Results 1 to 6 of 6
Thread: Headset Help
    Sweater
    Reputation: Buzzaro's Avatar
    Headset Help
    Wasn't really sure what forum was appropriate but there seems to be a lot of knowledgeable, and occasionally helpful , folks in here. Does anyone know of a headset for the 44mm ID headtube that fits a 1 1/8" and also sits flush with the headtube? I've got one from Cane Creek that fits a 1 1/2" (or whatever size Cdales SI headtube is).
    I've emailed Cane Creek but haven't heard anything.
    Here's the visual:
    All out of S**** and down to my last F***
    Jan 2013
    Quote Originally Posted by Buzzaro View Post
    Here's the visual:
    You need a tool to measure, take ur own measurements and buy what you need.
    I just converted my bike to a tapered steerer fork with a cane creek bottom adapter to convert the lower 1 1/8th to 1.5 i had no listing, just measured out what i needed.
    Nov 2007
    Cane creek has a headset finder tool-->Headset Fit Finder
    rho
    rho is offline
    Life is strange
    Reputation: rho's Avatar
    This problem can be solved with any of the following:
    Lots of beer and researching on google.
    A pair of calipers. You can use the back end of em to measure depth...
    Or a hammer.
    Choose wisely!
    I'd go for the hammer my self.
    Sweater
    Headset Help
    Maybe I am asking the wrong question because I don't know enough to know the right question. I just don't know much about headsets at all. I've done some googling, but haven't gotten to beer or hammers yet. I used the cane creek headset finder, but couldn't tell if that headset was what I needed. Basically I'm trying to fit a Lefty fork with 163mm clamp spacing on a frame with a 160mm headtube.
    I believe the frame to be an integrated headset (Scott Aspect 30). Do all integrated headsets sit flush with the headtube the way the one in picture does?
    I believe you are looking for is referred to as an inset headset.
    With that beig said, I don't know if a regular inset will work for you.
    When in doubt call the King of headsets: Chris King
  1. Replies: 6
    Last Post: 11-19-2012, 04:58 PM
  2. rz140 headset? headset confusion?
    By akiracornell in forum Cannondale
    Last Post: 09-21-2012, 06:41 PM
  3. Replies: 15
    Last Post: 10-03-2011, 11:41 AM
  4. Threadless headset and Integrated headset?
    By ricky916 in forum Bike and Frame discussion
    Last Post: 07-24-2011, 12:07 PM
  5. 1.5 inch headset reducer shims vs. "full" reducer headset
    By pfcnguyen in forum Downhill - Freeride
    Last Post: 03-21-2011, 11:55 AM
