Results 1 to 47 of 47
    Reputation: dsmxsteve's Avatar
    Jun 2016
    Best hand pump for NorCal?
    After descending down 3rd divide and finding that my camelback zipper was open at the worse possible time, my cheapo hand pump came up MIA. Iím in the market for new one. Hit me with your suggestions and advice for a replacement.
    Moderator Moderator
    Reputation: 5k bike 50cent legs's Avatar
    Oct 2016
    Quote Originally Posted by dsmxsteve View Post
    After descending down 3rd divide and finding that my camelback zipper was open at the worse possible time, my cheapo hand pump came up MIA. Iím in the market for new one. Hit me with your suggestions and advise for a replacement.
    This is the one I like.
    https://www.crankbrothers.com/produc...c-hv-gauge-co2
    Jun 2016
    Quote Originally Posted by 5k bike 50cent legs View Post
    I looked at this one online. Howís the volume for filling big wide 29Ē tires?
    Moderator Moderator
    Oct 2016
    I've only used it once, I usually use C02. I like it because it has a T-handle and hose, and is easier to pump without breaking off/damaging the presta valve.
    NRP
    NRP is offline
    Sep 2015
    I have a Lezyne HV pump. It works well, but needs to be carried in a backpack or attached to the frame. I think I'd just use CO2 because it's easier to carry.
    Reputation: RBoardman's Avatar
    Dec 2014
    I carry some random hand pump in my swat box. Knock on wood, Iíve never once used it on my bike. But other riders use it often. Same with my multitool, other people seem to use it way more frequent than myself.
    I use a Lezyne Pressure Drive. It's perfect for NorCal, but once I cross the border into NV it's pretty ****ed up. Still trying to figure out which NorNV pump to buy.
    Live to Ride, Ride to Live
    hopeless moron
    Depending on where you live in Nor Cal, this hand pump might work better for you than in other areas of the state:
    Your mileage may vary however.
    BTW, itís called ďsarcasmĒ; youíre soaking in it!
    fc
    fc is online now
    head minion Administrator
    Reputation: fc's Avatar
    Aug 1996
    Quote Originally Posted by RBoardman View Post
    That's your recommendation to dsmxsteve?
    IPA will save America
    fc
    fc is online now
    Aug 1996
    So here is the key question:
    How many times did you use use your portable pump last year? And how big are your tires and around what pressure?
    In general you want:
    - a portable that is proportional to the number of times you use it
    - want one that's anchored to the ground
    - avoid those valves that need to be threaded in a presta valve and often thread out your tubeless core
    fc
    Reputation: dchester's Avatar
    Downieville gives you solid hand pump. Or arm pump, both good.
    Oct 2015
    Blackburn Airstick mini SL. Blackburn Airstik SL Mini Pump 2018 | Chain Reaction Cycles
    For such a tiny, light weight pump this thing rips.
    Jun 2016
    Quote Originally Posted by fc View Post
    fc
    Great points. I didnít use it much last year, probably 4 times or less. However, when I did I hated it because it was a pain to use and was a workout due to its small volume displacement. I wasnít expecting much for a cheapo $8.00 pump. When I got a flat on Saturday I was carrying CO2 (2-200 grams I believe ). I burned one up trying to inflate my 29ĒX 2.4Ē that still leaked out because the hole was too big. I put an inner tube in and burned up my 2nd one but was still too low on pressure. I would guess it only got me to around 8-9 Psi. I usually ride around 23 Psi. or so. Luckily someone was willing to stop and let me borrow his pump that was a bit janky but worked better than the one I lost on the trail. One feature I really appreciate about the loaner pump was the fold out tee handle.
    Moderator Moderator
    Oct 2016
    I think all the small hand pumps are going to be small volume. But a t-handle and flexible hose makes the pumping so much easier.
    The problem with C02 is it's finite. I carry CO2 on all rides that I could easily hike out before dark, or know like the back of my hand. For long rides where hiking out would run into night or is remote, I carry the hand pump.
    I've also been carrying this stuff on my frame. Haven't used it yet.
    https://gupindustries.com/
    Contains no juice.
    Nov 2003
    $15 each time you fix a flat?!? Jeebus.
    "...rhetorical hyperbole..."
    Moderator Moderator
    Oct 2016
    Quote Originally Posted by Finch Platte View Post
    Oh, it's just in case I need a Whip It! Seriously tho, if I don't have to take the tire off to plug a hole, put in a tube, and deal with all the sticky sealant running all over the place etc, it's worth $15 to me. I got it at SeaOtter, haven't used it yet, so we'll see.
