Results 1 to 3 of 3
    g3h6o3
    Reputation: PissedOffCil's Avatar
    Oct 2007
    XTR 988 lever, bleeding with syringe
    Hello,
    Just received my XTR 988 trail brakes and I expect I'll need to shorten the hose when installing. I didn't buy their funnel kit and I was wodnering if the lever port was the usual size so that I could use a regular syringe for the funnel. Anybody know?
    Thx
    Check out my SportTracks plugins for some training aid software.
    g3h6o3
    Oct 2007
    Nobody knows if the port threads are standard and would work with an Avid/Formula kit?
    g3h6o3
    Oct 2007
    I confirm it is a standard port so a syringe could be used instead of the funnel. An Avid bleed kit with the closing clamp would be an ideal replacement if you already have it.
