Results 1 to 48 of 48
    Moderator Moderator
    Reputation: 5k bike 50cent legs's Avatar
    Oct 2016
    Pedaling Innovations Catalyst??
    I ordered a pair out of curiosity. Anybody else use these beasts? Will they help get my ass up the Dogmeat Challenge?
    https://pedalinginnovations.com/
    Contains no juice.
    Nov 2003
    I have a pair of them and LOVE them. My size 14 feet have never been happier.
    I rode clipless forever, but that has all changed. I know there's scientific mumbo-jumbo about using them, but I don't care. They just feel good.
    At least you got a nice boat out of the deal.
    DJ Trump
    fc
    fc is online now
    head minion Administrator
    Reputation: fc's Avatar
    Aug 1996
    Quote Originally Posted by Finch Platte View Post
    You are flatties now Finch?? How long?what do you like about these?
    IPA will save America
    wretch
    Reputation: Truckee Trash's Avatar
    Theyre great. I ride them on my rigid mtb / bikepacking rig as well as occasionally on my full suspension. Really done wonders with my knee pains and fatigue on longer rides. Did the Grinduro with them and loved it. It is a little weird going back and forth to normal flats. Theres way to much marketing / science in their verbiage but in short they work exactly as advertised. I believe he did some work on the axles / bearing spec as mine have less than a year and are showing signs of wear.
    Air Pirate
    Reputation: Bokchoicowboy's Avatar
    At first sight of those I was put in mind of running boards on a pickup truck...
    Interesting concept and design. Any toe overlap? Pedal strike issues? How are these things with sprint climbs or climbing up steep angles? Any changes/issues/concerns with the knees with riding with this flat-foot method when you have been riding ball-over-spindle for your entire cycling life?
    "You're messing with my zen thing, man!"
    Contains no juice.
    Nov 2003
    Quote Originally Posted by fc View Post
    Catalyst Pedals/One Up 30T Oval Chainring
    DJ Trump
    orthonormal
    Reputation: andy f's Avatar
    I have a pair but I like my Deity TMacs better. One nice thing about the Catalysts is that since both your heel and forefoot are supported, you can wear a shoe with a more flexible sole.
    The glass is twice as large as it needs to be
    Moderator Moderator
    Oct 2016
    Quote Originally Posted by andy f View Post
    I have TMacs on my bike now. Will be an interesting comparison.
    I plan to buy set of the Catalyst Pedals when my new bike comes in. I recently decided to switch to flats and put on a old heavy pair of Azonics (618g) and noticed immediately a difference in power transfer just riding around in the parking lot.
    I'm a gym rat like Bike James - and the science makes sense. There's no way you can move 300-400 lbs of weight at the gym on the balls of your feet. Now if I able to apply 300-400 lbs of force on my bike pedals efficiently because I have larger platform to push from both the balls and heels of my feet - I AM going to get up the climb faster even if the pedals are 100-200g heavier than weenie pedals.
    Also as andy-f mentions above I also noticed even on the Azonics (which are big, but not as big as Catalyst) - I am quite comfortable and stable on flexible shoe like my rather minimalist flat cross trainers. They have a flat sole and grip well...with BOTH shoes weighing in at 536g TOTAL. That's going to save you anywhere from 150-400g compared to a pair of 5.10 and of course even more compared most stiff soled SPD shoes. NOT that most people care - but you net weight around your foot is going to be about the same if not a a bit lighter with the Catalyst vs. other pedal options.
    always licking the glass
    Reputation: stripes's Avatar
    Sep 2016
    I have these pedals. I've been going back and forth on them for a few years now.
    things to note:
    - I wear size 9-10 wide in men's shoes
    - I'm 5'4"
    - I have very flat feet (needed prescription orthodics to stop hurting).
    - I also have duck feet (flare outward)
    I have used them in the Bay Area, Colorado, and Moab. Everything from trail to DH to DJ. I have had them on my Ibis HD3, GG Shred Dogg, and Scott Gambler.
    Positives: they are wonderful for long climbs. They keep my arches from hurting. I have had no pedal strikes on them, except at Wilder Ranch in the gullies, but zero in Moab. On long DH rides, they are amazing. On technical riding, they're awesome because you have a lot more platform to move around the bike and a lot more control.
    Negatives: jumping and drops. The pins aren't long enough, so my feet slip a lot. I had an engineering friend of mine mod my two sets to have center pins, but that only goes so much.
    My other pedals are Straitline De Factos (I use these for DJ and DH primarily) and Straitline AMPs. I'm hoping when my second set of Rx orthodics come in, I can try other pedals, but I still like them.
    I just wish he'd put center pins and have options for longer pins.
    Moderator Moderator
    Oct 2016
    Quote Originally Posted by stripes View Post
    things to note:
    - I'm 5'4"
    You could always drill and tap a hole for center pins.
