• 04-30-2012
    GL1
    XT-XTR BR-M785 Warranty Brake Leaking Issue
    Hi All,
    So I thought I'd post as a Public Service Announcement.
    I have the new design 2011 XT Trail Brakes. First and foremost, let me just say they are the BEST brakes I've ever ridden hands down. So, don't let this post deter you from purchasing a truly great product at what I think is a good value.
    But, after wrestling with an issue on my front brake for a few weeks and consulting with one of the best LBS's here in CO I finally have an answer.
    It appears that LBS's are beginning to see a common leakage issue with these brakes in the factory lines. The leak takes place right above the banjo nut where the fitting intersects the line itself (left side of the caliper) and trace amounts of mineral oil get down onto the pads/rotor. Apparently this is becoming "known" so check yours if you're having issues. I am getting a new hose warranty etc... I'll explain more below.
    As far as symtoms, I had a noticeable loss of power (because oil was on the pads/rotors). It was even to the point of my being able to push the bike with the front brake on hard. But, this went away if I used them on an extended downhill because it burned the oil off and then the power would increase again. You can also have howling and noise although I didn't have too much of that. The giveaway is that if you ride in dusty conditions like I do, you will see the dirt gather on the oil all over the caliper. Compared to my rear brake (that does not yet have this issue) it was easy to see the difference. Of course the final thing is that you will get some air in your line which I also notices when I tipped the bike upside down or on the back wheel and back down (the lever went nearly to the grip but "pumped" up again once the bike was again level.
    So anyway, I think I saw a post on this awhile back. I'd be interested to hear if others have had this issue. Again, I think the brakes themselves are OUTSTANDING and for me, Shimano is standing by this and giving me new lines etc. I am assuming the LBS will also get reimbursed for the subsequent bleed oil/labor from Shimano as well. The only component I'm not sure on is the pads. They did get mineral oil on them and I have heard that can damage them. We will see what happens but at $45 a pop I wouldn't mind a warranty pair of those as well.
    Let me know if you have had or heard of this issue as well. :thumbsup:
  • 04-30-2012
    baltik
    Helpful post thank you, I guess the next question is whether Shimano has redesigned the hose and if Jagwire or others offer a good aftermarket alternative
  • 04-30-2012
    GL1
    Yeah, I hope whatever they give me for a warranty is a redesigned one. I just saw another post on these and this banjo nut leak issue has been experienced by others on the XT's and XTR's. I'll have to watch my rear one as well.
    The jagwire has mixed reviews but it does come in an array of colors. I don't know if they have a different banjo nut that comes with them and/or whether that would be better. The Shimano hose itself seems to get good reviews less this banjo bolt leakage issue.
    I would be interested to know whether anyone makes stainless braided cables for these. If so they would probably be $$$. A quick search found one UK company...HEL Performance Mountain Bike Brake Line Kits
  • 04-30-2012
    JayMac
    The same thing happened to me. Both front and rear were leaking where the hose went into the fitting. My LBS quick fix was to heat up the pads, scuff the rotors and crazy glue the line at the leek to keep them from seeping and saturating the pads again. Here is my problem...they tell me Shimano refuses to believe there is a problem with the brakes. So now I have $400 worth of brakes that make noise, dont stop worth a damn and need hoses and pads replaced. Its been a week on Friday, gonna call them tomorrow and see whats up. If not, then Shimano gets the call from me.
  • 04-30-2012
    GL1
    Well, keep on it for sure and let your LBS call the reps. It sounded to me from my LBS guys that Shimano is beginning to acknowledge the problem and it sounds legitimate based on what you see on other threads on this forum.
    I also thought about some ways to do a "quick fix" but apparently they are getting my warranty line in a few days. I can still ride on mine and it actually works good on long DH's when the rotors get hot and the mineral oil burns off. Mine is not leaking like crazy either...but enough.
    Anyway, despite all this I still have to say that they are awesome brakes. Shimano may just need to address this issue and make it right. Funny how the smallest link (banjo nut fitting) can mess with an otherwise amazing system.
