Results 1 to 14 of 14
    Eldridge Grade Sabotage
    Came across this piece of rebar pounded down right in the center of the tire line on Eldridge Grade (below the Northside Trial entry)...took a bit of pulling on it but it came up.
    Be careful out there, it seems as though MV (or his ilk) is now focusing on areas beyond his own backyard?
    Eldridge Grade Sabotage-0804021143c.jpg..
    That's an old school C-Bak right there
    Reputation: KevXR's Avatar
    Feb 2012
    I would have informed Mr Ranger and let them remove it.
    Around Mt Tam, it's the HOHAs. Hateful Old Hikers Association.
    Someone put up bobby traps on Hoo-koo-e-koo, but that was over 15 years ago. I won't say what was used, but it gave my friend two flat tires on fairly fast section.
    Formerly dvo
    Reputation: mtbrdan's Avatar
    You would really leave a boobytrap in place? How about remove it and forward the photos to the rangers?
    Reputation: Fairfaxian's Avatar
    Dec 2004
    Calm down, not sabotage. Just an ancient piece of rebar. Was commonly used on trails long before bikes were. We used plenty of it in Tamarancho. There's enough of REAL drama to worry about. (by the age of your camelbak, I'm thinking you've been at this for awhile, and should know this
    I like to bike.
    PokeyOne
    Doubt that is a booby trap.
    A great many years ago E-Grade had water bars placed on it to maintain the trail. Super cool ones. 2x8 pressure treated planks sunk into the ground and anchored in place with rebar and a thick piece of rubber across the top to allow a bike to roll over. They worked really well,took a ton of work to install, and lasted about 2 seasons at the most.
    That's just old rebar coming out of an eroding trail, not "sabotage" - geez! You find those on trails all over the place.
    edit: a big thumbs up for removing it, most don't bother trying to tackle a hard but needed task like that!!
    Reputation: Passenger13's Avatar
    Thx for pulling that rebar out so that no one hit it
    "Time won't leave me as I am "
    Funny, I have the same camel bak with the Rancho pass in the same location. I even have the same valve on my tube. Did I post this after smoking a bowl and forget?
    Sent from my Nexus 7 using Tapatalk 2
    VRC Illuminati
    Reputation: Rumpfy's Avatar
    I have the same C-Bak...I don't see what the problem is here.
    -eric-
    http://www.rumpfy.com
    booby!
    Reputation: *Matt*'s Avatar
    Aug 2010
    ^^ How's that a booby trap ... They have boobs and they have vaginas.
    The picture below ... that's a booby trap. Yes, that's a man!!!!
    This thread has evolved interestingly.....
