Results 1 to 5 of 5
    Reputation: SUPASTAR2's Avatar
    Xtr Disc set -Rotor upgrade?
    I just purchased Shimano XTR M 975 Disc Brake Set , The centerlock rotors do not fit my 6 bolt obviously,So will Shimano XT SM-RT75 Disc Brake Rotor 160 6 Bolt fit & work? Or are there any better rotors that would also work with the Xtr?
    Start where you are. Use what you have. Do what you can.
    --Arthur Ashe
    Yes, the XT rotors will work fine. I think Hope Mono minis will fit (though not 100% sure), which are Al/steel rotors like the XTRs.
    --Arthur Ashe
    Missed out on the Shimano's, Does anyone know for sure what other rotors fit the Shimano XTR M 975 Disc Brake Set?
    --Arthur Ashe
    I am running Avid clean sweep's 203mm in front and 160mm in the rear, With xtr 970 calipers.