  • 05-01-2012
    avbcon12
    As stated, this is a known issue at shimano and if the dealer calls them they will send out a replacement, provided you send in your leaking one. I called our rep and got it all taken care of, including pads. The hose and fitting look exactly the same, i was told it was an issue with the crimping machine using not enough force and all has been remedied now.
  • 05-01-2012
    zuuds
    My rear M785 brake started leaking at the banjo / hose junction. I bought mine from treefort bikes, they got me a RA# and I sent it back to Shimano. I asked if I could just send in the line since the lever and caliper were fine, but I had to send in the whole thing. My replacement is on its way to me in the mail. No issues with my front brake (knock on wood), but I'll be watching the hose like a hawk.
  • 05-01-2012
    zuuds
    Everyone knows when it comes to ho(ses) that crimpin' ain't easy...
  • 05-01-2012
    MTB Pilot
    WOW!! Your LBS SUCKS!!:eekster: I'd be on the phone with Shimano yesterday.
    I just had this issue on Saturday with my rear brake and it pissed all the oil out during the last 3-4 miles of my ride. Luckily I have two sets and was able to use one off another bike, but my LBS called Shimano and got a new hose and pads coming under warranty. Shimano knows about the issue, and doesn't have a problem doing the right thing. \\ Wonderful brakes otherwise!!:thumbsup:
    MTBP
  • 05-01-2012
    FD5046
    Have the same problem with both m XTR brakes. Thank you very much for the info!
  • 05-03-2012
    RockyMt
    My M775's leaked at the front outside piston.
    Shimano replaced with M785's.
  • 05-07-2012
    GL1
    Follow Up
    Wanted to post a follow up on my warranty issue.
    So Shimano is sending me a new line, new pads, and apparently a new ICE tech rotor! Oh, and taking care of the labor I believe as well but not 100% sure on that yet.
    My LBS really came through for me and Shimano apparently agrees that once a brake has this issue and mineral oil gets on the pads and rotor, all those components need to be replaced. So, that was a nice surprise. I didn't know the rotor was included...and it was an ICE Tech at that...so between that and the pads there's some $$$ there in this warranty.
    Anyway, everything is on it's way so hopefully I'll get this resolved in the next week or so. Since this causes such an issue when the failure occurs I am thinking about proactively changing the rear brake line...or maybe I'll just wait and see if it develops an issue and then take it in for warranty as well IF that happens. I haven't decided yet.
    Anyway, a kudos to my LBS, Wheat Ridge Cyclery in CO here for taking care of me like they always do. Support your LBS. I don't buy everything at the LBS due to lower prices online but I do make an honest attempt to give them business in both service and parts...even sometimes when it's a few bucks more. Also, thanks to Shimano for making things right and standing behind their product.
    And as I've said along and will continue to say...even after this these are the BEST brakes I have ever ridden!
  • 05-10-2012
    zuuds
    I just got my new warranty replacement rear brakeset from Treefort. I mounted it up, and everything's looking good after a few rides, no sign of leakage at the banjo. I noticed that the crimp lines on the new brake line look more defined than the ones on my front brake line. I'll be keeping a very close eye on both banjo fittings.
  • 05-11-2012
    jabrabu
    I'm having a lot of the same symptoms with a rear XT brake. It has been squealing and has a loss of power. After storing the bike upside down for a few days, the lever would bottom out on the handlebars, but then pumped back up after many pumps. I'll have to take a closer look at the banjo fitting and see if the there is leakage there.
    Has anyone called Shimano directly instead of working through a dealer?
  • 05-11-2012
    andy.l
    Just fitted these myself,but as id started seeing reports on different forums regarding the hose leaks I bought the components seperately and opted to fit Jagwire Hy-Flow lines instead. But I had leakage from the lever end as Jagwires supplied Olives werent holding the hose correctly,my LBS corrected this and I think that they used the Shimano olives on the Jagwire hose,so far no leaks and great braking.
