Results 1 to 5 of 5
    Jan 2013
    XTR trail brakes, lever issue
    So today I discovered one of my levers has quite a lot of play.
    After a bit of a struggle to find out how to take the lever of (well done shimano ;-), I saw that one of the springs is broken, hence the play: the lever isn't "pushed back" anymore.
    This is quite annoying since these are brand new XTR m988 levers, I expected them to last a bit longer :-(
    So I'm looking up parts at Shimano but they don't list the part at all!
    Each lever has two tiny springs that push it back, these are not pictured:
    techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/BL/EV-BL-M988-3074_v1_m56577569830721147.pdf
    So I wonder: does anyone know if these springs come with one of the parts listed on the shimano doc. E.g. I can imagine it comes with the lever axle... But I need to be sure before I order anything ;-)
    I found another post here about a similar issue but it doesn't mention the springs that I'm after:
    forums.mtbr.com/brake-time/xtr-brake-lever-play-mystery-fix-769461.html
    g3h6o3
    Reputation: PissedOffCil's Avatar
    Oct 2007
    Shimano only sells complete levers so you're out of luck.
    Check out my SportTracks plugins for some training aid software.
    Warranty.
    Plays with tools
    Reputation: customfab's Avatar
    I'm sure they will replace the entire lever assembly under warranty.
    Jan 2013
    Apparently the springs are part of the lever assembly. I ordered a replacement one.
    I'm sure it'll be covered under warranty but I bought online and I don't want to send it back becuase I don't have a spare one ;-)
