Results 1 to 7 of 7
Thread: Zee Brakes
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Zee Brakes
    Anyone using these things yet? How are they?
    Reputation: Shalom's Avatar
    Nov 2008
    Also interested in the answer to this. Subscribed.
    IIRC Mr.Magura owns an Zee set, he modded the levers with reach adjust.
    DIY all the way
    Reputation: Mr.Magura's Avatar
    Aug 2010
    Yes, that's right:
    Shimano Zent
    They are nice brakes. Plenty of power, no noise or vibration worth considering, dirt cheap as well.
    No bleed kit needed, as 2 syringes does the trick.
    They run on Citroen hydraulic fluid, which is available anywhere and cheap as well.
    What's not to like?
    Magura
    Sep 2012
    Nice work!
    -S
    DIY all the way
    Aug 2010
    Quote Originally Posted by shibiwan View Post
    Nice work!
    -S
    Easy work
    Magura
    Reputation: BTTR's Avatar
    Jun 2012
    Any more info on the ZEE's?
    I'm about to buy a set and would like to have more info on them.
    Another question... is it ok to use Hope floating rotors with the Zee's or should i be better off if i use Shimano Ice Tech rotors?? (thinking about going with 160mm rear, 180mm front)