  • 05-11-2012
    fuenstock
    I've also been running Jagwire hi flow hose on my front and rear xtr trail brakes for several months with out issue. Great brakes now that they are working right. Both my front and rear shimano hose's leaked right form the start.
  • 05-12-2012
    GL1
    Still waiting..
    I'm still waiting for my parts from Shimano...hopefully next week.
    In the mean time, I put super glue around the banjo nut...seems to help. Temporary fix.
    See pic...
  • 05-12-2012
    GL1
    Yep
    Sounds like a classic case of this and you've got air in the line for sure now if your lever is doing that. You can ride it but it's not great. Check that banjo nut. It's a slight leak...more like a seep but typically if you have a thin layer dust on the caliper and lines you can see it.
  • 05-12-2012
    WHALENARD
    awe...man. I want to get a set of these but is worth the hassle.....?
  • 05-12-2012
    avbcon12
    There really isnt any hassle, not everyone is having this issue and if you do shimano fixes it.
    :cool:
  • 05-16-2012
    rgeniec
    Same issue with me on front and rear. The front drips onto rotor. The rear still leaks but drips on the underside of the caliper and has not infected the pads yet. I see a dust sludge trail like the front. Getting both replaced under warranty hopefully. I will let u know the results soon.
  • 05-16-2012
    charlesinoc
    How do I request for warranty repair if you did a self install? Anyone have an experience.
    Thank you for posting this information, very helpful.
  • 05-16-2012
    007
    Has anyone tried retrofitting the new XT/XTR's with braided lines?
  • 05-17-2012
    PissedOffCil
    Ended up having the leaking front hose, I epoxied it because I have a race this weekend. I might end up replacing it in the long run for Jagwire Hyflow or Goodridge lines since I doubt Shimano will replace the brakes since I bought them over Ebay. I also have a leak of my rear brake but at the lever this time... I wonder if the seals might have been damaged when riding in freezing temps this winter. Anyhow, bad situation before a race! At least they stop enough for me to race this weekend.
  • 05-17-2012
    fuenstock
    Originally Posted by PissedOffCil View Post
    I might end up replacing it in the long run for Jagwire Hyflow or Goodridge lines since I doubt Shimano will replace the brakes since I bought them over Ebay..
    I replaced my front and rear leaking shimano hose with Jagwire hyflow and has been leak free since. I didn't want to try shimano hose again because I had heard of people getting replacment shimano hose and have it leak again. Heres a picture of the jagwire hyflow setup.
  • 05-17-2012
    jimarin
    I bought my 785s on eBay so I just put goodridge lines on. So far so good. You need the 108 fitting kit. You also still have to use the stock bolt that bolts the banjo to the caliper. Works fine, no leaks and good feel at the lever. Chain reaction has the best price.
  • 05-17-2012
    rgeniec
    I left mine at shop today and they are going to try and get me a new pair. If not it will be new updated lines and pads. I am selling them once I get them back. Bought another pair in the meantime as I cant wait to get them fixed. Lemme know if anyone interested in them. Have extra pads and oil and bleed funnel not used.
    Randy
    805-338-9696
  • 05-17-2012
    GL1
    Yep
    Yep, that's a great question. I did a quick search and didn't find anyone making them. If you know of anyone who makes them let me know. That would be cool. Jagwire is probably the next best thing.
  • 05-17-2012
    007
    If the banjo bolts and fittings are the same as previous model years (which I realize they may not be since the redesign), Goodridge does have kits. If you could figure out which banjo fitting and compression washers are needed, you could probably get one to fit.
    I'd just wait a touch longer . . . can't be long before goodridge has something readily available. They may already to be honest.
  • 05-18-2012
    GL1
    Thanks for the info! So I see the goodridge lines but I'm confused. It looks to me like the Hose Kit 107 is what you need but that also doesn't look like braided cables. The kit 108 you refer to is just the fittings and says it's for Saint.
    Also, this thread XT M785 brakes & goodridge hoses Singletrack Forum seems to indicate it's kit 107 for the new generation XT's but let me know if you know before I buy anything.