    Sep 2016
    Quote Originally Posted by 5k bike 50cent legs View Post
    Yes I already said that an engineering friend of mine did that.
    Guerrilla Gravity BAMF, Colorado Front Range
    Moderator Moderator
    Oct 2016
    Sep 2016
    You got issues, man. A little sensitive there. I was explaining what you missed. Not my problem you took it personally.
    Reputation: DriverB's Avatar
    Apr 2014
    God TMACs are so good....
    Flats are the best.
    Sent from my SAMSUNG-SM-G925A using Tapatalk
    Marin County, CA
    Moderator Moderator
    Oct 2016
    I was making a joke at my expense for missing your comment! It's all good!
    Sep 2016
    Oh ok. My bad. Carry on then
    orthonormal
    I think you'll miss the concave shape and superior grip of the TMacs. Too bad yours aren't green.
    Sep 2016
    What are the Tmacs? Im pedal-curious.
    orthonormal
    Deity Components Tyler McCaul signature pedal. Big platform, reasonably thin, and very convex. I knew I had a new favorite pedal from day one.
    Moderator Moderator
    Oct 2016
    Most of the paint on my pedals will be gone in a couple months anyway.
    I used a pair for RABGRAI this summer. Liked them a lot. But, I've used flats since I was 1967 or so, when I had a paper route. Everytime I clip in to my clipless, I fall down. I also use Well-Gos flats and 5-10s on my MTBs.
    I liked the Catalyst story. I have noticed over the years that when I get fatigued, I unconsciously shift my feet forward so that the arch is more centered, like the Catalyst guy says to position my feet.
    They are long. That doesn't bother me because they aren't as long as my feet, and I have small feet (8 1/2 wide). (You know what they say, "little feet, little shoes".)
    Whenever I order a "new" or small producer product, I order the spares. So I got the pedals and spare axles at the same time.
    Moderator Moderator
    Oct 2016
    Catalysts next to my TMacs. Will probably tap a set of center pins along the axle.
    Moderator Moderator
    Oct 2016
    First ride review: definitely a comfortable pedal. Seems to give me more power on the steep climbs. Will have to check my times of over the next few rides. Had a PR on a downhill section at Montebello today and didn't seem to be pushing it at all. Feel more 'into' the pedals with these on downhills, but I did pedal strike the shit out of one of them!
    Apr 2014
    That really puts the length of the catalyst into perspective given the TMACs are big platform flats
    Marin County, CA
    Air Pirate
    Okay, good legit stuff about these pedals...except my question on the leg dynamics...when one has been using pedals for many many years with the spindle under the ball of the foot does one experience anything different in the knee when pedaling on these things with the foot centered on the spindle? Knee issues are not a concern for some riders but a big concern for others.
    Quote Originally Posted by Bokchoicowboy View Post
    Are you riding SPD/clipless or flats right now?
    Although every person is different, in general moving from clipless > flat > large flat platform will see improvement in biomechanics and knee health. Bike James goes over it in detail on his website and manifesto, but this comes from basics of biodynamics of walking and squatting, which we DO NOT only use the balls or our feet.
    I'm in the middle of switching from clipless to flats are so far so good. I have had knee surgery 2 years ago and my knee is never going to 100%. Just this weekend, my knee was sore from a lot jumping and skip rope at the gym (this is an on the ball of your feet movement) - but I went for 2.5hr ride the next day on my flats with lots of climbing and guess what, my knee feels BETTER.
    I mean flat pedals and the Catalyst are worth a try even if you compare it cost of 1 or 2 visits with a Chiropractor or physiotherapist.
    Air Pirate
    Quote Originally Posted by smoothmoose View Post
    Great answer smoothmoose, thanks!
    fc
    fc is online now
    Aug 1996
    I heard these are manufactured by VP Components for this design. Axle can get loose with grimy conditions. Rebuildable and my bud has done it already.
    Hey - did you drill 2 extra holes and added pins there? Their website states and shows 12 pins, but I count 14 on your pedal.
    Moderator Moderator
    Oct 2016
    Nope, these are stock. I was thinking to do this but the traction for me has been fine so far.
    Cheesiest
    Reputation: intheways's Avatar
    After 2 knee surgeries in 2 years, I have been using them. The biomechanics make tons of sense. Great for the climbs, but the jury is still out on the downs. I get a fair amount of strike in rock gardens.
    Contains no juice.
    Nov 2003
    Another benefit is that you can hop on your bike anytime. The pedals give enough support that you could probably run the dog in flip- flops, if you were so inclined (cue Marx joke re: shooting an elephant in your pajamas).
    Great pedals to have if you've forgotten your riding shoes (never done that! Nope!).
