    Reputation: imtb's Avatar
    ~~~Haelp 140mm size rotor
    I have been seen some discusion of running 160 in front and now using 140mm rotor in the rear. Will any calipers work with the 140 rotor. please clarify this for me I am getting ready to invest in some hydro's and would like to get this 160/140 set up.
    thanks.
    Meh.
    Reputation: XSL_WiLL's Avatar
    A front 160mm IS caliper or a post mount caliper attached to a 160mm front adapter will match up to a 140mm rotor on the rear end.
    1st off I like your avitar XSL. What about the XTR caliper in the rear they make make 140 But what rotor can you use if you dont have the center lock. I like the hopes would they work?
    Meh.
    Hope 2-piece may have clearance issues. The carrier/rivets might rub against the caliper.
    Avid, Hayes, and Formula all make a 140mm rotor. There are several other options out there.