  • 05-18-2012
    jimarin
    I put a 108 kit on my trailbike last week and on my dh this week (785s on both). Look at the fittings in both kits. The 107 has banjo's for both ends. 108 is the right kit. All goodridge are braided. The ones you saw are probably black, which don't really show the braid.
  • 05-20-2012
    JayMac
    My LBS got just hoses for me that they installed on Friday. I wasn't happy with just lines and felt that the pads should be replaced because of contamination (rotors should be fine). I called Shimano myself, and other than no toll free number and being on hold forever, they are sending the LBS replacement pads for me no questions asked..that easy! Don't know why that couldn't have happened when the call was made for hoses.
  • 05-21-2012
    GL1
    Yeah, pads for sure. I am getting those. I was mistaken on the rotor. I am not getting a rotor and I'm okay with that.
    jimarin, thanks for the info on the goodridge. I am looking into those. Kit 108 then for sure! Thanks!
  • 05-22-2012
    PissedOffCil
    Ordered the Hyflows with a new lever for the rear brake and new pads (without fins this time). Hopefully everything will get back to normal as I'm tired of the lack of power.
  • 05-22-2012
    92gli
    If you did the "bleed free line shortening" the levers will likely go to the bars after hanging the bike upside down. Mine did.
  • 05-23-2012
    daytona
    what are the item i need to get if i would like to change the m785 front brake host? any recommendation?
  • 05-23-2012
    BullSCit
    Thank you for posting this. I have had my brakes for a couple of months and thought they were the greatest brakes ever. But all of a sudden the rear started to howl, and the front lost it's great power and modulation. Looking at the rotor shows a darker substance on both the front and rear, and I have had problems with both levers pulling to the bars after longer downhills. I'm so glad to hear that this is a simple fix, and especially one that Shimano will pay for, good on you Shimano. And luckily for me, I just ordered a new set for my wife, so looks like I will use those while I wait for my warranty returns.
    But what is best to clean the rotors, as they definitely have a little bit of a film on them?
  • 05-23-2012
    mestapho
    just wipe them down with isopropyl alcohol.
  • 11-11-2012
    kiloman
    See pic...
    Glad I found this thread, because my front line started leaking at the end of the crimp to the banjo nut, exactly where circled in the above picture. I've had them since mid-September and absolutely love the brakes. Great performance for the price, too bad there is this little quality issue. But it's good to know there is a fix since mine didn't work so well on today's ride with oil on the pads.....
  • 11-11-2012
    GL1
    Glad you found the thread. Let us know if your LBS will help on the warranty. They should. As you've seen from the the thread the pads are toast once they get mineral oil on them. So a decent LBS warranty should include a new line with banjo nut, bleed, and pads. Then clean the rotor with 90% alcohol really good. Since my warranty, zero issues and that was almost a year and 60 rides ago. Still the best brakes I've ever owned!
  • 11-12-2012
    Niner_Boy
    This isn't a problem with the brakes at all, or at least it's not related to the OP's topic of leaking XTs at the caliper end.
    If your master cylinder has air in in, when the bike is turned upside down, the air being lighter than the mineral oil rises to the top, which ends up in the caliper. That's why the levers go all the way to the bar, because the levers when squeezed are pushing air into the caliper...not oil. Unsurprisingly, turning the bike back to normal will again cause the air to move upwards, but back into the MC, and it's just a matter of time before the levers become firm again.
    To avoid this, ensure that there is no air in the MC i.e. fill it right to the top. Then it won't matter if your bike is upright, sideways or upside down, as no air will ever get into the caliper.
  • 11-29-2012
    Pau11y
    Dumb question here:
    If your (metallic) pads are contaminated w/ oil, can't you just spray them down w/ disc brake cleaner or soak them in isopropyl alcohol to break up the oil? Hell, worst comes to worst, when you pull them out of the alcohol bath, set them on fire for a few seconds to burn off the oil/alcohol, then smother w/ a water dunk? Wouldn't this not work, instead of shelling out for another set of pads?
