Results 1 to 38 of 38
    Reputation: GuruAtma's Avatar
    dumb hitch rack question
    So after hitting my carport yet again with a bike on the roof of my car, I've decided to get a hitch rack. For the record, the Yakima High Roller rack worked fine and it broke on impact, which saved the carbon road bike, so that's good.
    I need to get a trailer hitch receiver for my Subaru. Is this something I can put on easily myself? Go to the dealer? Go to a muffler shop? Do I need to go to "Trailer Hitch Receiver Review.com" to find the best one, or are they all about the same?
    Gracias
    功夫大师喜欢骑着他的自行车在山上。
    Jun 2012
    Uhaul. I've never found it cheaper.
    Reputation: Bald_Ben's Avatar
    May 2005
    Uhaul or similar. Cheap, fast, sturdy. Just make sure to get 2" instead of 1 1/4" if it will fit on your vehicle.
    xls
    xls is offline
    Eduardo Naranja
    Reputation: xls's Avatar
    It depends on which Subaru you have. Some can be more difficult to get a hitch mounted. I have an Outback POS and ordered a 2" hitch from etrailer. It was very easy to put on. According to internet rumors a lot of hitches from different brands are manufactured by the same company and just labeled with the brand's sticker.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    1.125 is fine. Unless you have a big truck, you don't want to be putting 4 bikes on the back anyway, as it will cause the rear to sag way low and the front to be way high.
    Some hitches are easy to put on, some are a pain and require some modifications. The one I put on my camaro took an honest 30 min and was easy as heck, the one on my subaru took a little more work due to the exhaust and some other stuff. Uhaul is a good idea.
    May 2005
    True re: the 4 bikes. If you ever want to tow a small trailer, a 2" gives you more options. There are no advantages to 1 1/4".
    xls
    xls is offline
    Eduardo Naranja
    1 1/4" is fine, but 2" is better, if you can get it, even for mounting a hitch rack. Just don't think your Subaru is suddenly a class III towing vehicle. And I agree with the advice against 4 bikes.
    Feb 2007
    The 1 1/4" you will be stuck with getting a hitchrack they holds the bikes from their toptube if you want to carry more than 2 bikes.
    If you only want to carry 2 bikes, then you can find a 2 bike platform that works with the 1 1/4", otherwise you will need 2" for a 4 bike platform but then again I doubt the Subaru is rated for this.
    I got my hitch from Uhaul and had them install it on my Ford Focus, I got the Yakima Doubledown 4. I've only had 3 bikes on it and it works fine. Although a platform would be nice but more money and harder to store in my small apartment
    Berkeley Bicycle Club (BBC) - http://berkeleybike.org
    Old,slow,still havin fun.
    Reputation: fgiraffe's Avatar
    I just had a 1 1/4 receiver hitch put on my Jetta by Eyers in San Jose. Trailer Hitches - Eyers Hitch Center Inc., the Trailer Hitch Experts, located in Santa Clara CA.
    I don't have access to ramps or a lift so I just left the pros do it. Took one day for them to order it, 45 mins for them to install, easy peasy.
    Dec 2004
    I bought a Curt Class III 2" receiver hitch from Amazon for $112. Uhaul sells Curt hitches. Put it on myself (I have a 2011 Forester) in about 45 minutes. Of course, the Forester has high ground clearance and I didn't need to jack it up. I only haul 2 bikes but I wanted the versatility of the 2" receiver. The Forester is very limited as to tongue weight (200lbs) and trailer weight but the class III will NOT bend when hitting bumps on forest service roads. I'd be worried some about a Class II hitch. Go with the Curt Class III if it fits on your Subaru.
    Thanks for all the info. I'll check out uhaul this week.
    功夫大师喜欢骑着他的自行车在山上。
    Reputation: sfgiantsfan's Avatar
    Dec 2010
    I got my hitch from e-trailer, it is a curt 2". I have a Tuareg and the only way to put it on is to remove the bumber and to do that I had to remove the tailights. I didn't trust U-haul but took it to a local body shop because I figured they had the most experience with removing all that stuff. they finished it in 45 min and washed my car for me
    I'm sick of all the Irish stereotypes, as soon as I finish this beer I"m punching someone
    Slowest Rider
    Reputation: BigLarry's Avatar
    Like others say, get the strongest class hitch you can find for your car. Get a 2" receiver if at all possible - they're much stronger with more options.
    Your bike and rack are a lot less weight than a 2000 lb trailer. But the trailer only puts 10% or 15% of the weight on the receiver, or ~200 lbs. And that weight is up close to the hitch. The bikes and long rack stick out longer and put much greater torque from the long lever arm - many times greater than a trailer. And if you ever go to 4 bikes, which may not be possible with your car, you'll get a lot of droop and scraping on driveways even with the strongest hitch.
    My 4-bike rack actually cracked my car's unibody sheet metal frame from the stress. I had my car frame fixed and reinforced with 1/4" thick steel plates welded on the surface. I also had my Class III hitch cut up and reworked to make it twice as stiff with cross beams, as well as tilt up a few degrees more for clearance. Now my bikes don't droop and stay free of driveways and don't wobble while driving.