    Nov 2013
    i have good luck with the predecessor of the serfas big stick. not amazing, but $16 and it works. though the new one with the 'auto valve' (presta vs shrader) gets some questionable reviews. (the old one has two valves and you just pick the one you want.)
    any high-pressure low volume pump is a Bad Idea. had one of those once and it took 500 pumps to get a 26" tube up to something like 18 psi.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Topeak are solid. I have one.
    I also have a syncros, the 1st version of which is crap, the presta side stopped working (can still use the shcrader with an adapter) and in the cold, you can't pull the pump head out because there's nothing to grip. The 2nd version I've seen lately seems to have solved the 2nd issue. It's nice and compact and seems to be high quality...but when you compare to something like a Topeak that just works and works and works, you wonder. For winter fatbiking, where I need stuff to work miles away from civilization well below zero, I use topeak.
    Jun 2013
    I have two Topeak pumps for different situations. Camelbak gets a Mini Morph. If I dont want anything on my back I use a Topeak RaceRocket, that I just put in pocket.
    Both pumps are just OK for volume, you will surely have to work to get that tire pumped back up from nothing but in reality how often are you doing that vs lugging them around? I would rather have something more compact than having to work at pumping a tire when I get the rare flat.
    fc
    fc is online now
    Aug 1996
    Here we go, the pump bin. I usually just grab the smallest. But Iíll make a video later about the merits of these.
    Life's a Garden, dig it!
    Reputation: chuckha62's Avatar
    Quote Originally Posted by Leopold Porkstacker View Post
    Doesn't that suck the air out of the tube?
    "The man was born on third and thinks he hit a triple. But instead of running home, he ran to second base."
    fc
    fc is online now
    Aug 1996
    My circle has spoken and the best is a hand pump that converts into a floor pump. The reason is you can work against the ground instead of your other hand. Also you can put your back and weight on to the pump.
    Topeak Morph is the best line. Tons of options. One unfortunate thing though is they all go to 160 psi meaning they're low volume, high pressure pumps. they should go to 40 psi and be optimized for mtb.
    I like Crank Brothers pumps too. Very well made!!! And they have a switch system that converts them into High Pressure or High Volume modes.
    I'm usually hungry.
    Reputation: the_kman's Avatar
    Jul 2018
    I don't want to hijack the post, but does anyone have any experience with this?
    https://www.kickstarter.com/projects...cle-or-any-tir
    Looks like they're from Sausalito.
    fc
    fc is online now
    Aug 1996
    Quote Originally Posted by the_kman View Post
    I tried it and wrote an article here:
    Stompump first look - Mountain Bike Review- Mtbr.com
    Very well made product!! Expensive and a bit difficult to transport for some. But mine should be here this week so I will try it and report back.
    I'm usually hungry.
    Jul 2018
    Nice! Yeah, I will be interested to hear what you think of it after months of use. Thanks!
    Contains no juice.
    Nov 2003
Name:	Screen Shot 2018-10-09 at 9.57.48 AM.jpg
    I have two of the Topeak Mountain Morphs, same age. Got 'em on sale. Two complaints I have are: You have to have the valve near the ground, as the hose is very short. This can be awkward sometimes, and you may lose some of your tubeless fluid out of the valve. Also, the handle wobbles as you pump, again, making pumping awkward. If the handle were to unfold in a 'T' instead of an 'L', it would be easier to use, I think. Otherwise, half your effort is spent fighting the wobbles because you can't use both hands on the handle.
    Other than those quibbles, it's a well-made pump and it's got a lot of volume.
    fc
    fc is online now
    Aug 1996
    very, very good insight.
    Hella Olde
    Reputation: DH40's Avatar
    Lezyne Pressure Drive...
    "A lightweight hand pump for high pressure tires, with an integrated valve core tool."
    Always carried ,rarely used.
    Nov 2016
    fc
    Exactly. I need my pump maybe a couple times a year, so I want the lightest, smallest one I can just leave strapped to the bike and forget about. When I *do* use it, I curse its slowness, but it's way faster than walking.
    This little guys weighs about the same as a co2 cartridge:
    https://www.amazon.com/gp/product/B001N2M9XK
    Mar 2016
    Topeak Road Morph G is in camelbak. Hose long enough with foot pad & t-handle to easily use as "floor pump". Good volume for moto & bike tires.
    Catfish ...
    Dec 2016
    I have this one. I have only used it once so far and it successfully put air in the tire so that makes it a winner in my book. Its also very small and light, by my standards at least.
