Results 1 to 3 of 3
Thread: xtr harmonics
    This space not for sale.
    xtr harmonics
    has anyone ever heard of xtr disc brakes making noise/squealing because of harmonics created between the metals in the xtr rotor and the xtr brake? Not frictional rubbing but when they spin, it seems as though it is some sort of magnetic resonance that makes noise.
    I don't have near the brain power to understand it fully, if it's true, but that is the diagnosis I received.
    X-files....? or real?
    Go fast, take chances!
    The Riddler
    Reputation: Kaparzo's Avatar
    I've heard of it...
    I heard that xtr wheels and the calipers make a windy noise, but not the rotor and caliper, but maybe that's the issue if you are using the center lock rotors. To date, i dont think they've solved it, but its not hampering braking, or moving for that matter, is it??
    Lightweight Ghost Rider
    Reputation: Knut's Avatar
    IIRC they solved that problem by using XT centerlock rotors instead. Also the problem is only present on the XTR concept wheels, not with wheels built on XTR hubs alone.
  1. Replies: 4
    Last Post: 04-12-2004, 07:40 AM
  2. Older M950(?) XTR V Brake still available
    By Grande in forum Brake Time
    Last Post: 03-17-2004, 03:34 PM
  3. sram xo or xtr shifting?.........
    By marco in forum Weight Weenies
    Last Post: 03-15-2004, 02:37 AM
  4. xtr vees or 6" rotor discs
    By qtip in forum 29er Bikes
    Last Post: 03-09-2004, 01:53 PM
  5. xtr m959 cranks/dura ace bb compatible?
    By carlos in forum Weight Weenies
    Last Post: 02-27-2004, 12:53 PM