  • 11-29-2012
    rgeniec
    Good luck with that...try it out and let us know.
  • 11-29-2012
    StiHacka
    Originally Posted by Pau11y View Post
    Dumb question here:
    Of course they can be salvaged. 20s in a natural gas flame takes care of the contamination very well. I ride with the original pads after having replaced the leaking BH90 with BH59 and XTR banjo a couple hundreds miles ago. :thumbsup:
  • 11-29-2012
    shehateme
    I have had this problem as well.
  • 11-30-2012
    GL1
    Dumb question here:
    They just replaced mine with the warranty but at near $50 a pair it would be worth a try to salvage them.
  • 11-30-2012
    Pau11y
    The reason I ask is I just got my mitz on a set of the 988s for a pretty good deal and was researching these for Goodridge hose replacement (answered) before I pay the guy, and saw all the issues that you guys are having, specifically w/ contaminated pads. I've been an Avid guy since moving from Hayes and the resolution for dealing w/ DOT contaminated pads is a simple rinse w/ water. Mineral oil being different than DOT, I'd imagine you can just use a different rinse fluid, or in the worst case, oxidize the oil by heat (reads as burning) so it can be rinse w/ water...
    Anyway, the other issue was bleeding, ala Avid style, by degassing the fluid. Top to bottom method is fine and all, but doesn't do much for dissolved gases already in the fluid. Here, I think Avid has DEF go their act together. So, has anyone managed to get a proper seal at the caliper end to pull a vacuum and degas the fluid in the system? I saw a vid of some guy using an olive threaded on the tubing, then pushed up against the bleeder nipple once the tubing is attached to get a solid connex. Do any of you know if this creates the proper seal to pull negative pressure via a syringe?
  • 11-30-2012
    mestapho
    I've burned metallic pads with good results. I just tried a set of resin pads and
    would say that was a failure. Oh well, I 'll just buy metallic from now on.
    @Pau11y - I use the push pull method like you would with Avid brakes and it works fine.
    I bought the Avid bleed kit and gave the DOT to a buddy with Avid brakes. The brass threaded
    end thingy fits perfectly into the reservoir on the levers and I just push the plastic tubing over the bleed nipple on the caliper. It work perfectly.
    I did discover that if you overfill the reservoir you will get oil weeping from under the cover for awhile.
    I was worried that it was leaking, but its just the oil that spilled between the cap and the actual reservoir.
  • 11-30-2012
    Pau11y
    Hehehe... yeah, I didn't think the resin pads would be a good candidate to be set on fire :D
    Maybe just a alcohol bath w/ those...?
    And, thanks for the clue on using the Avid bleed method and that the tools work :thumbsup: I'm kinda invested in the Avid tools...pro bleed kit...so it's nice to know I can reuse :)
  • 11-30-2012
    iwantalitebike
    I have the same problem!
    Who did you contact? You LBS or Shimano directly? If Shimano, a phone number would be awesome.
  • 11-30-2012
    GL1
    Just went to LBS an showed them and they took it from there. And...i didn't even buy the bike or brakes from them. they are just a really good shop. I thought someone else on this thread contacted Shimano directly though.
    Again, I got the new banjo nut installed and my brake bled and new pads all covered by LBS through shimano. Kept rotor but cleaned it. In the interim while waiting for the banjo nut I kept riding it but put super glue around the nut. It had some air in the line but it worked for a week or so until the LBS had the part and time to do it.
  • 12-02-2012
    outlaw
    I have same problem with my XTR trail M988 brakes which Goodridge Hydraulic Tubing Kit do I need?
