Training for Kennedy
Ok. So I'm down in Dion's neck of the woods as I pretty much use STCP as my daily training ride, with multiple trips/laps up/down the hills. I see you guys tackling Kennedy on a regular basis. I realize that Kennedy is ~6m, and while STCP has no long trails, are there any trails in STCP that are similar to kennedy?
For example, if I did X laps of the radio tower climb starting at either the picnic area or the bottom of Bernal, how representative would that be? Or x number of trips up Boundary?
I could climb Quimby as well.. how does Kennedy compare to Quimby?
If you want to ride like Dion, one of the things you need to do to emulate his riding at Kennedy is to drop one of your gloves into the port-a-potty and mention it on MTBR.
Beyond that, I can't speak to Quimby. Kennedy is just a 4mi 2400ft slog. Best done with a dozen MTBR peeps.
Quimby would be similar to Kennedy in some ways. It is fairly steep and long and gets steeper towards before the top.
I can't friggin' believe somebody dug it out!!!!
Seth, just go ride it. Honestly. The worse that can happen is that you stop and take breaks, but there's no shame in that. Just think of Coyote Peak climb going on for a long time. I don't know if you tried Boundary climb at STCP, but there are some steep bastards like that in Kennedy.
Just go give it a try - we'll all go soon and you should hitch on with us. It's not as bad as some people make it out to be unless you're going for Strava times. Like Mr. Crustacean said, it's better to go with a group - because it ain't the most exciting place in the world.
So do any of you actually ride UP dogmeat when it's wet?
Guess you're getting it back then.
Rode up it no-dabs today, and it was sloppy/smooshy/icky in many places:
Of course I run 26"x3.8" Surly Nate tires, which have overkill traction available.
QUOTE from MTBR.COM: You have given out too much Reputation in the last 24 hours, try again later.
You would be surprised what ends up in the potty. Hash pipes ... watches ... panties ... even a pair of dentures after an untimely sneeze in there. Used almost half a bottle of his water to rinse them off before the ride.
You became weak loafing around in that big girly gear! -Soares
Ohhhhh, oh, ouch! walking away now...walking away
...You'll find me chugging a gallon of Pliny sooner than going hipstertard ~ Menso
Remind me again how much you mock me
I looked up at it a few days ago and folded....
Glad I put the 'mud spikes' on my new mtb shoes however
The key is to not look up at the Hill of Impending Doom™, and instead just look perhaps 6 feet in front of you, while you chant to yourself, “there is no hill”.
 Originally Posted by orthorex
Also, the line on the left is not always the best option.
I found both today and my last successful no-dabs attempt a few days before on my fatbike that at times riding right up the middle of the loose rocks/yucky stuff is the ideal line. Obviously not recommended on a normal bike.
Rode up it no-dabs today, and it was..
I've got serious work to do... and remind me to do it in clipless instead of flats....
I mostly went middle line today with no problems. I did however have my rear tire way low on air on purpose. Once you hit that tree, don't relax too much because it sucks to fail at that point after the harder stuff. Go slow and save some energy for the hard climb. I think this winter I have climbed it 4 times with 2 being successful no-dab efforts. Kennedy is hard but has nice rest spots to get Hr and breathing under control. Go ride it and get a base for the feel. Then build off of that.
They never made the "Slowster"
So do you guys just climb dogmeat or Kennedy Trail up, down dogmeat then back up? I am having trouble seeing direction on strava.
Only curious because a couple of days ago I did up Kennedy, down dogmeat to Alma Bridge, then came back up overgrown to dogmeat. And that's where I felt like I was dying.
Climbed Kennedy, went down dogmeat and then went right back up it. It was getting to cold at the top to do much more than that. Everyone was pumped for a dogmeat try anyway. Climbing overgrown (limekiln) then dogmeat is also tough. Dogmeat makes everyone feel like they are dying!
Seth, I have to work this morning, but if you want to give it a try later today or tomorrow, let me know. We can roll TSP style to pop your Kennedy cherry.
- You may not post replies
- You may not edit your posts
Forum Rules