    Good hitches can be found at etrailer.com. Installation can be as simple as a couple bolts, or a nightmare. I've had both. Look at the installation instructions and videos to decide. On one car, I had to hacksaw a few items at a bad angle among other issues which took hours to install, and the hitch fit was poor, and is what ultimately caused my frame to crack along with the high torque. If I'd had a professional installation, I'd have recourse.
    These days I use Rack N Road. They've been able to handle unusual problems, like installing my roof rack without having the proper landing. And they can help with all other needs like cargo boxes and bike racks and locks with a common key for all. But I've had success with others such as U-Haul to just install the hitch.
    My frame ripped from the receiver hitch. This is the right hand side - the rear bumper is on the right.
    With welded plates to fix and reinforce:
    It's not slow, it's doing more MTB time.
    rox
    rox is offline
    on a subaru the factory hitch is far superior to the aftermarket receivers. the subaru one will replace the stock bumper beam which results in a much cleaner looking install and minimal additional weight.
    I had the Subaru towbar, worked well.
    Reputation: wsmac's Avatar
    When I was researching hitches and racks for my Prius, I went to a Prius-specific forum and found a number of folks passing on their personal experiences.
    This was great because it was all Prius only.
    I imagine there are Subaru forums around too?
    But... seeing as how Subarus seem to be favored by MTBers, I figure you might find plenty of personal experience here as well.
    I have put hitches on myself and used UHaul... and my experiences with both have been good ones.
    Just a note... with the Prius, there was some issue regarding certain hitch manufacturers and how their hitches required some body mod because of the exhaust.
    I found out there was a manufacturer (one of the regular, large ones) who made a hitch that did not require any mods and my local UHaul had that one in stock.
    Reputation: KevXR's Avatar
    Feb 2012
    Things to look for in a rack.
    Tailgate access!
    I put a bicycle rack on the back of my truck, then I found out that I had to unload the bike, remove the rack, then get into the back of my camper shell. Some of the newer racks can tilt out to access the back of a car or truck. My solution was to put a bike rack on the front of my truck.
    Anti-Rocking Anti-Tilt
    I'm sure many of the new racks have a built in "rock lock" or "anti tilt" device. I haul a 270 lb motorcycle on the back of my truck and keeping it from rocking was a bit of effort. I bought one of these on eBay for $19.99 (usually 29.99). Best $20 I've spent in a long time. Works great.
    agree with the others, just have uhaul install the hitch and you should be good to go.
    Nov 2007
    Not sure which Subaru you have but try to get the highest class hitch you can get. I recently installed a class I hitch on my 02 WRX because that's the only one they make and it's scary trying to carry 2 bikes on a Yakima stick-up. When the rack is mounted on the hitch I can lean on the rack and see the receiver flex!
    Reputation: ratpick's Avatar
    Quote Originally Posted by rox View Post
    I'm looking at getting a hitch for my new Outback and have done a bit of research. The factory hitch is very superior - has many more mounting points and requires no drilling to install (IIRC). I didn't chose it because it's twice the price and I'm not ever planning on towing and the install requires removing many more parts (which is probably why it's a $695 dealer option at purchase).
    I had an appointment with RackNRoad to install a hitch on Saturday but they didn't get to me because they got behind trying to pull apart an Audi Q7 (Audis are apparently a nightmare to disassemble). The guy (WIll) in the San Carlos shop seemed to really know his stuff so earned my trust.
    Most of the aftermarket hitches seem to be a fairly easy self-install - etrailer.com has some great videos customized for specific car models - I'd rather leave messing with the car to professionals so I'm opting to pay for the install.
    BTW, RackNRoad quoted $120 labor on the install.
    Blargen
    Reputation: PACS's Avatar
    Jun 2010
    Bought a Curt class III 2" hitch from etrailer.com last week. Total shipped was $150. Installed in 30 minutes (4 bolts) on my SUV. Rack and Road quoted $300 out the door, "on sale". Put the saved $150 into a better rack...and beer.
    Moderator Moderator
    I found a youtube installation video for the Curt hitch for my wife's make and year of car. It was stupid simple so I just ordered the hitch and installed it myself. I would have spent more time driving to the uhaul place. Do some searching and see how big a deal it is in your specific circumstance.
    heaven help me
    Quote Originally Posted by sfgiantsfan View Post
    sfgiantsfan,
    Dude ,
    Touareg's are a beast. I drove down to San Diego with my buddy who has one and he was pulling a 19' Airstream. He got pulled over for doing 90 mph on I-5. I swear I could not feel the trailer.
    Dec 2010
    Dude ,
    Touareg's are a beast. I drove down to San Diego with my buddy who has one and he was pulling a 19' Airstream. He got pulled over for doing 90 mph on I-5. I swear I could not feel the trailer.[/QUOTE]
    Yeah it's a lot of fun, one of the fastest cars I've driven once it gets going, great off road too. Gas sucks and maintenance really sucks but I love itdumb hitch rack question-imageuploadedbytapatalk1339481288.925066.jpgdumb hitch rack question-imageuploadedbytapatalk1339481312.153892.jpg
    Crazed Country Rebel
    Reputation: iheartbicycles's Avatar
    Quote Originally Posted by GuruAtma View Post
    Gracias
    Still trying to figure out which part of your question is dumb...?
