    Reputation: jeffnat68's Avatar
    Xtr brake lever question.
    I hve just fitted some xtr brake levers but the lever needs to be longer as it touches the xo shifters when pulled hard. Anyone know if shimano make longer levers?
    Sent from my GT-I9100 using Tapatalk
    Attached Thumbnails Attached Thumbnails Xtr brake lever question.-uploadfromtaptalk1316204598550.jpg
    Weird huh?
    Reputation: cmdrpiffle's Avatar
    Not sure about the longer levers, but you just need to loosen the hex screw on the rear shifter, and rotate it downwards to move the cable entry housing out of the way of the brake lever. I had to do the same thing on my bike. 30 second job, tops.
    Cheers
    Poaching Demo...that's why we can't have nice things...
    There were 2 version of the lever made. You have the bent one, which was more common. Here's the other:
    ballbuster
    Reputation: pimpbot's Avatar
    Are there any aftermarket replacement levers, like Dangerboys? Maybe that's wroth looking into.
  1. Brake Lever question
    By yaqui316 in forum Beginner's Corner
    Last Post: 05-06-2011, 07:32 PM
  2. Brake Lever Question
    By Wrath UK in forum Beginner's Corner
    Last Post: 12-22-2009, 09:29 AM
  3. Brake Lever Question
    By freaknunu in forum General Discussion
    Last Post: 02-19-2009, 01:18 PM
  4. V brake lever question
    By bwgill37 in forum Brake Time
    Last Post: 12-21-2008, 06:27 PM
  5. brake lever question
    By etnocmit in forum Beginner's Corner
    Last Post: 07-21-2004, 08:53 AM
