Results 1 to 13 of 13
    rjx
    rjx is offline
    Reputation: rjx's Avatar
    Rigid SS @ Wilder, Soquel, Alum Rock, Santa Teresa?
    I'm currently without a bike and I'm very close to buying a rigid SS.
    This will probably be my only MTB until next season.
    I'd like to start riding at places such as Santa Cruz, Alum Rock, Santa Teresa and other similar trails. I've never ridden on trails like these before.
    In your opinion, would a rigid SS be okay on trails like I've mentioned?
    Do any of you ride a rigid SS on these trails? This will be my first rigid SS.
    Thanks.
    Axe
    Axe is offline
    Custom User Title
    Reputation: Axe's Avatar
    Rigid, no, but with a reasonable gear most everything you mentioned (not sure what in SC) is ridable even by a weaker guy like myself. I would expect a rigid SS, especially 29er with nice big tires would be a blast.
    Rogue Exterminator
    Reputation: kjlued's Avatar
    I have seen guys ride rigid SS down some of the most insane stuff that full squish long travel guys don't even try. That being said, the answer is that it can be done but do you want to do it.
    Just stick it in granny and start grinding.
    You'll be fine if it is geared right. You might walk a few things here and there.
    Nearly everything in Santa Cruz is singlespeedable. Gear ratio, as others pointed out, is key.
    For me rigid means some beat up arms after some rides, but I'm a wuss in that regard
    Aside from some of the technical downhill trails around scruz, I've ridden my rigid cross bike on most stuff around here.
    Big old tubeless tires are your friend!
    Not at rocky ridge and stile at santa teresa. From the sound of it, you are a typical joe like most of us instead of a pro. You can do it but suspension will help alot. At least front suspension.
    Same goes for demo. There will always be a guy that tell you he can cut steak with a fork and spoon. But having the right tool is much more enjoyable. Riding down braille on a rigid is def not the best tool.
    As for single speed. Most places you mentioned can be done on ss. Is it enjoyable? Not really. There are better tools for the job.
    Over it
    Jun 2010
    ^^ Yep.
    I have a medium SS (hardtail) that you could try out for gearing. It has XT pedals or you could throw yours on. Also, I would add Saratoga Gap/Skyline trails and Fremont Older to your list. I've ridden most of the well known trails in SC on my SS, and it was fine--but it's just been gathering dust since I got my Ibis HD 6 months ago.
    Good luck--and sweet pics!
    Nice e-bike! (sorry about your penis)
    The broken are the more evolved. Rejoice.
    Reputation: borabora's Avatar
    Rode SC on my rigid Niner for two years and many thousands of miles. No problem if you are willing to take it easy on descents. My neighbor rides all these trails on a SS Reeb. I can't keep up with him up or down. That's not say that a HT or FS aren't more appropriate but it can be done rigid SS and will probably make you a better rider.
    Sent from my LG-E980 using Tapatalk
    Ariolimax columbianus
    Reputation: nativeson's Avatar
    Apr 2005
    mountain larry has been ridin sc rails on a ss road bike since the 80's......then again, that's larry. I've done it many times but I like gears. If it's all you got, run what you brought. Just ride.
    Reputation: Harry Mackenzie's Avatar
    I rode a hardtail SS all over Wilder and UCSC last year. I have since converted the bike back to rigid and mainly ride it in Wilder when I don't feel like messing with suspension and multiple gears.
    rjx
    rjx is offline
    Thank you for all the replies
    Though I might not be able to afford it anytime soon, sounds like I should consider a suspension fork and swap the rigid fork for the more demanding trails.
    Quote Originally Posted by dirtvert View Post
    Thank you for taking the time to check them out
    Quote Originally Posted by borabora View Post
    I don't want to kill myself, but I'd love to ride the Sierra Vista (Alum Rock) downhill at a moderate speed The videos I've seen make it look like it would be fun to zip down.
    fresh fish in stock...... SuperModerator
    Reputation: CHUM's Avatar
    Rigid is fine
    Longer fall line trails beat with breaking bumps will give you some forearm pump...but you get used to it (RR and stiles included)
    I wouldn't invest in a fork until you go out and beat yourself up a bit
    My .02
    Click Here for Forum Rules
  1. Alum Rock Park
    By plantguy in forum California - Norcal
    Last Post: 02-20-2013, 06:08 PM
  2. Alum Rock condition?
    By Loll in forum California - Norcal
    Last Post: 01-01-2013, 06:38 AM
  3. Replies: 37
    Last Post: 08-07-2012, 10:00 PM
  4. Alum Rock Codition?
    Last Post: 04-16-2012, 05:43 PM
  5. Santa Cruz Bikes Demo - 4/23 Santa Teresa Park
    By bikemerchant in forum California - Norcal
    Last Post: 04-25-2011, 10:02 AM
