Results 1 to 45 of 45
    Reputation: ancient rascal's Avatar
    6th Annual 20/40 under from Kennedy Trailhead
    America's Great Gothic holiday ... Halloween and Challenge season has arrived. See if you can make it to the oak tree in under 20 minutes and or to the intersection of Priest rock and Kennedy in under 40 minutes. 6th Annual 20/40 under from Kennedy Trailhead-fullsizer-6-.jpg oak tree in the middle of the trail is a bit over 1/2 way 2.17 ish miles of the 4.1 mile distance. 6th Annual 20/40 under from Kennedy Trailhead-img_1560.jpg Start here. Season is on now and ends 3/31/17. Good Luck! More info here: http://forums.mtbr.com/california-no...ad-937071.html Strava link here: https://www.strava.com/segments/618921 ... I'm not on Strava. Is there a better link for the course that includes the oak tree 1/2 way segment? Edit: Trailhead/Potty to oak tree here: https://www.strava.com/segments/807965 Jeeze Menso ... 14:10 to the tree! I just use a stopwatch.
    Last edited by ancient rascal; 11-03-2016 at 08:48 AM. Reason: Add potty to tree Strava.
    Suicide by single speed. Work in progress.
    Sub 20's here
    (1. Rox ... 38 to the Turkey's
    Sub 40's here
    (1. Rox Turkey day ride for a 38 something! hahahahaha!
    Sub 20/40 combination here
    (1. yz343 18/33 ... (2.
    Jul 2013
    I think the "Kennedy PT (Potty Tree)" Strava segment is good. The other one is poorly measured so it can be unreliable.
    That said, I don't think I will ever make the 20. I hope to do the 40 again this year.
    Quote Originally Posted by form49b View Post
    Thanks for the link man! I hear you about the sub 20 and I may not be able to do another one myself. I missed it by 33 seconds last year and didn't even do a sub 40. Gonna try again this year. ... https://www.strava.com/segments/807965 Note: Kennedy trail will be very slow for times with the wet conditions for a bit. It's really fast when its really dry.
    Reputation: squashyo's Avatar
    Oct 2003
    Gave it a go today just to see where I am these days. I've been spending way too much time in the green zone (heart rate guys...stay focused) and it showed. 25.11 to the tree and 45:37 to the top. And that almost killed me. Sustaining time in the red zone is really hard and that's where you need to be on this challenge. For me anyhow. Didn't help that I was on flats, a few lbs of water and gear but I have my work cut out for me. Goal is under 40...20 is out of my league. I'll be out there every week seeing how I progress. ..gonna suck.
    Sent from my SM-N915V using Tapatalk
    I'm not sure how this works.
    Jul 2013
    I did a 22:37/40:32 today, but I got a bunch of PRs going down Dogmeat and Overgrown!
    Jul 2013
    BTW conditions on Kennedy are perfect. No dust and no mud.
    Oct 2003
    Tru dat. word.
    Yessir ... It sure did recover from the rain in a hurry! Sub 40 next run for you!
    I need to get after this too ... maybe tomorrow
    Squashyo and form49b have the right idea. Keep trying and you will get faster. I spent some time today working on my 20/40 bike and changed out a few things like gearing and the tires. Saved 13.4 ounces total. Squashyo and I talked about how nice it would be if he had a 20 pound Cross bike to race up Kennedy with. Who has the cx loaner?
    Ah yes the three hairpins
    6th Annual 20/40 under from Kennedy Trailhead-fullsizerender-313.jpg The 5 minute hairpin 6th Annual 20/40 under from Kennedy Trailhead-img_1586.jpgThe 10 minute hairpin ... 15 minute hairpin below pic is the turn after the long steep chopper pad hill that you see the start of in this pic. Made the cutoff times today but couldn't close the deal. 21.40 to tree and back at it tomorrow or Saturday.6th Annual 20/40 under from Kennedy Trailhead-fullsizer-16-.jpg 15 minute hairpin
    Oct 2003
    I call my attempt today, Illusions of grandeur.
    Slapped on my clipless pedals, pumped up tires to 40 psi, removed all my gear at trailhead start including water, powered down a Gu, and took off. Started well, felt strong and fast but I hit the last long sweeping left at around 20 mins. DID get 23.30 to the tree which knocked about 2 minutes off my last try but that sapped me and I bonked about 5 minutes after passing the tree. I only made it to the false top and I don't even know the time...it was slow though cause I was crawling/suffering by then.
    I have a very long way to go if I have any chance of hitting a sub 40. I think my legs are just blown out from trying to hit 600k footies this year...maybe in January I can take a few more rest days and really get this going.
    Quote Originally Posted by squashyo View Post
    You will find yourself getting used to sprinting up Kennedy and may even come to dare I say ... mildly enjoy it. I'm going up dat bastid again tomorrow.
