Results 1 to 7 of 7
    XTR Disc Pads Rubbing
    How do I get my pads to retract further from the rotor, they are suddenly rubbing very badly? I am running XTR disc calipers and rotors. Thanks.
    I have tried remoivng the pads, and going through the procedures outlined in the Shimano document to correct rubbing pads to no avail, any suggestions?
    Reputation: heatstroke's Avatar
    Jul 2003
    Are the calipers centered on the rotors. If so maybe you have sticky pistons.
    take out the pads, pump the brake CAREFULLY to extend the pistons EVENLY, use a screwdriver between the pistons to make sure they extend uniformly and one piston does not popout. Then wipe the pistons and squirt a bit of triflow on them . Work them a bit and you should be ok.
    Reputation: sandan's Avatar
    Good job!
    Quote Originally Posted by heatstroke
    I do it just about the same, except I let only one piston extend, that way I can clean a bit more of the shaft, lube it with Triflow or some of Shimano's mineral oil.
    Bad Case of the Mondays
    Reputation: Jdub's Avatar
    Quote Originally Posted by sandan
    Yeah that is how I do it as well. However, once I did it once time I haven't had the problem again. Knocking on wood now....
    I already rode that
    Reputation: SuperNewb's Avatar
    Yeah I did that too but it only lasted so long. The front is acting up again to the point the piston needs a good pry to move.
    Reputation: flipnidaho's Avatar
    Mine does the same thing..
    and I go through the steps to clean and lube the calipers like everyone has posted. However, I go through an extra step right before installing the wheels/rotor. I take the orange spacer and insert into the caliper. Then I squeeze the lever pretty hard about 5 to 10 times then install the wheel/rotor, squeeze the lever hard a few more times to reset to the rotor. If that doesn't work and it still rubs, I use the spacers. If that doesn't work, time to warranty those sticky calipers...
    Neg reppers r my biatches
    Reputation: FoShizzle's Avatar
    Quote Originally Posted by flipnidaho
    I did a similar thing....but finally had to have them both waranteed......these worked for a while.......then needed to start doing the same thing.....by the time I got tired of fussing with them I decided to go larger rotors and replaced the set anyway. Having said that, I like their power and modulation.
  1. deore discs?
    By xisaacx in forum Brake Time
    Last Post: 07-06-2004, 03:44 PM
  2. Replies: 5
    Last Post: 07-03-2004, 11:49 AM
  3. Tuning up XTR disc brakes - pads etc. ??
    By rpbt in forum Brake Time
    Last Post: 06-05-2004, 09:26 AM
  4. paging all 04 xtr disc users..................
    By marco in forum Weight Weenies
    Last Post: 05-24-2004, 02:12 PM
  5. disc brake pads are rubbing on the rotor
    By neversumme144 in forum Brake Time
    Last Post: 04-29-2004, 08:39 AM
