Results 1 to 11 of 11
    Front Tire Shakes When Braking
    Just got a tune up at a shop, but now when I use my front brakes the front tire shakes.What's with that? It rides smooth. It just shakes when applying the front brakes. The tire is on properly and doesn't wiggle while riding.
    A spotless bike is a bored bike.
    Fat Skis/Fat Tires
    Reputation: rangerbait's Avatar
    Quote Originally Posted by pacing08
    Disc brakes or rim?
    Reputation: cantonkiddo's Avatar
    The only time that happened to me, it was when my tire was flat, but you said the tires were fine so I don't know.
    TLL
    TLL is offline
    Reputation: TLL's Avatar
    Brand of brakes, size of rotor, tire? More info needed. PS, try the brake forum.
    Hadley rear hub service here and here.
    bike buster
    Reputation: jdubsl2's Avatar
    Feb 2006
    If your brakes were fine before the 'tune-up' ... wouldn't it make the most sense to return to the shop that did the work so they can correct the problem rather than speculate on a message board about what could be wrong?
    headset adjustment?
    Contains no juice.
    Nov 2003
    If they're disc brakes, throw some dirt on the rotors. They could be too clean and grabbing.
    You know not to touch (or get oil on) the rotors, right?
    fp
    What's the difference between red and green?
    Apparently nothing if you’re on a bike.
    Paper or plastic?
    Reputation: zorg's Avatar
    Maybe the rotors are ticklish?
    Disclaimer: I'm not a mechanic and I don't play one on the web either.
    Faster is not always better, but it's always more fun
    do you have those fashionable wavy rotors? as cool as those look they can cause pulsing in the braking force. It can make the front end shake.
    It could be after a tune-up your brakes are working better, better enough to make this noticeable.
    If that's the case the shaking will be more noticeable at slower speeds. The braking starts the whole bike rattling. It's not really a brake problem, it's basically the whole bike, in particular fork, front end of the frame, wheel, and your body mass.
    The braking force just provides some energy to make the whole bike wiggle.
    Things to change
    Fireball in the Night
    Reputation: Rex_Skidmore's Avatar
    Mar 2006
    Brakequake?
    everyone drives a Used Car
    Flying Goat
    Reputation: mrpercussive's Avatar
    loose QR axle???
