Results 1 to 31 of 31
Thread: Point One
    Urban Ninja
    Reputation: jeng's Avatar
    Aug 2005
    Point One
    At the CCCX race this weekend, I ran into a couple of guys with a new product that I thought was kinda nifty so I decided to try it out. One of the companies founders is Jimmy Amaral, a Pro MTB racer. I liked the sleek design of this stem and the fact that it integrates the top cap with the stem. Why hasn't someone thought of that already?? Anywho, here is a couple of photo's of my new bling. It dropped almost 150-200g off my bike and I'm told this stem is 10g lighter than a Thompson 50mm and that doesn't take into account the weight saving of the top cap.
    The product might be available if you contact them. Check em out on the web at:
    http://www.pointoneracing.com/
    Urban Ninja
    Aug 2005
    Hey, somebody posted a mtbr review. I've had this stem on my Enduro now for several rides including a Moab trip and have had nothing but good luck with it. All other stems I've used have slipped on me at some point. I highly recommend it. And it's 40 to 50 grams lighter than a thompson I guess. Sweet!
    http://reviews.mtbr.com/blog/point-o...named-thomson/
    that's a pretty piece of hardware....i wonder when they will be able come out with more lengths and rises...
    Reputation: grrrah's Avatar
    the stem/top cap combo made a run a couple years ago. Not very successfull, but were primarily used by people that cut their steerer tube to low and needed a shorter profile stem. Other than that, they weren't that poplular.
    I forgot the name of it, therefore no pics.
    Capricious youth...
    Reputation: Prettym1k3's Avatar
    Looks a little week in certain areas with the two separate clamps.
    It's great looking though, and obviously light, but for now I'll stick to my tried-and-true Thomson 50mm.
    Meh.
    Urban Ninja
    Aug 2005
    Quote Originally Posted by Prettym1k3
    It looks weak but I think it's the design that makes it so strong. I'm about 200 lbs. I've got about 3 months of hard riding doing jumps and drops on this stem with no issue. There is definitely no flex in it. I wouldn't have changed except for the fact that I was considering upgrading to a Thompson and this came along and looked like a better alternative. So far, I'm happy.
    I just wanna go fast!
    Reputation: bdamschen's Avatar
    My girlfriend has one on her short travel bike, works well as long as you cut your steer tube to the exact length you need. As for strength, I've heard they were tested to be just as strong as a thompson x4 stem. I have no idea how that sort of testing goes on, but I do know tha Amaral rides pretty hard, so if they hold up for him, they'll hold up for me.
    Reputation: fawndog's Avatar
    Nov 2007
    Ian was talking it up with Jimmy, I heard them saying stems are tested for flex by long solid bars. I would buy one because Point 1 are local guys and the product is quality.
    not a forum admin
    Reputation: atomicAdam's Avatar
    hey folks - i did a pro-review on this stem just this week.
    check it out - leave your thoughts
    my measure was 40g lighter than a thomson x4 50mm and 50g lighter when a chris king head cap is included.
    i've got a video too on there too - but it is pretty tame riding. i tested this stem on my dh bike and my mtnX/slope style bike. i'm 230lbs and tend to break stuff quickly. i think this stem will hold for quite some time.
    -adam
    Reputation: ThePunisher's Avatar
    Feb 2006
    like grrah mentioned. that kind of stem is pretty limiting. I rather have a thu hole in mine and use spacers+cap. but that's just me
    I'm with Prettym1ke - definitely looks a bit brittle. there is more to a stem than weight. weight to strenght ratio or Thomson stems is pretty hard to beat.
    not a forum admin
    Quote Originally Posted by ThePunisher
    yes - you are correct in that for some this just wont work because of cutting the steerer tube down. but, if you're building a race bike...well...why would you want the extra weight of the excess steerer tube/head cap/ and spacers?
    Feb 2006
    Quote Originally Posted by atomicAdam
    well if someone is such a weight weenie, they could just use the cap (or some headlock) to preload the headset bearings, tighten the stem then remove the cap all togeather. you don't relly need it.
    Capricious youth...
    I'm with atomicAdam on this one. I cut all my forks down and never have more than 1 1/4" spacer on top of the stem.
    It just makes it pretty.
    Meh.
    not a forum admin
    yeah dude - they sure could - i've seen like how many ppl do that myself.....
    it's not for everyone
    Urban Ninja
    Aug 2005
    You might take a look at their site. They've posted the results from a Cal Poly Mechanical Engineering Department stiffness test. I'm guessing competitor A is a Thompson.
    http://www.pointoneracing.com/splits...s_tests_v7.pdf
    May 2005
    "Integrated" cap aside good to see another light stem coming up.
    Although I'm quite happy with 150g Hope DH stem.
    Also there is nice and inexpensive stem from Sunline (661) V-One All Mntn at 140g for 50mm.
    What I like on both (Hope and Sunline) is full sized front plate. Contact area with bar is larger and it allows for lower torq values, especially if using FSA paste with crabon bar.
    I used to run tubes like you are, but then I got thorn in my wheel.
