    xtr pad alignment
    lil help,
    I have a set of xtr V brakes and this weekend had to replace a tire and when I put things back together the brake pad was rubbing the tire. Is there a trick to adjust the positioning to these. I have the pad positioned as far as it can go in the adjusting slot but am still way off. I just can't imagine what happened here it's not as if the pad is worn in such a way that this s how it was before the new tire.
    thanks
    -j-
    uofabill
    Aug 2003
    Try this,
    Loosen the 5mm allen bolts on each side of the brakes, this loosens the entire pad system up. Squeeze the brake lever gently and while you are doing that position the pads where you want them against the rim. When you get them like you want them squeeze the level more firmly and retighten the allen bolts. They should be in place.
    What may have happened is that as your pads wore thin if you adjusted your brakes it changed the geometry of how the pads line up with the rim. Then when you put in new thicker pads it threw the whole thing out of alignment.
    Thanks uofabill,
    I will give this a try. It's just seems odd because I didn't get new pads I simply replace the tire.
    j
    uofabill
    Aug 2003
    Sounds like something isn't seat properly?
    Are you sure your wheel is seated all the way into your dropouts? Pretty often when I mount a wheel I find that I don't have the axle fully seated all the way into the dropouts. I can usually tell by looking at how my tire is lined up or not in the frame.
  1. Does the 2004 XTR 965 wheelset and XTR
    By OffRoadRoadie in forum Brake Time
    Last Post: 08-06-2004, 04:41 PM
  2. XTR wheelset still squeal & which is lighter?
    By OffRoadRoadie in forum Wheels and Tires
    Last Post: 08-06-2004, 03:53 PM
  3. Squealing XTR disc brake on my new Blur.
    Last Post: 08-04-2004, 01:14 PM
  4. XTR Disk Pad Question
    By BLS439 in forum Brake Time
    Last Post: 03-23-2004, 07:36 AM
  5. sram xo or xtr shifting?.........
    By marco in forum Weight Weenies
    Last Post: 03-15-2004, 02:37 AM