    Goodridge patented reusable, stainless steel fittings, no crush-style compression ferrule olives
    Coated, stainless steel braided, PTFE inner, hydraulic tubing
    Tubing design has an extreme bend radius for no-kink, no-bulge performance which also offers a firmer, more consistent brake feel
    Developed from Formula-1, World Rally, and Indy Car racing
    Kit #104: (2) M8x.75mm-male in-line fittings (1 fixed, 1 swivel)
    Kit #108/110: (1) M6x1mm 90-degree banjo fitting and (1) M8x.75mm-male in-line fittings (must reuse stock caliper banjo bolt on Juicy brakes)
    Kit #111: (1) M6x1mm male inline (long) and (1) M8x.75mm male inline (long) fittings
    ZOOM
    item # kit # f/r length color remaining price action
    GE-10411 104 front 900mm carbon 10 $33.95
    GE-10412 104 rear 1650mm carbon 9 $36.95
    GE-10421 104 front 900mm clear 10 $33.95
    GE-10422 104 rear 1650mm clear 10 $36.95
    GE-10431 104 front 900mm white 2 $31.95
    GE-10432 104 rear 1650mm white 1 $36.95
    GE-10441 104 front 900mm black 7 $31.95
    GE-10442 104 rear 1650mm black 4 $36.95
    Fits (1 front or rear): Shimano XTR-M975, XT-M775, Deore-M525; Hayes Sole; Magura rim brakes (no crossover tube, just M/C to cylinders); Avid Code, Code 5, Code G3, Code R, Hayes Stroker Ryde
    GE-10811 108/110 front 900mm carbon 8 $43.95
    GE-10812 108/110 rear 1650mm carbon 6 $47.95
    GE-10821 108/110 front 900mm clear 2 $43.95
    GE-10822 108/110 rear 1650mm clear 2 $47.95
    GE-10831 108/110 front 900mm white 9 $43.95
    GE-10832 108/110 rear 1650mm white 7 $48.95
    GE-10841 108/110 front 900mm black 9 $43.95
    GE-10842 108/110 rear 1650mm black 6 $48.95
    Fits: (1 front or rear) Saint-M800, XT-M765/756, Hone-M600 LX-M585, Deore-M556 systems; Magura Gustav-M; Hayes El Camino, Stroker Trail / Carbon; 2005+ Juicy-5/7 (no <04 Juicy-7 or The One requires M8x1.0 lever fitting) Formula R1, RX
    GE-11101 111 front 900mm carbon 5 $49.95
    GE-11102 111 rear 1650mm carbon 7 $52.95
    GE-11121 111 front 900mm clear 6 $49.95
    GE-11123 111 rear 1650mm clear 3 $54.95
    Fits: Magura Marta, Louise; Avid Elixir, XX, X.O, X.9 and X.7 models do I need.......
  • 12-02-2012
    Pau11y
    Originally Posted by outlaw View Post
    I have same problem with my XTR trail M988 brakes which Goodridge Hydraulic Tubing Kit do I need?...
    Get 2 of these:
    Goodridge Connector Kit 108 Saint El Camino Gustav | Buy Online | ChainReactionCycles.com
    or these if you want some spare parts:
    Goodridge Connector Kit 107 Shimano Systems | Buy Online | ChainReactionCycles.com
    I prefer the silver stainless...but not alloy
    And, you'll need some of this:
    Goodridge Hose | Buy Online | ChainReactionCycles.com
    I made my own w/ the banjo from an old Juicy kit and swivel M8 x 0.75 from an ala carte buy. And, I buy hose in bulk to save some $$ (I use these hoses on several bikes).
  • 12-02-2012
    outlaw
    so any 108 kit should do, thanks!!!!!
  • 12-03-2012
    Pau11y
    Used the Avid method and got a GREAT bleed! Used an old Hayes bleed nipple spring over the tubing on the caliper end to attach the hose and the Avid hardware did just thread right in at the lever end! Used the steps from Avid...closed lever and pushed/pulled at the caliper end, then pushed fluid up to lever, closed off caliper then pushed pulled at lever end. Way clean, a HELLUVALOT less chance of making a mess than a open funnel, AND it degassed the mineral oil!
    Whoever said mineral oil doesn't hold dissolved gases like DOT...give it a try and get back to us on your results because I got mine to fizz up like a newly opened bottle of 7Up!