    DJ Trump
    wretch
    I've done some longer all day rides with Chacos and even flops on these pedals - a big plus in my mind!
    Sep 2016
    Ok. Now that Ive put in the longer pins, these are the only pedals I ride. I like not having foot pain.
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    I need a 2nd pair of pedals. I love my 1ups but i like the idea of the longer platform and being able to just centering my foot on the pedal surface axle/arch.
    jrm
    jrm is offline
    lower your saddle a bit so that on the down stroke your toes arent pointing inward and down like with clipless.
    Contains no juice.
    Nov 2003
    Quote Originally Posted by jrm View Post
    You'll like them. Buy them, if you don't like them, I'll buy them from you.
    At a discount of course.
    DJ Trump
    Sep 2016
    They also have a 30 day return policy.
    Moderator Moderator
    Oct 2016
    I'm still loving mine. I definitely strike them more than other pedals, but that's just getting used to the clearance, my Santa Cruz HTLT has a very low BB to begin with.
    Oct 2014
    Quote Originally Posted by intheways View Post
    They are terrible for descending. I've had knee surgery too and don't see any benefit to these pedals besides adding weight to the bike. A standard flat pedal with a large platform works far better in all aspects.
    Moderator Moderator
    Oct 2016
    After a few months of pedaling on these I'm going back to my TMacs for awhile. These are great pedals and I feel like they have definitely improved my power and pedal stroke. Will be interesting to feel the difference with the TMacs. Switching back to get more grips for the spring/summer jumps.
    If anyone wants to try these out for awhile, shoot me a PM and you can pick them up at the 5k madhouse, for a trial period.
    wretch
    I've done the same - back to the Tmacs. I tried these on my Wreckoning and my Hardtail. I love them for bike packing and think they work very well for long days in the saddle. I do not think they have the grip or profile i'm looking for on a low BB full suspension trail bike. My wife has been riding them due to some hip and knee pain on her full suspension and they've improved all of that. She cares much less about the grip and tactile feel of the pedal and does not have the same pedal strike issues I have.
    Reputation: Whiptastic's Avatar
    Mar 2016
    Recently put these pedals on my Surly ECR 29+ touring/bikerpcking rig. Really like the out of saddle stability they provide and the ability to wear more walkable/hikeable shoes. Seems to increase out of saddle balance between handlebar and foot control dramatically. Like others have stated, long downs are a pleasure.
    The one area I would like to see changed or offered as an option is a slightly longer spindle between the inside pedal edge and the crank. Im getting a few shoe edge/heel hits/rubs on the crank arms (not the stays). My prior pedals are AEST Ti spindle flats and they are the same pedal width, but have about an 1/8 more spindle space from the crank. Has anyone else had this issue? Ive read some wide feet riders have outside edge foot roll and this may be from compensating for the short spindle to crank length by moving their foot outward.
    Id like to see Pedaling Innovations offer a replacement spindle that solves this problem for those that have it; big Clydes and wide feet riders sure could use it. Maybe on their first redesign upgrade they can add an ~1/8 to the spindle in this area and offer the new spindle as an upgrade for existing users.
    Other than that, I have noticed I vary my foot position from front to back with cadence; moving forward to a more traditional spindle location just behind the ball of my foot when winding up cadence. They do appear to add power on slow cadence climbs, but I find the out of saddle and light saddle climbing stability to be their biggest asset. Stability in spades.
    All said, I like them!
    eSurly ECR SA-5spd IGH (BBS02B)
    Niner Jet 9 Alloy 1X Sunrace 11-50T
    Soma B-Side Belt-Drive SA-3spd IGH
    Contains no juice.
    Nov 2003
    Funny, this is a review site, and not one mention of these pedals. I hope the new owners will fix the broken review section.
    Oh, but plenty of reviews of Casio watches, lol.
    DJ Trump
    Contains no juice.
    Nov 2003
    I'm trading my Catalyst pedals in for these.
    Bigger is better, right?
    DJ Trump
    WUT? Bigger is always better. What are those pedals?
    Contains no juice.
    Nov 2003
    I was in my local Performance and they had one of these on the floor. Massive pedal action!
    DJ Trump
  1. Replies: 0
    Last Post: 08-31-2015, 12:12 AM
  2. 1990's Parkpre 26" Catalyst mountain Bike, any info
    By cmugler in forum Vintage, Retro, Classic
    Last Post: 06-28-2013, 07:39 AM
  3. Brodie Catalyst
    By utahdog2003 in forum Vintage, Retro, Classic
    Last Post: 12-28-2012, 11:24 AM
  4. Brodie Catalyst
    By 118R3volution in forum Beginner's Corner
    Last Post: 04-27-2012, 06:04 AM
  5. Replies: 26
    Last Post: 11-28-2011, 04:57 PM
Members who have read this thread: 77