    I LIKE that stem! that thing is sweet! I agree about the topcap.. I hate running spacers on top of the stem.. it looks like a stack of pancakes
    FYI- look at a thomson stem the faceplate is under cut in the middle so the actual bar contact areas are only in two spots- like the Po1nt stem.....Also, I found a stiffness test on their website.. it seems to be pretty good
    Just checked www.pointoneracing.com and the stems are available for pre-order... and I just couldnt resist so i snatched one up! I figure I will "Stimulate" the economy! Cant wait to slap that thing on!
    not a forum admin
    Quote Originally Posted by DH_Racer
    sweet dude - hope you like it as much as I do.
    Freetard.
    Reputation: Nut!'s Avatar
    Nov 2007
    Apparently they have a direct-mount version as well. sweet!
    Quote Originally Posted by Khemical
    Those cables on the Socom look flexy
    horn doggie
    Reputation: scooderdude's Avatar
    Sep 2004
    Great product, and quite bright, qualified people who are involved in product development.
    I've been testing a preproduction 50mm "Split-Second" stem on my Toro DH bike for ~2 months. It's beautifully made, beautifully conceived. And, as was mentioned, the prototypes went through both hands-on failure testing locally, as well as academic engineering/failure tests at Cal Poly. Sweet stuff, with glowing data. It's stiff at heck, and even lighter than one could imagine proper for a DH bike. I love it.
    I've also been BETA testing the new 70mm stem. It's a different design, but is equally stout. It too has gone through local testing to failure, with results used to tweak the CNC programs for the final prototypes. They haven't decided on a name, but a few of us are keen on the suggested name "Blunt". You'll see why once I post up the pics.
    Here's a picture of the Split-Second; I have none of the "Blunt", currently, but will post some up a bit later. If any questions, come to the races this weekend at Toro and see them in the flesh.
    Wanted:
    Potts, Potts, Potts
    horn doggie
    Sep 2004
    Here are the pictures of the prototype "Blunt", still showing grime and sweat stains from my race 2 weeks ago. Although you can't see it, the entire internal space of the "reach" part of the stem is a fully hollow cylinder. You could fit a pair of D-batteries end-to-end in there.....or your stash, for example. Hmmm.....
    This is a raw sample; production models are expected to be anodized black with laser etched logos. The face plates are nickel plated on this example, but aren't expected to be in production. I put the "1" from the company decal just to give it....something. The reach is 70mm. And the spacer under the stem, that spacer with concave face? That's also a Point 1 product, the lightest on the market. Tasty.
    Wanted:
    Potts, Potts, Potts
    not a forum admin
    Quote Originally Posted by scooderdude
    dude - where can i get a gold colored top cap bolt like you have??????
    its cool looking, but i think its a solution in search of a problem.
    My Stable:
    '08 Santa Cruz Nomad
    '07 Raleigh XXIX Rigid Singlespeed 29er
    horn doggie
    Sep 2004
    Quote Originally Posted by chris_nor_cal
    True. Kinda like all those bike designs that came in the decades following the success of the original klunkers on Mt. Tam. Good thing nobody ever thought to experiment with new ideas and designs, eh? What a waste of time that's proven to be.
    But seriously, it's just a new product from a local, young fabricator/designer that integrates a few nifty concepts resulting in cool looking stems that are both light AND strong, in fact, the lightest on the market, including the venerable Thompson. It's stronger, too.
    Wanted:
    Potts, Potts, Potts
    Urban Ninja
    Aug 2005
    True.
    Sup Scoot? How'd the race go yesterday? You gonna win that CCCX Series?
    Justin
    horn doggie
    Sep 2004
    Quote Originally Posted by jeng
    Justin
    I had a pretty good day, taking 1st in expert and 2nd in hardtail. I think Keith must have had to change a flat during his hardtail run, as I was just 1 second away from taking him! The course was uber fast, with a very tricky off-camber single-track section, as well as my favorite high speed rollers at the top - tuck and go, baby!
    I'm leading the series, currently, with 4 wins/6 races. But with double-points earned in the final, I could lose it if I don't win the final, too. It'll be close.
    BTW - Jimmy Amaral, owner of Point 1 Racing, had fast time of the day, and was his birthday!
    Wanted:
    Potts, Potts, Potts
    Urban Ninja
    Aug 2005
    Close my a$$. you beat 2nd place by 10 seconds and you beat all of the Expert 19-34 times!! I didn't know you were that fast man. When we went to Santa Barbara I could keep your wheel. Now I think you'd smoke me. Not too bad for an old lady.
    I saw that Jimmy killed it and beat Ian by 13 seconds. Did Ian crash or something?
    Groveland Trail Heads
    Reputation: scheckler's Avatar
    Jan 2005
    I was there also...
    a spectator for someone special who got 1st place in her first race What a nice event... great vibe and real nice people. I had a great time even though I was bike- less. The awards ceremony was pretty entertaining also.
    My beat box is bumpin' and my rhymes are fresh...
    www.grovelandtrailheads.org
    horn doggie
    Sep 2004
    Yep, he crashed. That's the only reason I beat Ian, too.
    Wanted:
    Potts, Potts, Potts
    not a forum admin
    split second DM review
    hey folks - just finished writing up a review of the split-second DM stem
    http://reviews.mtbr.com/blog/point-one-racing-split-second-dm-stem/
    very good strong light stem - very happy with it - and not as controversial as the other design.
    -adam
