Page 3 of 6 FirstFirst 123456 LastLast
Results 51 to 75 of 130
  1. #51
    Patrolium
    Reputation: Sorcerer's Avatar
    Anza/Grapevine Tree Action
    Hi,
    On Saturday May 26th 2012 while Plymmer took Ratpick, Fattire400 and I on a tour of the "Forgotten Ones" 10k my wife and a couple of riders spent nearly an hour cleaning up the area around the tree that has fallen by the intersection of Grapevine and Anza trails near the Wood Chopper Spring.
    Photos courtesy of the Mudskipper:
    You'll still have to crawl under the tree coming down from the Grapevine Trail. The work makes it possible to ride or hike the Anza - Coit Road without much bother. It would be possible to move the trail about four feet up hill to make the connection from Grapevine to Anza rideable. However, the maintenance staff has been notified, and perhaps this will be mitigated before too long.
    Photos courtesy of Super-Stoker:
    SOrCerer
  2. #52
    Patrolium
    A Couple on the 2nd Climb on Middle Ridge Trail
    Hi,
    On May 25th after the CPPF media event to hand-off the check to keep Henry W. Coe SP open, I went on a little ride to saw off some trees on the Middle Ridge Trail.
    SOrCerer
  3. #53
    Wow, nice work!
    So our conditions report became out of date while we were still on our ride!
    Now we just need to talk some immune person into clearing the poison oak on grapevine...
  4. #54
    Patrolium
    Tree Down at Flat Frog near Grand Junction
    Hi,
    Okay here's another big one that has been known about for a couple of months almost. Because of a busy schedule no one has been able to address this huge tree, yet. However on Friday May 25th the abundant lush garlands of poison oak vines were removed so that stooping under the massive fallen Valley Oak (and dragging a bike along) is now possible without risking exposure to poison oak.
    My before pictures:
    My after pictures:
    SOrCerer
  5. #55
    Medium?
    Reputation: Fast Eddy's Avatar
    Eric didn't want to try to tackle it with the chainsaw, nor did he want to improve the go-under by dropping the trail tread. IMO, this is the best and easiest solution to this issue. That tree isn't going anywhere without explosives or a helicopter, or a serious chainsaw crew with some time on their hands.
    Sorry about the quality of the cellphone pics.
    Attached Thumbnails Attached Thumbnails Pliny's "Tree Down at Henry W Coe SP" Contest.-06-02-12_1034_web.jpg
    Quote Originally Posted by Rumpfy
    So the guy likes hookers, who doesn't!(?)
  6. #56
    Medium?
    Instead of doing a bunch of chainsaw work, Eric trimmed up the roots where the trail went around and we improved the reroute. At least one group of hikers tried it out while we were there. Another group of bikers came by before we started working and went under without any trouble. I did manage to pull a McCleod under there and drop the tread a little.
    Attached Thumbnails Attached Thumbnails Pliny's "Tree Down at Henry W Coe SP" Contest.-06-02-12_1154_web.jpg
  7. #57
    Medium?
    Just a couple more...
    Attached Thumbnails Attached Thumbnails Pliny's "Tree Down at Henry W Coe SP" Contest.-06-02-12_1158_web.jpg
  8. #58
    middle ring single track
    Reputation: pliebenberg's Avatar
    Quote Originally Posted by Fast Eddy View Post
    Per the DPR Trails Handbook re-routing the trail is the right thing to do. The qualifying factor is a trunk diameter of 3' or greater. The logic is that a fallen tree is a natural feature and should be left alone unless safety is an issue. In this case re-routing above makes perfect sense.
    The views and opinions expressed here are those of the author and do not represent any policy of the CA Dept. of Parks & Rec.
  9. #59
    Patrolium
    Who will be first to clean the re-route on a bike?
    SOrCerer
  10. #60
    Medium?
    Quote Originally Posted by Sorcerer View Post
    The reroute is very soft and there are steps cut into soft dirt going around the north side of the tree roots. I would be sad if someone tried to ride it. Please take your wheeled locusts underneath the tree.