    The only drawback...rubber bits designed for DOT doesn't play well w/ mineral oil, or whatever Shimano has added into its oil, cause it'll eventually turn the syringe plunger's rubber tip into puddy! I think I need to find me some Magura syringes from the old days...
  • 12-18-2012
    bitewerks
    Does anyone know if this problem has been solved? I was planning on ordering a set of 785s next month.I think the first post was 2011 & Universal Cycles lists the brake as the '12 model.
  • 12-18-2012
    kiloman
    My friendly LBS got a new front brake line and new set of finned metallic pads for me from Shimano, no problem. Problem solved! My rear brake was unaffected and my friend with his M785 was also unaffected. I'm not sure why a few people couldn't get theirs repaired under warranty when my LBS manager said Shimano sent them my replacement parts no problem, no questions asked.
    Having previously been a Campagnolo fan for my road bikes, my opinion of Shimano is definitely increased by how they handled this little warranty issue.
  • 12-19-2012
    bitewerks
    Thanks for the info. I'm ordering online so just wanted to double-check as if there's an issue, I'd have to send them back to Universal Cycles (I'm in TX & need to save as much as I can on parts) for warranty, I"m assuming? Or would I go direct to Shimano?
    Reading threads about problems always seems to make the issue sound much bigger/worse than it is especially when it's the first set of hydro's for me.
  • 12-20-2012
    mojojojoaf
    Good read and thanks for the tips about line replacements- likely to double check tonight and order new lines anyways.
  • 12-21-2012
    nonamed
    Yeah my friend succesfully managed to solve his problems with new XTRs . Regards
  • 01-23-2013
    bedwards1000
    Question: How long does Shimano warranty this? My brakes are 2010 and I've had the problem for over a year now but haven't seen any leakage or noticeable loss of fluid (till lately) but the symptoms match perfectly.
    Thanks for the thread. I've searched for this issue before never found the answer. I guess i was searching for the wrong thing. My symptoms are howling brakes, loss of power and if I do some hard braking I get it all back for a while and then it starts over. Just lately I've noticed the lever is getting soft. The breaks worked flawlessly for about a year.
    I could care less if I have to buy new pads. I've bought about 3 sets trying to get them to work.
  • 01-25-2013
    jhymel
    XTR has a 3 year warranty and XT has 2 years.
  • 01-29-2013
    GL1
    Well, update since I started this thread. My warrantied brake / banjo nut & line that was installed last fall is leaking again. Noticed the power loss and saw the tell tale signs of mineral oil residue on the caliper. Leaking again at the same place...the crimp above the banjo nut. Back it goes to the LBS...again.
    As I have stated, I love these brakes but Shimano has to get this figured out. My rear is, and has been great since new but my front that was supposed to be a new, corrected banjo nut fitting/crimp is leaking yet again. LBS confirmed they come crimped at factory and it's the lever end that gets cut for size adjustments. So they come from Shimano this way...with the bad crimp.
  • 01-29-2013
    BullSCit
    I had the same problem too, put on the supposedly fixed Shimano crimped replacement lines and several months later had the same problem. Got tired of that, and put on some Goodbridge brake lines and knock on wood, didn't have any problems the last two months of the riding season. Hopefully that will continue to last, as they are truly the greatest brakes that I have ever used, it's just that the hoses suck. Having to ride the Avids hydros on my snowbike is painful, as they are a POS compared to the performance of the 785s.
  • 01-29-2013
    GL1
    Couldn't agree more. After the new generation shimano's the avids are lacking.
    LBS said shimano should do another warranty on them with new pads etc. as well since these have oil on them now. But I may look at the goodridge at some point and just be done with it. As you said, the rest o the brake is phenomenal just the lines are the weak link.
  • 02-27-2013
    jhymel
    For anyone that needs to get warranty on their brakes, I would recommend going directly through Shimano. By doing so they will replace your whole brakeset as opposed to a bike shop just replacing the hose. I just sent mine in and had new sets in less than 2 weeks.
