Results 1 to 9 of 9
    Feb 2005
    jericho leadfoot gearing question
    i have a jericho leadfoot, and i want to change the gearing. i'm currently running 34/17. i originally wanted 34/18, but when i bought the bike the shop told me that gearing wouldn't work due, i guess, to the range of the EBB. the shop also told me that the next easiest gearing i could run is 36/19, if my memory is correct. does anyone know what gearing is possible? i would ask the shop, but it doesn't exist anymore. thanks.
    Reputation: oakhills's Avatar
    my leadfoot
    I run 34/18 gearing on my leadfoot, no problems here... That's the reason for the ebb, to adjust chain tension...
    fc
    fc is online now
    mtbr founder Administrator
    Reputation: fc's Avatar
    Aug 1996
    Quote Originally Posted by gordon
    If you have an older Jericho Leadfoot, the EBB was manufactured a bit small and it did not have the full range of adjustability to accomodate all gear combination.
    So if you have good tension with a 34/17, you couldn't run a 34/18 and tension the chain properly. You can run a 34/19 though. The solution to this is to get a BMX halflink chain which allows better chain length adjustment. Or change the front chainring.
    The newer Jerichos didn't have this problem.
    fc
    Feb 2005
    thanks francois. i pretty sure mine's an older one, i bought it in the beginning of 2002. what you say matches what the shop said at the time.
    Medium?
    Reputation: Fast Eddy's Avatar
    Quote Originally Posted by francois
    x 2
    Feb 2005
    would a halflink allow me to run 34/18? thanks.
    fc
    fc is online now
    Aug 1996
    Yup. It looks something like this. You can take out one link at a time instead of two on a normal chain.
    http://www.treefortbikes.com/226_333...in-Silver.html
    fc
    Medium?
    That's extra zooty, but for half that price you can get a normal bmx chain and one half link that will solve the problem just the same.
    Medium?
    That's extra zooty, but for half that price you can get a normal bmx chain and one half link that will solve the problem just the same, and if you search around some you'll be able to find a 7/16" half-link to make a normal 8 speed chain work.
