Results 1 to 1 of 1
    Reputation: ciocc's Avatar
    Dec 2005
    Yet another Formula R1/X problem
    I have a set of R1 levels + RX calipers combo that came with my bike. The front has been perfect but the rear has had some issues since day one.
    The issue was it had too much play and had a spongy feel, so I bled it but the problem continued. I checked the caliper and found that one piston got stuck. The brake finally ran fine after cleaning the pistons with alcohol and bleeding it. It has been running fine since then but today (after about 3 months) I noticed the rear caliper locked up and the brake pads were grabbing the rotor. I felt as if there were too much brake fluid inside the hose, so I drained out some fluid and the caliper opened up.
    Is it normal that brake fluid expands inside the hose? I lived in So Cal and it was not that hot these few days.
    Do you think it's a defect and would it be covered by Formula's warranty?
    Thanks.
  1. Formula The One reach problem
    By pachaven in forum Brake Time
    Last Post: 11-17-2014, 02:44 AM
  2. Formula r1 brake problem
    By 65mtn in forum Brake Time
    Last Post: 04-24-2012, 08:04 AM
  3. New Formula RX Setup Problem. Help Please
    By Backnsaddleagain in forum Brake Time
    Last Post: 08-11-2011, 07:18 PM
  4. 2010 RIP 9 and Formula Oro K24 brake problem
    By MightyDingus in forum Niner Bikes
    Last Post: 04-11-2011, 06:43 PM
  5. Formula R1 problem
    By akazan in forum Brake Time
    Last Post: 01-04-2011, 12:41 PM