    Today's fail: Here
    1.) 11/11/16 ... 21.27 Tree ... 2.) 11/15 ... 21:48 Tree ... 3.) 11/16 ... 22:55/42:46 Top ... 4.) 11/25 ... 22:20 Tree ... 5.) 12/7 ... 23:38 Tree DNF the 40 attempt. ... 6.) 12/9 ... 22:58 Tree ... Wet trail no hammer gel no warmup ... 7.) 12/13 ... 22:33/43:33 Top ... 8.) 12/14 22:59 Tree 2nd day in a row wet trail calling a push to yesterdays 22:33 hahaha. ... 9.) 12/20 ... 22:31 Tree ... Let's try this ****** Drop from 20t cog back to 19t for a few runs ... 1.) 12/21 ... 22:06 Tree... good 2nd day in a row first run @ 32x19. 3 hairpins @ 4:51 ... 10:02 ... 15:21 with 22:06 Tree finish ... 2.) Worn out day 3 run 4:51 ... 10:20 ... 16 flat with 22:45 tree. ... 3.) 12/30 ... 5:00 ... 10:12 ... 15:41 with 22:12 tree. ... 4.) 12/31 24:58 dead legs ... 5.) **** 2017 New Year ... 1.) 1/31/17 ... 25:35 tree, pathetic. ... 2.) 2/28/17 ... 25:16 tree *** set up 32x22 first run with this. Last two weeks of tries ... 3/14/17 32x22 second try with high profile 270 grams saving lighter tire ... 24:18. Changing out 22t for 21t today ... I won't go down without a fight ... at least a scuffle maybe? ... 3/17/17 Changed out to 21t for a 23:19 tree today. 3/19 ... 23 something tree. 3/20 40.25 to false summit.
    Oct 2003
    Gave it my Thursday effort but still not there. Still hurts for 40 plus minutes but at least I didn't bonk today. My progress:
    11/17: 23:07 and 42:40
    11/10: 23:30 and fail (DNF)
    11/3: 25:11 and 45:37
    Mar 2012
    Got off work early and road through the cold wind to the top.
    18:01 to the tree
    33:55 to the top
    https://www.strava.com/activities/779284326
    https://www.strava.com/activities/779281017
    Wow that's more than a Knockout!
    Quote Originally Posted by yz343 View Post
    18:01 to the tree
    33:55 to the top
    You killed it! Nice job ! You are the first one "On" for this season! Who's next?
    Oct 2003
    Congrats YZ...you were pedal to the metal on this run. What bike are you sailing on out of curiosity? Weight?
    Mar 2012
    Bianchi Zurigo today. It's an aluminum cx frame circa 2012?
    Even with my lightest wheels (ROL D'Huez) mounted tubeless, it's not crazy light.
    Today with a bag, Rockform Iphone mounted on stem and lights front and rear, about 21lbs. 19 when I race cross.
    Cat 1 ? ... Originally ... I was gonna ask but since you mentioned it! This is what he used Squashyo ... Looks pretty shuweet! Review: Bianchi Zurigo | road.cc
    Mar 2012
    My bike is the older frame. Non disc, black with Bianchi green panels. I test road the one in that review and it was a pig. The brakes were cable discs Heavy bike. I used old parts that a friend gave me and that I had laying around and then bought TRP mini V brakes.
    Cat 4 road
    Cat 2 cross and mtb
    Raced motorcycles for years. Hills are more fun with a motor.
    Road compact with 12/29 cassette was not fun today!
    Mar 2012
    Here it is
    Attached Thumbnails Attached Thumbnails 6th Annual 20/40 under from Kennedy Trailhead-2015-vacation-bicycle-trip-yellowstoneyosemite-101.jpg
    Oct 2003
    27.01 to tree... That's bad. My legs were just toast... Agh.
    Sent from my Pixel XL using Tapatalk
    You'll get it. My fastest sub 40 was 37:15 ish with a 22.30 slow guy to the tree. Following Darcio up and I damn near died and almost messed up my no dab on the sister hills uninterrupted series. So maybe even a 24 ish at the tree can yield a sub 40 for starters. You crushed the combo one year ... remember ... I know you do! I'm set to go after either challenge thread with two bikes set up Dogmeat and one bike set up for 20/40.
    Well ... Let's bump this miserable boy
    Now that it's back to being fast on the Kennedy side ... let's jump both the 20/40 and the Dogmeat no dab deal eh? Both of the challenges can do this to you. https://www.youtube.com/watch?v=ehwSEVbBZl4 Dazed and confused is how I felt on Dogmeat yesterday!
    Hipster
    Reputation: mboldt's Avatar
    I'll have to head out there again this season.. Definitely not in the shape I used to be right now so it should be interesting.
    Long time no see man!