    I would not be sad at all if someone rerouted the trail 2' deeper under the tree and chain-sawed another foot of clearance around the hole. It could be made rideable and sustainable with a day of hard work if it could be approved.
  11. #61
    Patrolium
    Okay.
    The idea of rigging the tree and winching it off the hillside so that it would fall into the gulch was advanced earlier. That would be a risky operation with unpredictable results. Alternatively I wonder if it could be jacked (no triangle of death) up until it rolled, and repeated until moved below the trail?
    SOrCerer
  12. #62
    Medium?
    750 kg per cubic meter for oak (*). 1.5m avg diameter (conservative) * 3.14 * 8m = 28260 kg = 30 tons.
    You'd have to cut it into three pieces to pull it out with a SkyCrane.
    * Wood Densities
  13. #63
    Pies are square; nooo...
    * Wood Densities
    ...pies are round; cakes are square!
    Interesting 'rithamatic you use Eddy; I think you'll find your numbers are off by a bit on the high side. No matter; a Skycrane is well over $5K an hour so I don't think that'll happen considering the DPR's financials. Plus; it looks like if it was sectioned for lifting it would head down the hill anyway (problem solved).
    Hey I forgot to thank you for going out and helping Eric and crew!
  14. #64
    Medium?
    Quote Originally Posted by pliebenberg View Post
    So much for my expensive edumication.
    0.75 squared * 3.14 * 8m * 750 = 10600kg = 11 tons.
    I'll bet the wood would be worth an hour of skycrane time...
  15. #65
    Phegley Phreeway
    LocoYokel reported this last year I think.
    A narrow volunteer trail is well worn in below the tree now. It may damage the tree roots it skirts around eventually, so something will be done eventually.
    The photo is from Weds, 10/12.
    This tree is still there and since the bypass has become well bedded-in it will likely rot away before it's removed.
    More of interest though is that the DPR recently ran the grader all the way down Phegley Ridge Road; for the amount of use it gets it sort of seems like a waste---but for fire/public safety access I guess it makes sense. Here my son starts down the "wall":
    Photobucket
    Photobucket
    My daughter rolls out after descending the Phegley Wall. For thrill seekers this is probably the most rad wall in Coe given the steep/straight/length combo! (There are steeper ones but not this long with a clear roll-out) That grader operator has balls...
  16. #66
    loopy counter
    Reputation: knobs's Avatar
    Phegley Ridge Road
    If it is just the road, it's a not a huge concern. I don't think it required grading, but thanks for cutting the grass.
    Personally, I think Redfern is a better descent. It's got the views and the trees, and it's last section is insane. IIRC the Solstice ride is going up that.
  17. #67
    More pie please
    Reputation: Skyline35's Avatar
    May 2005
    First off, let me say "Thank you!" to the folks involved with the tree removals shown in the earlier posts in this thread
    For a few months now, there has been a large fallen Oak blocking Cattle Duster Trail near the top of Grapevine. The pedantic will know this is technically Coit Spring Trail but commonly it is thought of as Cattle Duster. Yesterday Roy and I set out to see if we could clear the trail. Here you see Roy and Kangasaw hard at work:
    I'm going to switch this around and show the "after" photo first. It was such a mess, maybe this will make more sense?
    Looking up hill, after:
    …before:
    From the opposite direction...after:
    And before:
    Here is the debris field showing how much was cut and removed:
    90 minutes work for two people.
    Roy checks the overhead clearance:
    Roy is the boss, graaaaahhhhhhhhhh
    We also cleared a nearby much smaller fallen tree. You'll be able to ride through here, no problem. Yay!
    ///Charlie
    Long live long rides
  18. #68
    More Torque
    Reputation: Diesel~'s Avatar
    Quote Originally Posted by Skyline35 View Post
    For a few months now, there has been a large fallen Oak blocking Cattle Duster Trail near the top of Grapevine. .....
    ///Charlie
    Awesome work guys. Thanks for the effort. That one was a huge pain in the ass to come across, in either direction.
    -D
  19. #69
    Medium?
