Results 1 to 6 of 6
Thread: Point Reyes
    Point Reyes
    I'm going to Point Reyes for a few days. What are some good trails in the area?
    Air Pirate
    Reputation: Bokchoicowboy's Avatar
    Most of the wonderful trails in Point Reyes National Seashore are off limits to mountain bikes. There are several that you can ride that are decent, but the majority of good rides are actually outside of the Seashore itself.
    It also depends on what you will be doing. If you are riding with kids along, there are a few options in the National Seashore that are easy enough for your offspring to ride with you, such as the Coast Trail or the Bear Valley Trail. If you go to nearby Samuel P Taylor State Park there is the Cross Marin Trail running along a creek.
    If you are riding solo or with other adults or teens, then you have lots of options. If you want a ride that is not too far from the Seashore try the Bolinas Ridge Trail. You can combine it with several other trails to make a loop ride.
    Much of the area near Point Reyes has restriction on singletrack for mountain bikes, so you will mostly have to ride fire roads, which there is an abundance.
    For Mt. Tam Trails.
    For single track, going inland a bit is the excellent Tamarancho, or on the Bay is China Camp State Park.
    Locally for info, stop in at Black Mountain Cycles in Point Reyes Station.
    For some maps by the Parks Service check here:
    http://www.nps.gov/pore/planyourvisit/maps.htm
    If you want some good descriptions of some of the rides, check this website:
    http://pedaldamnit.blogspot.com/sear...8California%29
    Or even
    http://www.gatetrails.com/
    PDF's of some of the trails:
    http://www.marintrails.com/biking/biking/index.html
    Here is a PDF map from Marin County Bike Coalition:
    http://www.marinbike.org/Map/SideA.pdf
    aka baycat
    Reputation: Ryan G.'s Avatar
    Bolinas Ridge, 5 Brooks, Inverness Ridge and Drake's Estero are all good trails with incredible views.
    My gloves stink
    Reputation: Appendage's Avatar
    Olema Valley Trail
    I'm a fan of the Olema Valley Trail. There's something magical about it, and the variable terrain is interesting. Start at 5 Brooks stables and take OVT south. Out to the end and back is about 10 miles. You can also access Bolinas Ridge by taking Randall Trail or McCurdy Trail, both of which intersect with OVT. Randall is a tough climb and McCurdy is really tough.
    I dreamed I ate a 10 lb marshmallow. When I awoke, my pillow was gone.
    Mt Vision has a decent legal single/double track that is worth checking out..link in a ride out to Drakes Estero...
    Good job!
    Thanks for all the suggestions. I wasn't able to do as much riding as I would have liked (kids need attention) but I was able to check out the Drake's Estero area and had a great time. Makes me want to go out that way again without the family.