    Quote Originally Posted by mboldt View Post
    Good luck on this! Let me know when you are coming to slay the challenge threads and Squashyo and I will come out to say hi man! 20/40 challenge thread may be a problem for me also this year as it was last year. 6th Annual 20/40 under from Kennedy Trailhead-img_1802.jpg Hope this is not my last victory pic for the challenge threads but who knows. Next is a sub 40 try prolly tamale. Ah the glory days!
    Reputation: pmarshall's Avatar
    Nov 2007
    I am thinking of doing the dogmeat again tomorrow. No way I can do both with the same bike though. I am not sure I could get a sub 20 right now but would be close I think. I will have to get the HT out and ready to go and give it a shot I guess.
    They never made the "Slowster"
    Quote Originally Posted by pmarshall View Post
    Significant rain is here after tomorrow so 20/40 trail will be slow for a week or so. I'm gonna bundle up and try for a sub 40 tomorrow. Next week Dogmeat with the 1x10 Ibis then the Lynskey later in the season. Klein Rascal is done for the season.
    Trail is good to go for times already
    Bump it up. Beat down ride up Kennedy today. 22:33/43:30 top. Me old and slow now. Dogmeat is also looking good for no dabbling.
    Mar 2012
    What bike are you using? You're pretty close to pulling it off.
    Thanks man
    I'm using this @ 32x20. Just missed sub 20 by 33 seconds last year.6th Annual 20/40 under from Kennedy Trailhead-fullsizerender-36-.jpg I keep trying.
    Man I'm slower than ever bump
    Beautiful day for a little climbing fun. 6th Annual 20/40 under from Kennedy Trailhead-fullsizer-44-.jpg 3rd hairpin needs sub 15 for success ... 17:05 today. 25:35 tree ... Nancy says just say no to stupid challenge threads!
    Bump: ... One month to go!
    3/31 is closing time on challenge season. I got what I had to have with the Dogmeat challenge but still looks like yz343 may be the only name on the 20/40 challenge this year. New lease on life for the Ti guy with another hollowtech crank and a new bottom bracket from Sloughs. Prolly sat in his shop 10 years waiting for me? 6th Annual 20/40 under from Kennedy Trailhead-fullsizer-60-.jpg Just got pinged ... Dogmeat no dab attempt is on for LG man and myself dis moanin! 10:50 ish Lexington lot/potties ... We'll be your huckleberry!
    Exit Bump ... Just saw pmarshall post
    I just found a Race King Supersonic with plenty tread left. Going to stay on the 20/40 challenge now minus 270 grams of rear wheel rotational weight. Maybe I save at least a little dignity by pulling off a sub 40 before closing time. Oh almost forgot ... the jealous 20/40 calling pmarshall and the rest of ... never mind.
    Nov 2007
    I will have to fix my rear hub on the hardtail to have any chance at all at a sub 20. I am sure I can do the sub 40 but the 20 might be a tall order. Maybe I will get this thing fixed and give it a go.
    Could you pull it off with a lightweight dialed in 32x22 18 pounder? New crank, bottom bracket and slightly used race king. Let's go buddy? May try tamale ... 19t-22t available. Busted up Ti guy is smooth as silk right now!
    WTHell
    Where's the W.R.R.? ... 23:19 short beatdown to the tree was all I could take today. Father time laughter heard in background!
    Indeed challenge season is over
    Props go to yz343 the only one on my thread. "Crushed" the 20/40 combination and also made Dogmeat no dab challenge. Way to go tough guy! It's still on for at least a sub 40 ... you and me form49? Off season play anyone? Dogmeat and 20/40? "Johnny come lately" thread?
    Mar 2012
    I got it in just before the 3 months of non stop rain.
    Is this beer worthy?
    I spent a bunch of money on beer last year and they sat at my place so I let LP drink some and gave the rest to another 20/40 guy cragnshag? to give away on a Coe ride. How bout a free beverage card for Peet's coffee Los Gatos? I still have it in my wallet.
    Mar 2012
    Thanks for the offer. I don't drink coffee though.
    Well, I don't drink beer. Judging by our 20/40 times ... beer trumps coffee!
  1. 5th Annual 20/40 under from Kennedy Trailhead
    By ancient rascal in forum California - Norcal
    Last Post: 04-02-2016, 09:49 AM
  2. Break in @ Kennedy trailhead
    Last Post: 09-16-2015, 07:57 AM
  3. 4th Annual 20/40 under @ Kennedy Trail-head
    Last Post: 03-24-2015, 01:38 PM
  4. 3rd Annual 20 and 40 under @ Kennedy Trail-head
    Last Post: 05-07-2014, 02:04 PM
  5. Kennedy/Sierra Azul 10:30AM Kennedy@Top-O-The-Hill Saturday March 2 2013!!!
    By Leopold Porkstacker in forum California - Norcal
    Last Post: 03-04-2013, 11:24 AM
