Results 1 to 17 of 17
Thread: Bike Wrench
    Reputation: GuruAtma's Avatar
    Bike Wrench
    On my commuter/cargo bike the back wheel is held on by 19mm nuts and the front wheel by 15mm nuts. I can't use an adjustable wrench on the back wheel because of the way the frame and derailleur crowd the nut. So that means I have to carry two big box wrenches with me if I want to change a flat.
    Do they make a wrench that's 15mm on one end and 19mm on the other? I've searched and can't find one.
    any suggestions?
    功夫大师喜欢骑着他的自行车在山上。
    Craftsman has a multi socket wrench. They call it dog bone wrench.
    Craftsman Dog Bone Metric Wrench: Simplify Your Toolbox at Sears
    It might be easier to have a small breaker bar and two sockets.
    It's about showing up.
    Reputation: Berkeley Mike's Avatar
    A thought: buy 2 cheap ones, cut them in half, and have the 19 and 15 welded together. To reduce size weld them at an angle; you can't want that much torque.
    I don't rattle.
    Reputation: BeeRoose's Avatar
    Or just carry the 19mm and a shim. Maybe a piece of 1/8" square key or allen wrench segment. It might be a bit sloppy but should work unless Gorilla Armstrong tightened the axle in the first place.
    "That's the smell of fitness."
    Foster Farms MTB Chickens
    rho
    rho is offline
    Life is strange
    Reputation: rho's Avatar
    Quote Originally Posted by Berkeley Mike View Post
    That would be quite easy with the right tools, but I'm not sure the OP has them. Wonder if anyone else around does? (I don't, while I have been known to get my welding on with some car batteries, jumper cables and a welding stick... Not sure if the OP wants that to go that route.)
    A custom tool would be slick though, you could do a right angle between the two wrenches, throw in some nice curves and even put a 3/8" square drive for tossing a torque wrench on... Or a ratchet.
    heaven help me
    Crescent wrench.
    Birthday Collector
    Reputation: ATBScott's Avatar
    How about an inexpensive 15mm Box-end wrench, and weld a 19mm socket onto one side of it? Only add a few ounces and not much size if you can get a relatively short 19mm socket. Or - change the nuts on the rear axle. 19mm is a pretty retarded size for an axle nut! :oP'''''
    R.I.P. Corky 10/97-4/09
    Disclaimer: I sell and repair bikes for a living
    Thanks for the ideas. That craftsman wrench looks pretty good. The crescent wrench won't work because I need a socket-like profile to fit in the narrow space between the frame and the nut.
    I'm putting that craftsman wrench on my xmas list
    功夫大师喜欢骑着他的自行车在山上。
    Oct 2011
    Quote Originally Posted by the.vault View Post
    The breaker bar and sockets sounds good. To save weight, you could cut the breaker bar handle off short and find a piece of aluminum tube that fits over it to make a longer, lighter handle out of.
    heaven help me
    Reputation: dkbmxr18's Avatar
    Dec 2010
    Assuming it's a 3/8 axle in the rear, buy new 15mm axle nuts.
    Or change the fronts to 19mm.
    Medium?
    Reputation: Fast Eddy's Avatar
    Quote Originally Posted by dkbmxr18 View Post
    And a 15mm peanut butter wrench.
    Cheesiest
    Reputation: intheways's Avatar
    Quote Originally Posted by rho View Post
    Bada$$-how thick off material can you join?
    "Paved roads...just another example of needless government spending"—paraphrased from rhino_adv
    Oct 2011
    Quote Originally Posted by intheways View Post
    All depends on how many batteries you hook up. I've used 2 and 3 batteries in series and have welded up to 1/2" thick steel:
    - Dual Battery Installation
    First time I saw it done was on my first 4WD trip on the Rubicon Trail by Tahoe. One truck twisted his rear drive shaft up like a pretzel and I figured that truck would have to be abandoned on the trail. But the next morning, it was like that old story "Stone Soup", where one guy had some welding rod, another couple pulled batteries out of their trucks, someone banged the shaft straight on a boulder, someone else cut some angle iron off their truck's flat bed. Then one guy put on 3 or 4 pair of sunglasses, burned some welding rod and viola:
    The guy drove the truck back out to pavement where he had to pull that rear shaft off (can you say unbalanced!) and drove the rest of the way home in front wheel drive.
    Cheesiest
    Quote Originally Posted by 4Crawler View Post
    Gotta love the resourcefulness of wheelers! Thanks for the information.
    Oaktown Honkey on Strava
    All of a sudden my Chris King w/ Funbolts is looking economical. J/K.