    My draw to this pump was that it uses both manual pump action and a Co2 cartridge. New tube - Co2, low, repaired tube - pump.
    I have another on the way for my second bike.
    LifeLine Hybrid CO2 Mini Pump - MTB | Chain Reaction Cycles
    fc
    fc is online now
    Aug 1996
    Quote Originally Posted by brucero View Post
    oh damn! The nana mini.
    fc
    fc is online now
    Aug 1996
    Quote Originally Posted by DH40 View Post
    condom ad?
    Sep 2015
    Quote Originally Posted by chuckha62 View Post
    in a way...you could say that.
    man, i would hate to see the advertisements that pop up now that someone "searched " that. hahah
    Santa Cruz 5010 C
    Surly Crosscheck.
    Dropshot Champ!
    Reputation: redmr2_man's Avatar
    this + HV variant. Best hand pumps on the market, imo.
    fc
    Amen!!!
    TR
    Hella Olde
    condom ad?
    Haha sad but true. Never used.
    Dec 2014
    Just offering my experience. I havenít used a hand pump in over a year, so Iím not going to spend top dollar on the best one.
    I may try out the Oneup one, that bolts under the waterbottle cage as well as fits their multi tool setup. It may not be the lightest but I ride packless and prefer a set it and forget it setup.
    Mar 2013
    I've had a Lezyne Alloy Drive for years (5+) and it just keeps on working. Takes forever, but they all do. 29er, 2.6 tires, 30-32psi rear. Whatever though, a CO2 will just leave you at 15psi and go empty.
    Also have an SKS Spaero Double Action - some parts are well thought out, but the handle tends to catch on the body when pumping - smooth action takes some practice and swearing. The t-handle is sweet though and a screw-on head is my preference (just need to make sure the valve core is in there tight), and the Spaero's is very well thought out. Openings are perpendicular to the hose, which helps for small wheels where clearance is limited (e.g. kid bikes). The hose storage is similarly excellent, taking seconds to deploy.
    Confession: they work outside of GnarCal also.
    Over it
    Jun 2010
    Another vote for the Alloy Drive. I only use it about twice a year--usually on somebody else's bike, but damn it's sexy.
    The broken are the more evolved. Rejoice.
    Cheeseburgler
    Reputation: gryphonics's Avatar
    Jul 2015
    Quote Originally Posted by jaycagney View Post
    I have the oneup tool and pump combo. I really like it. You can pretty much carry anything you would need for day riding in it.
    Bipolar roller
    Reputation: singletrackmack's Avatar
    Oct 2012
    Agree. I bought a crank bros power pump well over a decade ago, have used it countless times and it is still going strong. Choose between presta or Schrader, it has a pressure gauge and like fc said, can convert from high volume or high pressure mode. I bought it in Chico, used it from Trinity to Tahoe and can verify it works well for Nor Cal
    Get out of the gutter and onto the mountain top.
    fc
    fc is online now
    Aug 1996
    I can see that. But given that DSMX is asking for pump advice and that you could care less about pumps, maybe there's better threads to chime in on?
    fc
    fc is online now
    Aug 1996
    For CO2 lovers, this is a good one. SKS Airboy for $30. It's a Co2 inflator and real pump in one.
    Best hand pump for NorCal?-43648101_10156574522098213_9099786869763211264_o.jpg
    fc
    fc is online now
    Aug 1996
    Here you go. I wrote this piece.
    Fascinating selection available today!!! And each brand has a whole family of different sizes of these models.
    Best portable bike pump - Mountain Bike Review- Mtbr.com
    I actually have the OneUp EDC pump. Schiiit, I want to get a flat now!
    Rider, Builder, Dreamer
    Reputation: sambs827's Avatar
    Dec 2008
    Specialized BigBore pump. Easy carry, telescoping hose,huge volume. Max 50 psi
  1. Pump Pump Pump Pump POP!!!!!!
    By prowlus in forum Scott Sports
    Last Post: 06-25-2011, 05:34 PM
  2. Best hand-held air pump with gauge?
    By marpilli in forum General Discussion
    Last Post: 06-18-2011, 08:37 PM
  3. Best Hand Pump w/gauge?
    By -=phelan=- in forum Tooltime
    Last Post: 01-15-2007, 09:54 AM
  4. hand built vs. machine laced/hand finished wheels
    By jimmy in forum Wheels and Tires
    Last Post: 11-14-2005, 11:17 AM
  5. Hand to Hand Combat.....
    By Stratocaster in forum New York - New Jersey
    Last Post: 03-31-2005, 02:05 PM
Members who have read this thread: 153