    I have to take my due credit for making the 'before' version passable. Before 'before', people were climbing the bank to the north. I went through there the day before the VOCal trailwork.
    Great work on the 'after' version!
  20. #70
    More pie please
    May 2005
    Who needs a saw?
    Hi Paul,
    Do you think this one could be dragged off the road?
    Live Oak Spring Road at 37.142455 -121.4185967 (Sept 15, 2012)
    ///Charlie
  21. #71
    Absolutely!
    Hi Paul,
    ///Charlie
    Thanks Charlie! This may explain the shortage of water at Pacheco Camp if it has fallen across the pipe; did you see a wet spot in the vicinity?
    I'll pass this along to the proper Authorities (???)
    If Staff doesn't get to it first; there will be volunteers in the area with 4x4's 2 weekends in a row---first the UV "ride-a-long" training on 10/13 and then the TASPC work event on 10/20. One way or another I'm sure it'll get moved.
    This is a good segue to the new California State Parks Foundation website; About POP ---it's already been met with some skepticism within the MTBing community but I think it looks like a winner.
    I've been envisioning something much like it just for Coe but they've "beaten me to the punch"! I hope they expand it to include Coe soon.
  22. #72
    More pie please
    May 2005
    At the intersection of Grapevine and Anza:
    A Park maintenance truck would easily be able to drive up Grapevine Road to here.
    ///Charlie
    Fixed!
    Hi Paul,
    ///Charlie
    I saw that one has been cleared too. Yay!
    ///Charlie
  23. #73
    Patrolium
    Skyline, congratulations on the huge ride yesterday! You are amazing. Thanks for reporting the tree down on Live Oak. When I copied the post about it, I immediately forwarded the information to the Sector Maintenance Chief and the Coe Mountain Bike Patrol (I think I might have beaten Pliebenberg to it).
    It wasn't long before I received word that someone from staff would go out and pull it off the road. And so eventually it was removed.
    That's how things are supposed to work!
    MTBR is a great medium. Pliebenberg has done so much in his time volunteering with Henry W Coe. This thread is incredibly useful.
    The tree that was down at Anza and the Grapevine was reported at the last Coe trails meeting a couple of weeks ago, and must have resulted in it's removal.
    Good news: The huge tree which has fallen down on Flat Frog has been re-evaluated by staff and I heard that they have a plan to remove it by sections. It may sound like what Pliebenberg would've liked to do if they let volunteers operate powertools in the park. We might see it gone in two months.
    The Pliny tree down, and sign threads are useful. They really help and get things done. Please keep the reports coming. Don't hesitate to ask questions about status etc. as well. It helps to keep pressure on I think.
    For next weekend I have my saw's sights on a tree down on Bear Spring Trail.
    Again, thanks Skyline35, and good job on the 100k ride. You and the other heroes of this weekend are an inspiration.
    Now I know I need to make time in my life to prepare for the 2013 10k, ,100k, and 100 miles of Coe.
    SOrCerer
  24. #74
    More pie please
    May 2005
    Skyline, congratulations on the huge ride yesterday!...good job on the 100k ride. You and the other heroes of this weekend are an inspiration.
    Thank you!
    Paul, these rides are a continuation of an awesome culture which grew out of your annual Solstice rides. And I have no doubt that if you set your mind to it, you could complete the 100 miles.
    Thanks for all you do for Coe Park!
    ///Charlie
  25. #75
    Patrolium
    The Monterey District Trail Crew reported that they bucked the big tree fallen across the Flat Frog Trail today.
    SOrCerer
  1. Replies: 20
    Last Post: 02-25-2011, 06:59 AM
  2. Oak Tree Super "D" coming in 2010!! to Auburn
    By slowpoke69 in forum California - Norcal
    Last Post: 03-15-2010, 01:49 PM
  3. Replies: 4
    Last Post: 06-05-2009, 12:47 AM
  4. Alafia state park: "caution, tree down"
    By jahmic726 in forum Southeast - GA, TN, AL, FL
    Last Post: 07-03-2007, 05:54 AM
Hot Deals
Contests
Latest Mountain Bike Articles
