. A more active, i.e centered and higher on the pedals, body position will allow you to react to any developing slides, as well as hold the bike through the turn.
    How 'bout this one: High speed off-camber straight with wet roots?
  • 12-07-2012
    gurp
    Gap the section :D
  • 12-07-2012
    shredchic
    Originally Posted by Yody View Post
    Cornering Pop Quiz:
    Well, for starters, in all situations: neutral position, looking toward the exit, get any braking done before the turn, not in the turn.
    Here are my guesses, given the details of each situation:
    A: pedals level (due to berm) - treat as slowspeed switchback, not high-speed cornering technique.
    B. outside pedal down (no berm) - swing wide before the turn, cut across the apex and swing wide out of the turn (due to off camber), lean hips toward outside, maybe countersteer (push down on inside handlebar)
    and of course ... Practice practice practice :) What would your suggestions be?
  • 12-07-2012
    CSC
    I'd still have my outer pedal down...no reason to switch up pedal tech through a sharp bermed-up turn.
    Mountain Bike Tips: How To Ride A Berm - YouTube
    Sweeping berms, yes, keep your feet level.
  • 12-07-2012
    shredchic
    Oh, ok - you just don't want to whack the berm with the pedal, of course. But if it's a very low berm, it should be ok.
  • 12-08-2012
    Yody
    you can ride a berm either way, but usually you don't need an outside pedal down. I still do it out of habit often.
  • 12-08-2012
    Yody
    Corner A I would stay slightly neutral on the bike, slightly biased foward, feet level. I would look for something to pump off of, scrub some speed and then pump the corner hard and quick, using whatever bit of real estate I can to push my front tire in, to change direction, looking for a quick turn and to boost exit speed, with maybe a pedal stroke out of it.
    Corner B I would come in hot and possibly a bit tight with my outside foot down, and crouch low with some weight over the front. Looking to carry momemntum through the corner. Looking through it pushing the bike into the turn, keeping body slightly upright. Leting the bike drift mid corner to exit.
  • 12-08-2012
    chris.george
    That was intentional bro. It's from my upcoming dvd.... seconds before disaster.
    part 2: mtbr bend oregon slalom course - YouTube
    fc
    Oh man. Thanks for sharing some of your crashes.
    I thought I was the only one who spilled out!
  • 12-16-2012
    Cobak04
    thanks for all the videos, super helpfull
  • 08-02-2014
    dustyduke22
    This is a great thread to bring back! Who doesn't need better cornering technique??!!! Tons of good vids and info.
    Thanks guys!
  • 08-02-2014
    iheartbicycles
    Welcome to norcal's cornering clinic
  • 08-02-2014
    fc
    Yep, this thread is very important, as evidenced by the Rider Down thread.
    This is the time to really focus on equipment and technique since confidence is high in mid-summer and conditions are the trickiest/****tiest.
    fc
  • 08-11-2015
    Gorn1120
    Originally Posted by fc View Post
    This is how ya do it. Lean on inside bar. Weight on outside foot. Torso and head forward into the turn. Eyes wayy up front.
    This is how not to do it.
    The reward
    http://www.facebook.com/v/10151005710903213
    I wanted to see the media with fixed links.