  • 03-10-2013
    steiny
    Thanks Pau11y for the good info. I just ordered the full shebang - front and rear XT M785, ice tech rotors, adaptors, bleed kit, mineral oil, Goodridge hose, and fit kits. I ordered (2) of the #108 Goodridge fit kits and 3 meters of hose. And thanks for the tip on getting the stainless fit kit - that's what I ordered.
    I bought the new Shimano bleed kit TL-BT03-S which has exactly the right parts for the job and nothing you don't need. For the drain line step to bleed the caliper, I just pulled the plunger out of the syringe and pointed it into my drain pan. I got a perfect bleed on both brakes.
    I'm super stoked to burn in the brake set tonight and go for the maiden voyage tomorrow. :cool:
  • 03-10-2013
    SpeedStarr
    I had this on my SLX and they were replaced under warranty. I have since gotten XTR trail and have no issues. I hope they last but looks like it may still be a problem.
  • 03-23-2013
    morkys
    Awesome. I live in Canada and just ordered a front and rear XT kit and had not stumbled upon this issue until, of course, after I ordered these brakes. Now I wonder if I should bother installing the shimano hoses or not. I may contact Shimano before I install and ask them about the issue.
    Hopefully my living in Canada and buying Shimano XT brakes from the US isn't an issue via warranty, otherwise I have to replace the hoses myself. Braided looks like a good option, although I may need to buy them outside Canada too...lol.
  • 03-23-2013
    TheNormsk
    While no doubt there has been a problem with some people's brakes when you consider the millions of these made and sold it not a huge problem. I have 2013 XT brakes which I've had since they first came out and they have been nothing but reliable over the six or so hundred miles put on them.
    I say put the regular lines on and if you have issues then perform a warranty replacement. The odds are that you won't have an issue.
  • 03-23-2013
    DWill
    ^^^^ +1 I have 2012 XT's with at least 900-1k miles on them. No issues with them at all.
  • 03-24-2013
    morkys
    Fair enough. At least it's just the hoses and connections. The levers and calipers themselves are ok. I will try and see if mine have been updated though.
  • 03-24-2013
    palerider
    So how do you go about going directly through shimano?
  • 03-24-2013
    DWill
    If my XT's start leaking I think I'll just replace the lines with better quality lines. Faster and easier than warranty, not hugely expensive; and you don't take the chance of ending up with the same problem again.
    The brakes themselves are more than worth the effort and small expense IMO.
  • 06-17-2013
    Mac1987
    Hey guys, I noticed brake squeal and fade within 4 corners descending on Alpe d'Huez. Upon inspection I noticed the following black stuff around the banjo bolt. Does this look like the infamous leak or is this normal dirt and is something else causing the problems?
  • 06-17-2013
    jhymel
    I would expect it around the hose crimp, which is where the problem is. Have you made sure the banjo is tight?
  • 06-18-2013
    Mac1987
    I expected the same, but can not find anything strange around where the hose enters the banjo. The only thing I could find was this black stuff around where the banjo connects to the caliper.
  • 07-02-2013
    coursemyhorse
    I wonder if I have the same problem. I have a brand new set of Shimano SLX M675 brakes. They are now 3 rides old. They are Resin/Organic non finned pads.
    1st ride: Awful. Not bedded in yet.
    2nd ride: Poor to start but by the end of the ride really biting well. Nearly at optimum.
    3rd ride: Rear is fine but front is starting to honk and squeal and is not biting hard.
    I checked the front and it did appear a tiny bit oily but I do not understand where it could have got contaminated from. They do not rub. The bleed is good. It is just the front that now has an issue. I will check my banjo bolt tonight.
  • 07-02-2013
    Mac1987
    I would check the banjo bolt, where the bolt enters the caliper, the bleed port and the piston seals, in that order. A loose bleed port screw can leak oil, but be careful not to over-tighten it or you might ruin the seal and also start a leak. Another possibility is contamination from fork cleaner or another oil-based substance. It might be handy to clean your caliper, including the inside and keep the brake engaged with a tie-wrap or strap. Use a clean dry cloth or one with some clean water. Wait an hour and see if there is oil anywhere.
