OK, So I changed from CODA disc calipers to XTR. The front was easy and only required 1.4mm of shims. the back looks like it will require about 7mm or more.Can this be right? Is there an adapter required?
The CAAD 5 frame is rigid and the hubs are XTR (centerlock). The CODA calipers had shims but only about 2mm worth.
