Results 1 to 5 of 5
    Saving lives with knives.
    Reputation: frank daleview's Avatar
    XTR 975 disc brake in cold temps
    How do the older XTR 975 brakes do in cold temps. I really like the look and feel of my 965s but the lever get really stiff in cold weather, I found a set of the 975's for cheap and was looking to maybe resolve this issue. Is this an issue common to all mineral oil brakes, or is this a design issue with these in particular. I would greatly appreciate any advice, even if it's for other brake brands they do well in the cold.
    Formerly known as iceaxe
    I don't believe it's a mineral oil issue but rather a caliper seal issue. I have the m585s and they are horrible when the temp is less than 40F. The rubber used for the seals gets stiff in the cold and does not allow the piston to fully retract. I think Shimano has fixed this but I'm not sure if they did on 975's.
    Quote Originally Posted by iceaxe View Post
    Sorry don't know what you are doing wrong....I ride my XTR's down to -35 C they don't get stiff at all...
    They do leak some oil when it gets below -25 C.
    965's or 975's?
    965's or 975's?
    The ones that don't have the banjo bolt the hose goes straight into the caliper.
  1. Cold Temps Lube
    By jkcustom in forum Alaska
    Last Post: 11-12-2009, 11:16 AM
  2. Best Battery for Super Cold Temps?
    By Longfellow Mafia in forum Lights DIY - Do It Yourself
    Last Post: 01-05-2009, 04:00 AM
  3. Cold Temps
    By Giant24Yukon in forum Trail Building and Advocacy
    Last Post: 02-12-2008, 08:52 AM
  4. Fox Fork and cold temps?
    By crux in forum Shocks and Suspension
    Last Post: 11-02-2006, 04:45 PM
  5. cold temps and magura
    By dang in forum Brake Time
    Last Post: 01-26-2004, 12:36 PM
