Results 1 to 3 of 3
    Category Winner
    Reputation: teamdicky's Avatar
    XTR discs with Hop Mono Mini?
    I would like to build up a wheelset with DT centerloc SS hubs and Hope Mono Mini brakes. Would I be able to use the XTR disc to benefit from the weight of the lighter discs as opposed to using the 6 bolt Hope rotor with the QBP 6 bolt to C-Loc adapter?
    Both discs are 160mm, but I have no idea about the thickness.
    (aka SS_MB-7)
    Reputation: 1speed_Mike's Avatar
    Quote Originally Posted by teamdicky
    In theory, the XTR splined rotor *should* work with the Mono Mini...assuming the thicknesses, outer diameter and rotor braking height are equivalent. I've sucessfully used Formula rotors with my Hope Mono Minis without any issues.
    Ride Hard,
    Mike B. (MCM# 7.77)
    http://www.one-speed.com
    centerlock, lighter?
    I do not think that the centerlock rotor will be lighter. Weight weenies lists the XTR centerlock rotor with lock ring at 140 gms. as I recall, and the mono mini rotor with bolts is about 120 gms. Does dt make SS hubs for disc that are not centerlock? If not then you have to figure in the weight of the adapter, maybe that's where you are at. I just posted a thread regarding centerlock rotors to try and determine if there are any performance advantages to them besides the mounting ease. Sounds like you are going to have a trick SS, cool!
  1. levers to go with XTR discs
    By jam in forum Brake Time
    Last Post: 07-01-2004, 07:14 AM
  2. hope mini vs mono mini
    By pfunk in forum Brake Time
    Last Post: 06-13-2004, 12:32 PM
  3. Mono Mini or Marta w/ XTR Centerlock rotors??
    By Alta825 in forum Brake Time
    Last Post: 05-03-2004, 11:11 AM
  4. xtr vees or 6" rotor discs
    By qtip in forum 29er Bikes
    Last Post: 03-09-2004, 01:53 PM
  5. marco very much likes xtr discs!
    By marco in forum Weight Weenies
    Last Post: 02-24-2004, 04:55 PM
