Results 1 to 6 of 6
    XTR M975 disc brake hose
    Can someone shed some light on my disc hose question? Can I use any model of Shimano disc hose for my XTR M975 brakes? I saw a hose (SM-BH-59) on Ebay and it was claimed that I can use it for my XTR M975 brakes. However, when I search through Google, this SM-BH59 hose is specced for Deore M525 brakes. So my simple question is can use this hose model or should I use something else? This is just for my rear brake so I'm not looking for a Goodridge type so it will match the regular hose I have on the front.
    Thanks for the help.
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    yeah..it's the same hose...the SM-BH-59 is the shimano hose with 0deg connectors at both ends, most of the current generation of shimano brakes (Deore, SLX, XT, XTR) use this hose IIRC.
    Sm-bh59
    So I can just buy the SM-BH59 hose and a pair of inserts and olives? I have an existing hose but there's a cut on it. I assume I can still reuse the connecting bolts (the threaded portion) and rubber cover in the brake lever, is that right? When you say 0 deg connector, are you referring to the banjo or not? Thanks.
    if you get a new hose it should come with all the fittings....
    0 deg. means a straight connector (no banjo)
    It is a great thing that Shimano changed.
    THe previous gen had XTR 2 banjos, XT 1 banjo and 1 straight, lx 2 straight.
    It was a huge PITA b/c the hose and fittings you needed were not always readily available.
    Now they are all interchangeable (which means the hose is cheaper as well). A win in my book.
    Sm-bh59
    Also the SM-BH59 is cheaper than the older XTR hose (with the banjos). It was quite interesting that the LBS in my place keeps on insisting that I need the XTR hose (with the banjos) because the SM-BH59 package indicated that it is for the Shimano M525 levers only. I ended up getting the SM-BH59 from Bikebling.com. Thanks for the answers guys. You are really a big help to me. I'll be doing my first bleed, hopefully it will be successful.
