Results 1 to 10 of 10
    Fork leaking oil?
    So, I had a good 20 mile ride yesterday on my new-to-me Stumpy 29er. At the end of the ride I found juice coming out of the fork. Is this normal? I was riding on the pleasanton ridge, which was kinda harsh on the bike than usual due to storm damage.
    bike buster
    Reputation: jdubsl2's Avatar
    Feb 2006
    Yup, Fox forks do that.
    You could (and should, regularly) change the oil and replace the seals... but don't confuse that with 'new seals won't leak.' Just the way it is from my experience. If it's been serviced recently, just wipe it off - no big deal. Just be mindful that low oil levels could damage the fork so if it starts spewing oil every ride, change the seals and oil. It's real easy.
    aka dan51
    Reputation: d-bug's Avatar
    Mar 2005
    If you're going to replace the seals and wipers use either ones from Rock Shox or Enduro Fork seals. www.enduroforkseals.com
    It's "normal", but a fork puking oil should never be considered normal.
    Reputation: peletonnissen's Avatar
    Your fork is indeed leaking oil and is due for an overhaul (wiper and oil replacement). I would not recommend the Enduro seals myself, as the dust wiper creates additional seal friction and could potentially lock in hard objects that could damage your fork's coating, not to mention that using them voids Fox's warranty. Also, if you were say a racer and this happened at an event that fox was in attendance at, and you wandered over to their booth in search of some help, and you had Enduro seals installed, they wouldn't help you at all. Just a quick advise from someone who has been servicing half a dozen forks a week for the past 14 years. Good luck!
    Ibis Cycles
    www.ibiscycles.com
    used to be RipRoar
    Reputation: TraxFactory's Avatar
    Sep 1999
    Blown for seals happen. Check your stanchions for any damage as well that may have gauged the seal. Perfect opportunity to service your forks like peletonnissen mentioned.
    Also, good opportunity to get to know your forks. Servicing them is not that difficult if you have slight mechanical skills.
    ballbuster
    Reputation: pimpbot's Avatar
    Listen to the man
    Quote Originally Posted by peletonnissen
    Pelesumthin is the fork mastah.
    I found my my older Duke and Reba forks that sometimes gunk just gets under the wiper seal, holds the lip open and lets the oil seep out. I ride in mucky conditions all the time.
    I found I could just drop the lowers (clean conditions rule applies), clean out the seal and slap it back together (with new bushing lube oil) as a quick and dirty fix and I would be good for another six months. The process would take me like 15 minutes.
    Thanks for all the info guys. Never done a fork job before, and don't even know what some of you are saying (wipers), would you suggest any DIY manuals?
    Feel free to use the Fox service site: www.service.foxracingshox.com
    They have great videos and images up there with full tutorials on their equipment. Although this service is not the most difficult repair for a bicycle out there, it still can be challenging to someone who is not familiar with the internals of a fork, or what to look for when servicing a fork. Also there is the issue of purchasing oil, and disposing of your old oil. For those reasons it may be advantageous to bring your fork/bike into a shop. Generally your local shop (if they service fox forks) can have a much shorter lead time than sending it into fox, will charge less than fox, and can save you shipping costs both directions. Shops have the right oil and will only charge you for what you need, plus they can deal with the clean up. Good luck!
    Ibis Cycles
    www.ibiscycles.com
    Master of None
    Reputation: presslab's Avatar
    A really cheesy way to clean your fork seals is to put one wrap of masking tape on the stanchion just above the seal. Gently compress the fork to push the tape under the seal and pull it out. See all that dirt on the tape?
    Works for me. If you lost a lot of lube you should drain and refill the lower.
    Quote Originally Posted by presslab
    This fork needs a wiper/seal replacement as well as an oil change. No quick fix for this situation. Good luck!
    Ibis Cycles
    www.ibiscycles.com
