Results 1 to 6 of 6
    XTR Disc Brake Pad springs
    Are the XTR springs that hold the disc brake pads the same as the ones for XT pads? The pics look similar. Does anyone have 2 XTR springs they want to get rid of cheaply? or if you have a used set of disc pads (frt and rear) + springs ... let me know:
    - what you have and how much you want
    - your location (city and major area or intersection)
    Springs are the same.
    A bicycle will take you to fantastic places....if you let it.
    Ibis fan since '08 now rolling on the big wheeled Ripley.
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    both springs and pad are the same for the current 2 piston caliper shimano brakes (XTR, XT, LX, Deore)
    XT's caliper are the 4 piston type (M755)
    I guess i should have mentioned that my XT are the older 4 piston type (M755) that use this type of pad (see pic)
    It's the axle
    Reputation: Gregg K's Avatar
    Just a heads up.
    I have noticed that the newer XTR return springs are much thicker than the 03 models. I'd try to find the newer ones. I think it's their attempt to fix the sticking pistons.
    I got springs with a set of pads I bought once. You might try that angle. Search around.
    -> SickLines.com <-
    Reputation: mtb_biker's Avatar
    Quote Originally Posted by jisozaki
    Those don't use the same XTR springs.