    Stupid, but sometimes witty. Occasionally brilliant. Slow and fat though.
    Mike Vandeman Sucks Dong
    Dude ,
    Yeah it's a lot of fun, one of the fastest cars I've driven once it gets going, great off road too. Gas sucks and maintenance really sucks but I love itClick image for larger version.
ID:	703293Click image for larger version.
    Dude, Kuats are expensive! I ended up buying a used Thule T2 off craigslist...
    ballbuster
    Reputation: pimpbot's Avatar
    regarding pulling the bumper.....
    Not unlike my MK3 GTi. I had to remove the bumper to install the bolts that hold the hitch on. It was actually easier than it sounds. Just 4 big bolts, a couple of clips that hold the bumper cover on, and the whole works just slides off.
    IMO, the 1Up rack is the best out there. Best rack I've owned by far.
    May 2012
    I second the DIY method....it was stupid easy and only took me 45 minutes. Look for the Youtube install videos for your model car.
    I got a Curt hitch for my Mazda 3 from Amazon for $130, no tax and free 2 day shipping (Prime Trial membership). I could not be happier with the $$ I saved plus the satisfaction of doing it myself :-)
    You will need a Torque wrench and some ramps if you go this route unless your car has some clearance in the rear.....you won't need much.
    Good Luck.....you will LOVE your new hitch rack!!
    Hi.
    Reputation: jtmartino's Avatar
    I had to drill holes in my car's frame to install my hitch. I did everything myself and it was a bit of a PITA, but doable.
    Quote Originally Posted by pimpbot View Post
    I just ordered the 1Up rack, based on all the good reviews here on MTBR. (I made sure to credit mtbr on my order).
    Is there a built in way to lock the bike to the rack, or do you just leave a cable and lock in the car?
    功夫大师喜欢骑着他的自行车在山上。
    Dec 2004
    Quote Originally Posted by BigLarry View Post
    WOW! This is EXACTLY what I was worried about when I installed mine. The "frame" is barely more than a little thin sheetmetal. I went with the 1UP USA single bike rack (since 99% of the time I only carry 1 bike and the 1UP only weighs like 28lbs) but I do have the add-on as well that I can put on to carry two bikes. I didn't even want to consider thinking about 4 bikes back there for this reason. I've also heard of 4bike racks mounted to hitches on trucks (which have massively strong frame rails - not the unibody sheet metal of our cars) and the weak link is the hitch itself. They will bend and elongate when bounced around on a forest service type road.
    Feb 2012
    I worked in a welding / hitch shop for a summer. You might check where various brands of hitches are mounted. Frame or sheet metal. If Subaru has a factory one, it's worth looking at where they mount it. Then see if another brand uses the same attachment points.
    We made a custom light ball hitch for my Datsun 510. Two bolts went into the bumper. Two bolts went into the sheet metal of the trunk area. On the inside, we put a large steel plate to spread out the load on the sheet metal.
    ballbuster
    Yeah, no cables on this one. Built-in rack cables suck anyway.
    I use a disc type lock around my hitch receiver, to a big fatty hardened chain through a U-Lock around my frame and rear wheel.
    Dec 2004
    posted in wrong place ... ignore
    Dec 2004
    The Subaru OEM hitch mounts differently than all the aftermarket hitches. The aftermarkets mount only to the frame (see Larry's pic above) but the Subie one mounts there PLUS they remove the original bumper support bar and the hitch becomes the bumper support (and there are an additional 4 more bolting points). I didn't go with it since I'm never going to tow and only put two bikes back there and, the biggie, the OEM cost over $350 vs $112 for the aftermarket. I should probably scour the boneyards for a OEM hitch and sell my aftermarket.
    Feb 2012
    Quote Originally Posted by campisi View Post
    I am not surprised, which is why I said to look at the OEM hitch and compare. Sometimes aftermarket is focused on speed of installation vs strength of mounting points. However, you really need to look at what is on the bumper rack. Bicycles vs Motorcycles.
    Feb 2012
    My own solution. I turned a "bumper thumper" (front guard) into a bumper rack / bug deflector.
    Dec 2004
    Quote Originally Posted by KevXR View Post
    My big plan originally was to use the hitch to transport one of my motorcycles. But that was before I learned about hitches and racks and load ratings etc. I knew I wouldn't be able to transport my XR250 on the hitch (even though it's a comparatively light bike) but I thought for sure I'd be able to transport my CR80/XR100 conversion bike as it only weighs 150lbs. After researching and putting on the hitch there is NO CHANCE I'd even try the lighter bike. It would tear the rear of my Forester to hell. I'll have to get a utility trailer. The hitch rack is strictly for one or two bicycle duty. The Forester replaced my Dodge Ram 1500
