    Reputation: skyno's Avatar
    Reverb issue - help!
    I'm cross-posting this on the Norcal forum b/c everybody here is so knowledgeable and helpful (flattery will get you everywhere):
    I am really hoping somebody can help me out with this Reverb issue:
    I wrecked with the seat post in the fully dropped (lowered) position and broke the hose barb off the remote. I purchased and installed a replacement barb, and watched the bleed video on the Sram website (I have successfully performed a bleed before & it wasn't a big deal). The problem is that the instructions say to perform the bleed with the post in the fully extended position, but I cannot figure out how to get it back to the fully extended position. When I extend the post manually, it contracts right back to the contracted position.
    Does anybody know how to get it to the extended position?
    Thanks in advanced!
    This might be worth a try. Take off saddle and rail clamps. Then depress the poppet valve in the top of the post. Little silver button down in there a few mm. I have not tried it but was told it works. Let us know
    Quote Originally Posted by Vaughn View Post
    Great advice Vaughn! - followed your instructions and it worked perfectly - I'm back in business with my Reverb working better than before my wreck + $7 fix - already had the fluid & you can get replacement barb on Amazon
    Reputation: Mt. Tam Haze's Avatar
    Also, i would use the Tech tuesday instructions on how to bleed a reverb from Pinkbike.com.
  1. My Saddle Issue May Fix Your Back Issue
    By Fleas in forum General Discussion
    Last Post: 07-18-2012, 06:17 AM
  2. Reverb help
    By denjen in forum All Mountain
    Last Post: 01-25-2012, 06:14 PM
  3. KS vs. RS Reverb
    By bicyclemark in forum All Mountain
    Last Post: 12-27-2011, 04:36 PM
  4. Reverb Nipple
    By scottishyard in forum SRAM
    Last Post: 12-12-2011, 03:31 AM
  5. Reverb from 31.6 to 30.9
    By Jingleman in forum SRAM
    Last Post: 02-17-2011, 09:09 AM
